Shaver HD8 return line
/ Shaver HD8 return line #1
zsemaskvich
RK 55
I have a RK55 and recently bought the shaver post driver. As many people have posted it needs to return with no restriction, usually using the fill port. My question is the thread. I have asked both RK and shaver with nobody really sure what the thread is on the fill port. A 3/4" galvanized pipe fits in the port while a 1" pipe does not. Even went to a hydraulic dealer with no luck. Does anyone know what fitting would adapt to pipe thread?
/ Shaver HD8 return line #2
I've been chasing that rabbit for a year on my Mahindar 2638 and right now a machine shop is making an adapter to thread into the tractor to accept a 3/4" NPT pipe.
In the meantime; the plastic cap that comes on the male ends of hydraulic hoses is JUST thick enough that if you slip it on a 3/4 pipe and push/thread it into the tractor (cut the center of the cap out) it will grab just enough to stay in for a while and not leak. It will wear out and you'll likely lose a gallon of oil when it blows out but it gets the job done.
Before you think I'm crazy I've made about $2500 with this setup so far.
Great idea. Kind of a bushing. I was considering buying an extra fill plug and drilling it out for 3/4 pipe and gooping it up with silicone/epoxy/jb weld or something to hold it. your idea is a lot easier. Hydraulic oil is cheap. Thanks
/ Shaver HD8 return line #4
If you have a metal cap on your hydraulic fill I'd do that. The plastic one on my 2638 isn't thick and heavy enough plastic to be able to do that and it hold up long at all.
Of course the hydraulic hose cap doesn't hold up long either but it will get the job done and make some money.
plastic cap unfortunately, might as well use the cheap thread protector
/ Shaver HD8 return line #6
Ok, this is kind of funny, I was about to respond to your video on YouTube and ask if you had any luck on the adapter! I have a 2638 as well and my HD-8 should be here next week. I have been plowing thru the internet looking for a solution to this problem and found your video and went "well, that will work" (obviously), but wanted to share something with you that may help.
I have a cab version of the 2638 and ordered a set of rear spools when I bought my tractor and was NOT a fan from the moment I saw how they actually attached. I have a post auger as well and when I mount it and lift the auger all the way up if it sways side to side the top link on the auger will come in contact with the left coupler. Aware of this I tried to always be careful but as luck would have it one day it made just the right amount of contact and bent the connector just enough to crack the adapter.
Took me several days to track it down (the block was not NPT despite the coupler itself being NPT). I ended up going to a hydraulic shop to find out that its BSP and not the diameter I expected.
Seeing your video and comment, it got me thinking, could that cap ALSO be BSP?
BTW, if you do happen to crack yours, here is the replacement: 3/8" BSP to 1/2" NPT Adapter
I have a backhoe for mine, so I got to thinking, what ports does the hydraulic valve have on the post driver? And is it possible to plumb the valve up to use those ports as opposed to the rear remotes?
I may call Shaver this week and ask.
/ Shaver HD8 return line #7
I called Shaver several years ago and they did not have an adapter to fit the 2638. I'm still chasing a rabbit to figure out the solution I want on hooking it up and I keep rigging it with a plastic cap till it fails.
/ Shaver HD8 return line #8
  • thread_guide.pdf
/ Shaver HD8 return line #9
Maybe some relief here.... IF 3/4 NPT fitting screws in and seal It be pretty sure that is what it is (depending on country of manufacture)...Also check out page 13 -15 of manual... Maybe some relief there....
That's part of the issue, 3/4" is way to small and 1" is to big. I have an HSC Branch about 5 minutes from where I work, I took the cap over there yesterday and spent about 30 minutes with the counter guy, these caps use a metric thread that is a one-off as well as a diameter that is not standard in anything. We kicked a couple of ideas around and since they have an inhouse machine shop, they are going to machine a threaded sleeve and tig it onto a 3/4" NPT Coupler, then we are going to grab the rest off the shelf parts to T it and put a high flow coupler and cap on it.
I am still hunting for an answer on the hydraulics on my backhoe, I feel like that would be the best option for me if they are actually plumbed the way it looks.
I figured for the cost of the machine work its a good backup plan.
/ Shaver HD8 return line #10
Normally, I don't comment on this stuff but... Both my new Kubota BV round bailer and my Shaver PHD require a 'return to tank / sump' fitting so I Teed into the return line from the FEL where it goes into the transmission case (on my M's that is on the backside above the PTO) with a Pioneer female QD coupler and put Pioneer males on both the bailer and the PHD. Both dump into the gearcase. Easy peasy. Just used a large flow Pioneer.
/ Shaver HD8 return line #11
Have them make 2 of those items and let me know and I'll send payment for it. I have tried and tried to find someone to make such a thing and I have tried inventing this wheel a hundred times and have yet to find something to truly hard pipe this.
/ Shaver HD8 return line #12
What is so odd about this is it seems all the hoses and fitting are "standard" (according to installation manual) except this one..... Why would a manufacturer use one nonstandard fitting amongst all the "standard" fittings.... Seems to me there is a problem diagnosing what the fitting is....
/ Shaver HD8 return line #13
The hoses are standard, NPT, but not every tractor has teh same thread on the hydraulic fill cap. Most equipment doesn't have to return directly to the sump like this one does
/ Shaver HD8 return line #14
Ugh!! I just saw this and picked it up last night. I will post pictures of what I did and post it and you can tell me if this is what you had in mind. Candidly they did not have the exact things I was hoping for so I may be modifying it but, long as I have the clearance I expect it should work.
/ Shaver HD8 return line #15
On now I understand better... IT not the Shaver that is actually the problem its the tractor and its proprietary design of fill cap.... Guess I misses mention of fill cap on tractor portion of initial post...DUH!
Why not get replacement fill cap and bore hole through it and add appropriate fitting...
/ Shaver HD8 return line #16
[mention]Birdhunter1 [/mention] So it’s home, I’ve now had 3 separate dealers tell me my suspicions on the backhoe hydraulics are correct but we could all be wrong .
They did not have the couplers I need though so I guess I’ve got to go on the hunt in the morning.
If the backhoe hydraulics work out this won’t be needed and I think to help everyone out I will run back by HSC next week and have them give us the exact thread and diameter that he built but here it is.
All put together this is what I had in mind.
I think this should work, I swear those hi-flow couplers are made of gold and painted silver because they are NOT cheap.
If my deal works out I’ll sell it all to you.
/ Shaver HD8 return line #17
So what it is this going to thread into? I don't plan on a coupler at all I'll just cap or plug the hard pipe on the tractor and when I need to use the driver I'll remove the cap and thread the hose in as it isn't hard and its not Like I use the thing multiple times a week or month. Usually I hook it up, pound a bunch of posts, then I'm done with it for a while.
/ Shaver HD8 return line #18
Then all you would need is this
I wanted to put it on and leave it.
That’s a 3/4” NPT coupler threaded to go directly into the tank fill.
Like this
/ Shaver HD8 return line #19
And you are adding a "Tee" fitting for what purpose, is the QC in "Tee" going to Shaver, if so it seems to violate the "free flow" concept....
/ Shaver HD8 return line #20
THAT IS EXACTLY WHAT I WANT! Does it thread in tight and seal? I can even weld on my own 3/4" NPT end, I just need the part that screws into the tractor.
PM sent!
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
