What’s this?
/ What’s this? #1
Quantumkev
Member
Ford 4500 Industrial Loader/Backhoe
So on my backhoe controls is have 6 levers, that operate 6 valves. I would expect the same mechanical connection between each lever and valve but on the boom connection it is completely different. Can anyone explain what this is, and what it’s purpose is?
Thanks in advance.
/ What’s this? #2
Is it a Case?
I remember that to store the boom for travel that you'd pull the lever until about the top of its normal stroke, then quickly push it away from you to finish the stroke to the locked transport position.
I've wondered how this magic happens and I still don't know 😆
You mention it's the boom valve and my Case experience came to mind.
/ What’s this?
I should have put it in there originally, sorry for the miss.
This is a 753 backhoe on a ford 4500 industrial tractor.
/ What’s this? #4
I can't help on a Ford hoe, this is mainly for Rusty -
The travel position on a Case hoe is accomplished by a combination of geometry, inertia and a QUICK wrist :rolleyes:
The boom pivot joint cylinder (2 of 'em on older hoes like mine) PULLS in order to raise the boom, until the boom gets ALMOST all the way up - at that point, the linkage goes "over center" - if you have enough momentum at that point, AND you're quick enough to then PUSH on the boom lever, the momentum continues upward travel BECAUSE the boom has passed the over center point, at which time a spring loaded hook (located MAINLY inside the main pivot casting) has engaged the "travel" pin (ALSO located inside the main pivot casting).
The spring loaded hook has a "release" lever, so in order to return to dig you GENTLY push on the boom lever, and as soon as the boom starts to travel further UP, you move that release lever which lifts the hook out of the way, then you PULL the boom lever (which actually LOWERS the boom til it moves past the travel hook - then gravity takes over, and the boom stays UP (but NOT far enough up to re-latch the boom).
The "inertia" part teaches you fairly quickly to NOT bother to try this with the engine at idle - the boom will NEVER have enough momentum to reach that over center position, so if the boom UP travel isn't fast enough, PUSHING on the boom lever will only cause it to go back to DIG position.
Wow, I'd almost forgotten how hard that was to explain - good thing actually DOING it gets to be a habit fairly soon :oops: ... Steve
/ What’s this? #6
Does the boom have float? To me the top gray part looks a lot like the float detent thing you usually see mounted on the hydraulic valve. The yellow thing looks like a damper (ie shock absorber) which would simply prevent you from ‘overcontrolling’ the boom and rattling it up and down real hard. Lots of ‘travel’ levers/pedals have dampers mounted inline with the linkage to take the edge off of rapid inputs.
What the open port on the shock is for, i dont know. If its a single acting cylinder i dont know what it would do there.
/ What’s this? #7
My 6 lever Ford 753 does not have that. I know some of the old Fords had Auto Dig, having never seen one nor understand it, maybe thats what you have.
/ What’s this?
So I really could do with some help on this, if anyone has any idea what it is…. I am trying to move this old backhoe and I had some luck today. One of my hoses is blown, and I thought it was the one for the dipper cylinder, but turns out it is the one for the bucket cylinder. So now I have the old rust bucket running, the loader moving, so I can get the front end in the air for moving the backhoe, and what I thought was a blown hose on my dipper cylinder, meaning I would have to manually move/hoist/rig the back hoe for moving, but now I know it is only the bucket hoses that are bad it is fairly easy for me to chain the bucket in place for moving…… if only I could manipulate the boom cylinder!!!!
With the loader and stabilizers I have 8 valves, and 7 of them work fine. 7 of them operate their respective cylinders (all be it roughly, with leaks etc) so I can manipulate everything into a position for transport, but the 8th valve, the one with this setup on the lever, doesn’t want to do anything….. I know the cylinder isn’t bound, because I manually winched the boom up today, and it moved fairly easily.
I can’t help but think this valves lever setup is what is causing my problem, and if I could understand what/how it is supposed to work I could figure out how to get this cylinder moving too.
Thanks for taking the time to look at this again, and I will take any suggestions!
/ What’s this? #9
Does any portion of the linkage you circled in red move? If the large yellow canister moves and the rod below doesn’t then something in the canister is faulty. You can put a pliers or vice grip on the linkage and operate the valve enough to get home.
/ What’s this? #10
That has to do with the auto-dig function that some of the old ford hoes have.
I have never explored how it operates, nor have ran one that has.
But go to messicks.com........and search for the 753-series backhoe attachment for new holland.
Then start looking at the parts diagram for the control levers with auto dig and you will see those controls.
I also suspect that some of those other unknown valves you were questioning in the other thread might be related to the auto dig function....because there are some diagrams that look pretty similar
/ What’s this?
Let me start by saying thanks to everyone that commented so far. You absolutely nailed it. Looks like it was for the “auto dig” feature. Odd that it was only on the boom control. I guess at some point it got removed from the bucket controls. The tractor is currently at the sellers location. I am trying to get the backhoe up off the ground so I can transport it back to my house.
The hose on the bucket is blown, and I was thinking that this odd linkage was what was causing the boom controls not to work, so I figured I could take the linkage off the bucket control and put it on the boom control as I can’t operate the bucket control due to blown hose, and I need to operate the boom control to move the tractor.
So here’s the thing. Even with the linkage removed from the bucket controls the bucket hose continues to spew hydraulic fluid…. I guess at this point I am looking for confirmation, but is it just that the seals in the valve body for the bucket controls are completely shot, and just allowing hydraulic fluid to pass? Is that what’s causing the hydraulic fluid to continue leaking from the blown hose even though the valve is in the neutral position?
If this is the case, is it even possible for me to pull the valve spool out with the valve body still mounted on the tractor? Or do I need to get the valve body on a bench before pulling the valve spool?
Any comments/suggestions gratefully accepted. Photo attached just because. Photos of tractors/tractor parts are fun!
/ What’s this? #13
There are no seals in the valve body to "blow" that would cause that. The valve body is a metal spool in a metal bore....no seals just VERY tight tolerances.
The only seals are where the spools protrude out of the valve body where the linkage hooks and the return springs on the other end. These are just case seals that keep fluid IN the valve body.
So basically.....there is no rebuilding the valve.
So, did it start spewing fluid as soon as it was started? Or did it start leaking when you were moving the boom or dipper? Because even though the hose is blown....that bucket cylinder still holds quite a bit of oil. And moving other functions can allow the bucket to move via gravity. And without a sealed system and having a blow hose....hydraulics are not holding the bucket in place. Therefor gravity can move the bucket and expel fluid out of the cylinder.
If it isnt much trouble to get to....and since you need to do it anyway, go ahead and replace the hydraulic hose and proceed from there
/ What’s this?
Thanks for the response, and please excuse my ignorance. I just assumed that there were o-rings sealing the spool positions, I didn’t realize that it was just really tight tolerances matching…. Makes for a whole lot simpler/reliable system though!!!
It does make me a little more confused though. I have the bucket strapped in a way that it shouldn’t be able to move.
When the tractor is static, and the engine is not running, I have no visible leakage, or at least if I do it is extremely slow.
As soon as I start the engine I start to see hydraulic fluid running out of the bottom of the boom. It’s not spraying, like it’s under great pressure, but it is running quickly enough that it is definitely being pumped. I am not moving the tractor, or operating any of the hydraulic control levers.
Bearing in mind what I mentioned above, that there is no operating linkage connected to the bucket valve, and your response, i guess the only Way that this can be happening is if the bucket valve is. Not properly centered? Even though it certainly appears that it is!
Am I missing something here? Or is there another explanation as to what I am seeing?
/ What’s this? #15
Id just try replacing the hose before you do anything else.
I know on alot of mini-excavators.......due to their hydraulic systems, will continue to flow oil if a hose is removed even if you dont activate that function. Just simply having the engine running.
Now I dont think that should be happening on your machine.....but who knows just what is going on. And you need to replace the hose anyway, so just go ahead and do it and see if you cant get the thing working. OR at the very least, plug the leak and see if the other functions will operate
/ What’s this?
So I finally managed to move the tractor back to my place, and start taking it apart to replace the blown hoses. It certainly seems like whatever that part was it was linked to the auto dig function. It is on the bucket cylinder. As I was taking all of the hoses off to get at the blown one, the bucket cylinder connections at the valves had these between the hose and the valve block. Anyone seen these before and know what they are? Are they some kind of flow restricter? And if so why are they only on the bucket cylinder?
/ What’s this? #17
This is most likely a flow restrictor. It will probably have something like a disc with a hole in it (like a washer) and a spring against it so in one direction the washer seats and everything has to flow through the hole, but in the other direction the washer lifts and fluid can go ‘around’ it as well.
From what i know they are not typically on the bucket cylinder but usually on the boom and swing, boom to prevent you from ‘dropping’ it at full speed or swinging it too hard.
/ What’s this? #18
If it has auto dig, the bucket moves out with the boom moving in, doesn't it? To keep the bucket at the set level? That would explain the leak in the bucket line when you're trying to move the boom.
/ What’s this? #19
Could that be a fitting to prevent erosion???
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
2012 JLG G9-43A TELESCOPIC FORKLIFT (A64279)
2012 JLG G9-43A...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
