FEL says Up 3pt Don't
   / FEL says Up 3pt Don't #1
charlessenf
Gold Member
York County, SC
Kubota B7800
When I store my Kubota B7800 in teh shed, I raise teh FEL to clear the Bush Hog attachment so that I can get teh entire tractor under cover. I also raise teh 3Pt so as not to drag that attachment (plow, box blade, etc) as I put her away.
In the morning or two days later, I find he FEL standing tall as I left it and the 3Pt and attachment down as low as they can go.
Is this the result of an adjustment I made or the default operation of the rear hydraulics vs the front hydraulics?
   / FEL says Up 3pt Don't #2
Some hydraulics leak down after a while. My tractor's the opposite...the FEL will leak down but the 3PH doesn't. I always lower both (well, 3PH only if there's an attachment on it) when I park it as a safety precaution.
   / FEL says Up 3pt Don't #3
My older tractors the 3 point hitches settle down overnight all the way.
My new LS both the front loader and rear 3 point seem to stay up but for safety reasons I lower the loader down when parked overnight , if there is a rear implement attached I also lower the 3 point for safety.
   / FEL says Up 3pt Don't #4
Does your B7800 have knob by the seat area for rate of flow to 3pt hitch?
If so raise your 3pt. hitch up and turn knob close see if that helps.
"rate of flow to 3pt hitch"
Yep, I thought that might be the problem/issue but was not sure. I'll try closing it to se if that changes things any. Thanks I've still got a lot to learn!
   / FEL says Up 3pt Don't #6
On all 4 of the tractors I've had, it's been the reverse.
2012 PETERBILT 365 (A55745)
2012 PETERBILT 365...
Riding Mower (A55853)
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
Bobcat T250 Skidsteer (A54865)
Bobcat T250...
