Ignition key
/ Ignition key #1
esz
Member
Colorado
Kubota L2550DT Kubota BX2200D Branson 2515H
Are newer Branson ignition keys universal? I think I should pick up a couple spares. When running my rear mount snow blower in reverse, I keep bending the key with my knee; probably not long before it breaks. I have the seat as far back as possible while still reaching the pedals. Any ideas on a solution?
/ Ignition key #2
Sometimes there is a number stamped on the key that indicates what it's cut to? If not try your local hardware store to see if they stock matching blanks and can cut a few spares for you?
/ Ignition key #3
A quick search on the old Google brought me this: https://www.amazon.com/Ignition-Branson-Tractors-mowers-198360-52160/dp/B093RB34Y3 There are plenty more sources out there.
I've hit mine somewhat gently a couple times too to the point the key has now a slight bend to it. I tend to hit the indicator switch more than I hit they though.
I know on the new updated 15 series they finally moved the ignition and the light switch to a more safe and logical place.
/ Ignition key #5
You can buy a dozen them on Ebay for a song
/ Ignition key
Relocate the ignition switch to the right side of the main console area. There should be enough wire, there was on mine. No more chance of "bumping" the key with your knee.
Thanks, good idea. I didn't know they had moved it. On my list when it gets warm.
/ Ignition key
Nice to know. The dealer phone quoted me $16.95-$28.95 per key. They can't tell which one I need until I bring mine in; not going to happen.
/ Ignition key #8
Here is much easier solution, 10 minutes of work, much faster than driving to the dealer, and costs whooping $0.00 and you will not be able to brake it again
/ Ignition key
Here is much easier solution, 10 minutes of work, much faster than driving to the dealer, and costs whooping $0.00 and you will not be able to brake it again View attachment 786070
Well, at least I am not the only one that has this problem. What did you do? Cut the head off and weld a couple pieces on?
/ Ignition key #10
I have the same problem with my New Holland. I can't understand why the engineers who design the consoles lay them out with the ignition switch in exactly the wrong place.
/ Ignition key #11
/ Ignition key #12
The ergonomics of the CUT tractors are basically designed for a much smaller person. Can't imagine how uncomfortable a smaller tractor would be. I had to raise and push back my seat on the MX5200. Pain in the ash project with mixed results. Honestly the cab area is just too small for a 6ft tall 200# person. Life is full of compromises. If you are a smaller man - you will fit better. Get some extra keys... and a knee pad :p
/ Ignition key #13
My LS was the same. Cut the bent key off and fit it in metal water halve handle. It's been great since.
/ Ignition key #14
First i straitaned it. Then cut and riveted 2 little seel pieces . Took about 10 minutes.
/ Ignition key #15
You are absolutely correcto-mundo on that. Our Branson 5520 cab is so tight between the steering wheel and the seat that I have to be very careful getting in, and I weigh 169 lbs wet!
I cant imagine a heavier tall person trying to fit in there!
/ Ignition key
My seat has a good adjustment range; it will go back so far that I can't reach the pedals. The problem is the console. When I move the seat to a comfortable position, my knees are too close to the console. I'll either move the switch or cut the key.
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Unused HLA BRB84 84in. Hydraulic Rotary Pick-UP Broom Skid Steer Attachment (A66734)
Unused HLA BRB84...
2013 HILL COUNTRY (A67714)
2013 HILL COUNTRY...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
