Minnesota to try and ban gas powered equipment
Status
Not open for further replies.
   / Minnesota to try and ban gas powered equipment #361
The gas blower ban has passed in many areas and others will follow. The CA ICE car ban is well known. The MN small engine ban, who knows.
But you’re avoiding the poop you stepped in. You said “lots of groups have agendas. Few are successful”
I countered that the “agendas” you downplay have actually become legislation. I’d consider an agenda becoming legislation VERY successful.
And another thing: “majority support” doesn’t always work, either.
Ok. We will see. I don’t think this current legislation will be successful, and don’t see CA enforcement being successful either. Unless you can see the future, we’ll see how this plays out.
   / Minnesota to try and ban gas powered equipment #362
See post 359.
Gasoline powered lawn equipment Engine ban in CA 2024 bro.
Read here:
excerpt from article:
"If HF 1715 eventually passes, it would make Minnesota only the second state in the country to ban gasoline powered lawn equipment. California passed a similar bill last year which is set to take effect in 2024.
Not hyperventilating.
Oh, and one more thought: ever heard “what happens in California happens in the rest of the nation”?
What you think now?
   / Minnesota to try and ban gas powered equipment #363
My two stroke doesn't pollute much... it hasn't moved from the shed where I put it 3 years ago.
Someday I'm going to have a bigger boat with about a 20hp 4-stroke, but I won't spend the money until I start using the one I have.
!2 foot aluminum with a 3 hp Evinrude... it's like a moped on the water. :D
When I was 12 and older I had a 12' aluminum V hull boat ('Tarpon Special') and a 3.5 HP Evinrude...it had two cylinders with a single carb...modified a bigger carb for more power and added a 12V fuel pump and 6gal portable fuel tank (rather than the gravity feed two quart tank)...lots of memories...!
   / Minnesota to try and ban gas powered equipment #366
LoL...There's a lot of people that wouldn't give a rat's patootie if CA broke off and sunk into the Pacific...route the refugees south of the border...America would be a better place...!
   / Minnesota to try and ban gas powered equipment #367
The US would be screwed if CA went away. We all know that, as it's been discussed in the past. Buy itself, it's the 5th largest economy in the world, the largest sub-national economy in the world, and 15% of the total US GDP.
Similarly, we'd be screwed if Texas went away, as it makes up 10% of the US GDP, followed by NY and FL.
Status
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2014 DRAGON 130...
golf cart (A55758)
golf cart (A55758)
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
