ToddRN
- Joined
- Jan 5, 2023
- Messages
- 11
- Tractor
- John Deere 1050
I have a 1984 John Deere 1050. This is my first tractor so I am in a learning curve to say the least. I have purchased a model 75 loader to add to it. I want to use a 2 spool aftermarket control valve. My tractor did not come with any hydraulics other than the factory ones for the rear lift. I have replaced all of the short hoses on the loader and will replace the long ones that connect to the control valve once I get everything installed and can measure how long they need to be. The person that I bought the loader from has worked on tractors for years. He says that the simplest/easiest way to connect the control valve to the tractor is to cut the high pressure line, connect the line coming from the pump to the input to the valve, come out of the valve back to the high pressure to complete the circuit back to the rear lift. I have been told that they make an adapter that you can connect the input and output lines on the control valve too where you disconnect the high pressure line from the pump, connect the adapter to the pump and then connect the high pressure line to the adapter. I haven't been able to find one or even a picture of one. I will add photos so everyone can see what my tractor hydraulics look like. Any help or direction will be greatly appreciated. I'm not trying to be cheap doing this but I am trying to be frugal.
