Buying Advice Deciding what to buy for my 1ST tractor.
/ Deciding what to buy for my 1ST tractor. #1
WxMan85
CASE 580L Kioti CK30
Sorry LS, I had caps lock on and never gave it a thought to change it. Here is the edited version of my first post. Thanks for the info and god bless!!
I have been in a joint custody situation using my father in laws Kioti CK30 with loader and backhoe, (which by the way, you all of this fine forum helped him decide almost 20 years ago to buy), he says hello and thank you for your all’s plethora of knowledge and experience!
I have grown up using this tractor as I dated and then married his daughter, we then 3 years ago moved back close to them and bought 10 acres. I have used it as well as paid a per job price to, use a case 580 Super L from down the road when the project was too big for the CK30 for the last 3 years. The CK30 has 996 hours on it and I don’t want to add another 5 or 6 hundred hours for the next portion of major projects to it. I am replacing all cylinder seals, changing filters and fluids, and tie rod ends and giving it back to its greener pasture home.
Now the big question for me is what in the world do I want and need to buy!?!? As stated earlier, we are on 10 acres, with the possibility in the future to double to 20. My 10 is 60% trees and 40% sandstone boulders with a little shell and dirt mixed in, (not kidding) good ole north eastern Oklahoma land! We are going to clear cut and dig out roots where needed on the fence line which on the 10 acres is about 3/8 of a mile of clearing, build a 40x50 shop with 16’ ceilings (so I need to also be able to fly 50’ trusses), clear cut and remove cedar stumps and a few less than 10” diameter (2-4) trees and stumps for a 30 tree orchard and garden, dig about 750 feet of water lines and electric, cut in a new 400’ driveway, and last but absolutely not least a pond that will be about 3/8 of an acre when it’s full. Now the pond is going to be a cheat by a bit as I am using an already cut in creek that runs diagonally across the property. I will only have to dig down about 5 to 8 feet in half of the pond as the creek has cut the other half out and then build a dam. Still that said, it alone is still a big project and have been quoted 15k for someone to come in and cut it and bring clay in if they cannot locate a pocket of clay on the property, or from when they dig out the pond. They did say it would be closer to 10k if they can locate clay.
So what tractor would you all recommend for all of this work? I don’t really have the money to go over 35k to 40k for something. I have a love for the Kioti brand as I have used one for nearly 20 years, and they have stood behind their product, even out of warranty and that speaks volumes to me!! I have read some about Mahindra and the company and line of products does intrigue me quite a bit. That said I don’t have much knowledge on them other than what I have read about the last few days of researching. I know that I have to lift and move a ton of materials, dig a ton, and build a ton of projects . So lifting and digging are main requirements. The extras would be nice, but those 2 items are the main have to’s for that price. Any and all advice is welcomed and appreciated!
With all of this said, I can possibly purchase a different 580 Super L that is a 97’ open air cab with about 3200 hours that I have known for 90% of its life for about 20k. It just had all new hoses and cylinder seals replaced and fluids changed out. I would have to buy new tires, so that is going to be a couple thousand more on top of purchase price……Thoughts?
/ Deciding what to buy for my 1ST tractor. #2
Maybe break this up into paragraphs..... I gave up reading it about a quarter way through. o_O
And, why are you yelling? :unsure:
/ Deciding what to buy for my 1ST tractor. #3
That Case would probably be your best bet. Fix, clean, maintain, restore it.
For your needs, it would be a better choice. When you are done with a lot of the 'heavy' stuff, you could sell it for at least what you paid for it. Maybe more if you get it fixed up. Then, buy a CUT to do the routine stuff later.
LS what if I did not have the 580L option, what would you recommend then?
/ Deciding what to buy for my 1ST tractor. #5
Before I got to the last paragraph I was thinking, you've got experience with a full-size TLB, you should know if it's too much or too little.
/ Deciding what to buy for my 1ST tractor. #6
The tractor you need for construction, might well be bigger and more robust than the tractor that works best for your ongoing maintenance work.
If it were me, I would go with the 580L, until all the big jobs are completed, then settle into a nice comfortable cabbed 35 to 45 hp Kioti/LS/ Kubota. Whatever brand suits you.
If you could swing it, it would be nice to keep the 580, for the unforeseen heavy construction jobs you come up with in the future.
I have been on my place for 37 years, and there’s always something that needs building or improving.
/ Deciding what to buy for my 1ST tractor. #7
You know the machine and history so for the money and capability the 580L definitely. There are very few options in your price range to do what you want to do in an efficient manner. (smaller machine will do it in 2-3x the time)
Sure, you can find a used 40-50 HP utliity tractor with backhoe in that (35-40K) price range, but for your work go full sized now and sell later.
/ Deciding what to buy for my 1ST tractor. #8
I was going to say GRAPPLE
Then i re-read the title and post, and realized that you are in market for a tractor, not an implement.
Kioti has some nice units. Find out what is the minimum requirement for your needs, ... and then go bigger, perhaps next size up :)
I do agree with your statement. I just wanted to tap into the collective knowledge of everyone here before I went and spent that kind of money. I feel that the CK30 is to small of a machine. I was looking at getting at least a 45hp CUT, but wanted some other opinions in the matter. Thank you for your response.:)
I would love to have a grapple!! I have seen some 5 in 1 buckets and grapples that are amazing! I would love to go to a bigger Kioti, but trying to get the boss to stretch the purse a little more is very much a challenge!;)
I have made the call over to the 580SL to see if he will actually move on the sale! Will let you all know what happens!:oops:
My thought too! I figured most would be in favor of the 580SL, but you never know till you ask. In a perfect world I would absolutely keep the 580SL and get a 45hp CUT for maintenance. I told the boss that we could also put it to work out here in our small town for hire and make some good money with it too!
/ Deciding what to buy for my 1ST tractor. #13
For all of that digging, the Case is the winner hands down. A CUT will work, but you'll beat it up. They are meant more as a jack-of-all trades tool. Like a swiss army knife, it can fix a lot in pinch but no substitute for a tool box full of tools.
/ Deciding what to buy for my 1ST tractor. #14
One approach may be to see what types of dealers you have within a reasonable distance. Of course, how far is reasonable is a variable only you can define.
You can get bigger, more powerful tractors for less than a CK, the problem is the backhoe. Those things are $7k or more. It can be done under $40k, but just barely.
/ Deciding what to buy for my 1ST tractor. #15
I know that a Mahindra 5100 series 5145 or 5155 will dig. and is in the low 30k range, it is tuff as hell and stable enough that with just a box blade attached i do not feel the need for filled tires. I do plan to add some more weight to the box blade.
if you zoom in on the first photo you can see the top of the tractor on the top left for perspective and this was done without a backhoe.
/ Deciding what to buy for my 1ST tractor. #16
If you can't get the 580, then the highest hp CUT you can go with. Anything smaller and it will just take time. I built a house from the bare ground up.... Did the site work, footers, utility trenches, full septic system, everything.....all with a 25 hp subcompact TLB (LS MT125)(about $20K brand new now). I was not in a rush, doing a couple hours after work and full days when off.
I sold that LS SCUT, and bought another 25hp TLB, an LS XG3025, which is now called the MT225E, but a CUT size. Even though it is still only 25hp, it works about double what the smaller one could do time wise.
You can get a capable CUT, new with the BH, like the Kioti CK2610, Branson 2515, LS MT225E, etc for about $27-30K with the backhoe. Once you get up to the 35-40 hp units, probably around the $40K mark.
Good luck with your search and projects!
Great info!! That is what I was looking for. I hope I can get the 580SL, but the guy that has it is one of those that says today he will do something (like sell his 580SL for 20K) and then the next day wishy washy about it...... So was hoping I could get info like you gave me and run with it in my searching. Once again thank you and I will keep this thread going with updates no matter how long, or what piece of equipment I can get!!
The first words out of my mouth when I saw your photos was "this has to be Texas" that is some serious soil and rock to move!! I was looking at Mahindra, and my only concern on the BH is its not a sub frame style implement, (at least not what I have seen for sale online and around here) it is a 4 pin hooked up to the back of the tractor. I just feel that it would break the tractor in half without that sub frame support. That said, I do like seeing that the loader can DIG that well, do you have a cut bar with rock teeth on the front edge of the blade? How large of an area is that, and how long did it take to achieve that? Thank you for your response!
Yeah there is a Mahindra 4540 with loader and BH for 39K about 45 minutes from me. I have not been able to get them to answer the phone for a few days now, so that is troubling if I ever need to have work done. Definitely not a good sign on their part. There is a really good dealer in Oologah, that has some package deals on some 30 and 40 hp Kioti units, but that is a bit of a drive for me if I ever need service or parts. Still might go look just in case the 580SL falls through. Thanks your your response!
/ Deciding what to buy for my 1ST tractor. #20
You’re not describing CUT work. Go with a full size backhoe or a CTL. A CTL and small excavator would be ideal, but above budget.
You can sell them without much depreciation, though.
when you’re done, buy a Kioti DK or CK.
2020 Chevrolet Tahoe (A60352)
2020 Chevrolet...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
2025 80in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
