Kioti Nx issues
/ Kioti Nx issues #1
Timbgf
Prescott Valley, Az
none
What year did the NX series have the issues with lurching in the throttle? Trying to figure out if a 2022 is safe.
Tim
/ Kioti Nx issues #2
Tim
According to some posts I’ve seen recently… it may not be fully rectified yet.
/ Kioti Nx issues #4
Can you point me in that direction to do some reading?
/ Kioti Nx issues #5
Tim
To be fair, my research when I was contemplating the NX, indicated it was in the HST, not throttle. It had to with the fancy electronic HST that they made for that specific model later in its life.
/ Kioti Nx issues #9
The NS is hard to find, but it’s a great unit. They sell very quickly.
/ Kioti Nx issues
Is the NX the only model that has the hydraulic controls up on top instead of on the side of the seat?
/ Kioti Nx issues #11
Not sure but my NS 5310 has the loader control mounted by the seat. There are cables running to the valve spools which I'm not a fan of but I'll take it to have the loader controls mounted convinently beside me.
/ Kioti Nx issues #14
In my sample of 1 -- no HST issues. They did a recall shortly after purchase for HST firmware and grounding straps. But I never had any noticebale issues before or after recall (still very low hours).
I don't think the NS was avialable when I bought my NX. If it is a more cost effective option on teh same size platform I may have optioned to go that route but i'm happy with my NX.
/ Kioti Nx issues
What year is your NX?
/ Kioti Nx issues #16
Tim
My 2022 has that problem. The dealer I purchased it from couldn't get it out. However, local Kioti dealer Vermeer Ag East Texas has gotten most of it out. They are still working on fixing the CAL problem. Sometimes, the tractor will not move in either direction (you can push either peddle down to the floor). Sometimes all it takes is hitting the CAL switch on the right pannel. At other times, you can kill the engine, wait 30-45 seconds, and try to restate. If no luck, try turning the key on and hitting the CAL button before engaging the starter.
/ Kioti Nx issues #17
I'm starting to think the "lurching" may just just be from foaming hydro fluid getting air getting stuck somewhere in the transmission and not the speed solenoid (or whatever Kioti calls it) but I need more running time.
The idea (and this may not pan out to be true) is that after I replaced my leaking hydraulic lines off of my hydraulic pump, I only used my tractor once in the winter for plowing and the tractor did lurch when cold. Once warmed up, the lurching went away (as it always has). But my tractor has been lurching when started summer or winter and now suddenly, it has NOT been lurching. This may be luck of the draw, or that the "air" that was stuck somewhere finally foamed out and was carried to the tank thereby resolving the lurching issue and because the tank is staying topped off now that I've fixed the hydraulic leaks.
Anyway, more cold start cycles are needed and my thesis may be incorrect.
My NX is from 2014 and has no updated software.
2020 TAKEUCHI TB230 EXCAVATOR (A64279)
2020 TAKEUCHI...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
Military Transfer Cases (A64119)
Military Transfer...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2012 FORD F-250 SUPER DUTY SERVICE TRUCK (A64280)
2012 FORD F-250...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
