3cyl Diesel Not 'Warming Up'
/ 3cyl Diesel Not 'Warming Up'
Hmmmm,,,,, wonder what this little widget does? Assuming it goes in the bottom of the tank? No electricals? Maybe detects vacuum and stops fuel flow when the engine isn't running? So it's failure caused the injector pump to flood and pour fuel into the the engine block? Trying to brainstorm this....
It's cam driven, and as far as I can tell, just moves fuel to the injection pump. There's a little diaphragm seal that failed and allowed fuel to enter the case.
I walked over to my neighbors and swapped the filter, and checked tube flow (it was OK). Definitely runs a bit better but still blowing heavy exhaust and not clearing up.
/ 3cyl Diesel Not 'Warming Up' #22
I am wondering if any of the bits from the diaphragm managed to make it to a injector causing the issue? It almost sounds like it is not firing on one cylinder. I might would try cracking the injector lines while running to see if one does not make a difference in the running of the engine. Then pull that injector and inspect it.
/ 3cyl Diesel Not 'Warming Up' #23
It's just a simple mechanical lift pump. Goes on the side of the engine. One of the lobes on the camshaft pushes the plunger in/out and a combination of check valves allows the flow to the right direction.
That explains how it flooded the engine block.
/ 3cyl Diesel Not 'Warming Up' #24
And maybe allowed air into the pump which moved it to the injectors??
I don't know the bleeding procedure?
/ 3cyl Diesel Not 'Warming Up' #25
Maybe so. I always just loosen the lines feeding the injectors and crank the engine until I see fuel squirting well. Then tighten the nuts back and it starts.
/ 3cyl Diesel Not 'Warming Up' #26
It sounds to m me like at least one cylinder isn't firing. And it may be getting to much fuel or not enough air.
Have you checked the air filter?
Also is the fuel return line plugged?
Also may check the valve clearances and then injectors for spray pattern.
You can check your injectors by pulling them all out and then watching the spray pattern while cranking the engine over.
All great ideas. Thank you guys.
I will loosen lines and purge, and check fuel return line, air filter is OK.
I will also check injector spray and see if I can find clearance specs somewhere.
/ 3cyl Diesel Not 'Warming Up' #28
I had a similar issue with a tractor running poorly. It turned out to be a problem with the fuel shut off. This tractor had a cable actuated shut off and the cable had slipped causing it to not completely open up with the cable pushed in. The engine was lugging like OP, and it had no throttle response. Once I figured out the problem I was able to re adjust the cable and it worked just fine. I would push the lever that the fuel shut off is on one direction then the other to see if that makes a difference. You might have to remove the linkage if your unable to overcome the controls. You might also try tapping very gently on the injection pump with the wood handle of a small hammer to see if something might free up if it is stuck internally.
/ 3cyl Diesel Not 'Warming Up' #29
Yep. I've saw mechanical shutoffs fail a couple times by coming loose and slipping out of adjustment.
My neighbor called me this morning and said he made a break through. Turns out... as he loosened the valve cover acorn nut on the 3rd cylinder (closest to the firewall) the idle smoothed out. If he retightened, the engine choked up.
I have a video I will upload later.
Does this make sense to anyone?
There is negligible blowby, air filter and intake tube is clear.
Now that that is smoothed out, it idles just fine for along time, but is not burning very clean, still unburned fuel
/ 3cyl Diesel Not 'Warming Up' #31
My imagination is going wild.....
Hmmmmm,,,,,, valve cover acorn nut...... Would this be the nut that holds the valve cover on? Would this nut also hold a bracket that holds something else? Was this acorn nut tampered with during the process of replacing the lift pump?
Inquiring minds want to know!!!! Anxious to see the video!!! :)
It's weird, eh?
I personally didn't mess with the nut when we did the lift pump.
My neighbor with the tractor is elderly, just full story, and the dealer tried to tell him this thing was junk several times before. I don't know a whole lot about diesels but I at least wanted to try and help the guy keep from scrapping this thing. He's taken really good care on the thing, and it only has 500+ hours on it. He tinkers a bit, and it's possible things were done I'm not aware of.
But I got a video of the terrible exhaust at high idle I'll share soon. Seems like coolant, but it doesn't appear to be losing any..
/ 3cyl Diesel Not 'Warming Up' #34
Does it do the same thing if you loosen the oil fill cap? Maybe a bad crankcase vent?
/ 3cyl Diesel Not 'Warming Up' #36
It's weird, eh?
Next to his socket, is that the lift pump? Or what is that I see?
/ 3cyl Diesel Not 'Warming Up' #37
Or maybe,,,, he's tightening the valve cover enough to compress the top causing valve train to not function properly??? But then, you should hear the tappet banging on the cover......
I think it's just a little cover, the lift pump is on the other side. Here:
/ 3cyl Diesel Not 'Warming Up' #39
Interesting thread. Keep it rolling. Thanks!
/ 3cyl Diesel Not 'Warming Up' #40
I believe it is adjusting or torquing the decompression rod.
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
