Kioti NX 4510
   / Kioti NX 4510 #1
Roger099
Kioti
I have a Kioti NX 4510. It has 300 hours. I was plowing snow An it went in to a regen the engine rpm’s went up and the motor was pouring out white smoke this was the first time it went in the a regen. The motor ran for about 4 minutes then died. It will not start again.. I did get a P008 code and I believe the is the sensor on the fuel filter. But I am not sure that would keep it from starting I have ordered a new sensor and filter. Any thoughts on this problem would be greatly appreciated. Thanks
   / Kioti NX 4510 #2
Check out this post! Good luck.
  • P0008 is the result of a test run by the engine control module to check for misalignment between the camshafts in engine bank one and the crankshaft. The misalignment for this code would be at an idler sprocket in the bank or at the crankshaft. The test checks the positions of the camshafts and compares them against a reference value.
  • I found it on this website maybe under Kioti!
   / Kioti NX 4510
That would make sense since there is an occasional pop like it wants to start. I will look further in to this Thank you
   / Kioti NX 4510 #4
Not sure if I am reading that right, you said that it has 300 hours and this is the first regen? My DK4510SE runs about 40 hours to a regen.
   / Kioti NX 4510 #5
I have a manual for the NX, and don't have a P008 code in it. There's a P0088 and P0089 in there referring to fuel rail overpressure. There is a thread 'understanding error 008' on this site. And my 2016 NX4510 cab regens approx every 30 hours.
   / Kioti NX 4510 #6
sorry, was looking at service manual. Owners manual has P008 as no signal from fuel filter water sensor.
   / Kioti NX 4510
Yes it’s the first regen normally I use it in short periods like feeding the cows or something. Not this year we had heavy snow and it not 3 hours plus periods. I am not looking forward to taking in to a dealership. The dealer that I bought it from was good but the owner retired and sold and the new dealer doesn’t do Kioti.
   / Kioti NX 4510 #8
Welcome to the club. There are several unfortunate members. My 2019 Kioti dk5510 had its first parked regen at 348 hrs. Regen failed and limp mode began. The tractor has been in the shop repeatedly for this issue. Unable to resolve it, much less figure it out. At 460 hours my tractor is useless. Now looking for something without a dpf. I hope you have better luck. Kioti technicians in this area are not up to speed on tier 4.
   / Kioti NX 4510 #9
Was your engine at operating temperature when it went into regen?
   / Kioti NX 4510 #10
Still curious about these "First Regens" at such high hours. Mine regenerates every ~40 hours. So far all have been auto initiated during use. A slight change in engine note, a little odor, which causes me to look at dash and say, "Oh, it's doing a regen". It has gotten to where I can almost anticipate an auto-regen based on hours since I use my tractor mostly for mowing the field.
Have either of you ever had your "light" come on and "hit a button"? You may have cancelled the auto-regen. The only reason I would see to do a "parked" regen under normal circumstances is if the light came on (regen started) as I was finished with what I was doing. I would then either find something else to do with it for the 10 - 20 minutes or just find a place to park it and kick up the RPMs until it was done. Two years and > 250 hours I have had absolutely no issues with my DK4510.
   / Kioti NX 4510 #11
No I haven't. Parked regen on a kioti has a different light notification than a passive regen. Parked regen requires the operator to stop, please tractor in neutral , parkining brake engaged, throttle on idle, hold down regen switch for over 2 seconds. Regen is supposed to take over at that point and last for approximately 40 minutes. Apparently you have not had a Parked regen. With that many hours you should have. You too are probably in for a rude awakening. I hope not.
   / Kioti NX 4510 #12
My passive regens like you are referring to occurred regularly from 13 to 20 hours apart.
   / Kioti NX 4510 #13
So that is what I meant when I asked if it was the first regen. I meant of any kind. How often did you have passive (auto) regens? How did those go?
Edit: your reply crossed with mine.
As mentioned I use my tractor mostly for mowing, running ~ 2500 RPM. No issues so far, no need for parked regen so far.
   / Kioti NX 4510 #14
I have read, but have no personal experience about, that it is not good to allow your diesel tractor to go into regen while it's still cold.
If you understand regen, it's dumping some serious fuel into the system, either on the exhaust stroke into the engine or with an independent injector. I doubt they're using an independent, separate injector.
I know nothing about it through personal experience but, if I had a tractor that required regen, I'd look into it. I would also look into keeping the regen switch on 'deactivation' until the engine is at full operating temperature. If that is possible.
Also, I'd run a good 5w-40 Synthetic in any tractor that uses regen. I am definitely not a part of the Amsoil crowd, but I do believe in 5w-40 syn for anything that has to do a regen. Big Diesels are a whole different ballgame. I'm talking the smaller diesels we see on CUT's. I also think part of the problem is the ECM's on the smaller tractors (-100hp) are not as sophisticated as they could be. Getting sidetracked. Just look into it. ;)
But my understanding is that going into regen when your engine is cold is uncool (pun intended). I believe LS MTron had/has a serious problem with this.
Just trying to help.
   / Kioti NX 4510 #15
   / Kioti NX 4510 #16
The instructions in the manual are confusing at best, misleading at worse. I originally read that to mean that when the "regen light" came on I was to follow those steps. I was fortunate to see better descriptions of these lamps on this forum. There are actually two "regen" lights... the "underway" lamp and the "warning" lamp. The manual does not clearly instruct you to just keep working with the first which is more of an "FYI" indicator. You are supposed to keep RPMs at ~PTO speed until it is finished. The operator can cancel the passive regen if it is not a good time to do it. I have made the decision to always make time to let it run. That section of the manual does not address the "underway" lamp, it jumps straight to the "warning". The "warning" (as I understand it) would mostly occur if for some reason the passive regens were summarily cancelled or did not keep the DPF clean for some reason.
   / Kioti NX 4510 #17
If you turn to 'deactivation' on your regen switch, will it prevent a regen? Or does it -- Whatever.
If it were me (it isn't) I would keep my regen switch off until my engine was nice and toastie. IF that's an option.
I don't like the idea of a diesel trying to regen while it's cold. Diesels don't like the cold anyway. The whole idea of a regen is to burn off the soot in your DPF. If it isn't hot enough, what happens? Hydrolock? I don't know but if that happens, you just bought a new engine. And what happens if your DPF isn't hot enough to burn off that extra fuel? I don't know.
I don't like the whole thing. It sucks because -- It's stupid. And it's stupid because the people behind it are stupid.
   / Kioti NX 4510 #18
If the warning light comes on when the engine is cold, it is recommended in the instructions to let it warm up before pushing the switch.
   / Kioti NX 4510 #19
Regen might be a secondary issue. It would be helpful if you could put your location in your profile so that we have a better understanding of your operating environment.
I'd check on the fuel situation. Verify that you don't have water in your filter or that there's blockage happening: I encountered blockages in my fuel line from/at the tank due to frozen water (pellets); bad fuel cap was letting in rainwater. If you have water in your fuel your sensor should detect that: as noted for me, water was freezing IN the tank and blocking the fuel line out in which case the engine was being starved for fuel.
   / Kioti NX 4510 #20
Yes, and I believe that the passive regen would never start until the engine is at operating temperature. At least that has been my experience. It has always been after I had been operating for at least 30 minutes.
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
2023 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2023 CATERPILLAR...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
60" HANG-ON WHEEL LOADER FORKS (A60429)
60" HANG-ON WHEEL...
