Cat 1 Cylinder length Hydraulic top link
/ Cat 1 Cylinder length Hydraulic top link #1
kas2960
Ontario, Canada
CK4010HST
Sorry folks,
Another question regarding replacing the manual top link with a hydraulic one. What is the length of cylinder you are using?
I currently have a blower attached and the top link is extended to 21". I realize I can go and remove/install my blade and box blade and rotary mower and and measure the lengths and of course since it's winter put the blower back on, but instead of re-inventing the wheel, my guess is someone already has a lot of experience with this :)
Looks like 18"-26" and 20 to 28" are the ones I would pick from. I am worried that the 20" may not retract enough. A store here in town only has the 20"-28". The one I was going to buy was on Amazon from Sparepartsholland which comes with hoses and a dual check valve and is 18"-26". Stay warm and thanks!
/ Cat 1 Cylinder length Hydraulic top link #2
Every application is going to be different. I think I'm using the 18-26 on mine. However, I have Quick Hitch and I'm using a Stirrup to connect the rod end to the QH. The stirrup allows a cutter to float.
Here's a better picture of the stirrup.
/ Cat 1 Cylinder length Hydraulic top link #3
Sorry folks,
The working length that I normally recommend for the Kioti CK10 series tractors is 18"-25".
I think that the 18"-26" unit would suit you well. (y)
/ Cat 1 Cylinder length Hydraulic top link #4
Does your factory top link work with all your attachments? That's the length to get. I added Pat's Quick Hitch to my tractor then needed a longer top link and a longer PTO shaft for my mower.
Good point. I could just unhook it and measure it fully re-tracked and extended. I think it's about 17.5" re-tracked but I don't remember having anything attached like that. Thinking the 18 to 26 will do.
/ Cat 1 Cylinder length Hydraulic top link #7
Be careful what you buy. I saw “deal” on “Type 1, 3-pt hydraulic top link”. Didn’t have time to put it on when it arrived, and when I had time to try it, I discovered it for 20-mm pins not 3/4-inch. About two months after the return window closed. I probably could have used it and tolerated the slop.
Plan is to buy another as the top link, and use the one with the 20-mm pins to modify my rear blade to power angle.
/ Cat 1 Cylinder length Hydraulic top link #8
20mm is about .030" larger than 3/4. It should have worked with a 3/4 pin. Are you sure you weren't trying to use a 7/8" pin?
/ Cat 1 Cylinder length Hydraulic top link #9
the 3/4 pin was rattling around. Probably would work, but be loose. But since I needed a double acting cylinder, to modify the rear blade I decided to buy another cylinder with the right sized mounts.
If I didn’t already have an alternative use, I probably would have tried it with the one I have.
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
HYSTER 50 FORTIS STRAIGHT MAST FORKLIFT (A59823)
HYSTER 50 FORTIS...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
(INOP) 1996 FORD F150 SINGLE CAB TRUCK (A59823)
(INOP) 1996 FORD...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
