buckeyefarmer
Epic Contributor
wouldn't be much different than a deep water well open loop and returning down a separate well on the same aquifer
When I took my training they said don’t dump it back into aquifer.
This is exactly the issue with geothermal.I want to redo the heating/cooling system in my house. Researched geothermal, closed loop is not used around here due to all the trees. Open loop is what all the installers are familiar with. I was told they drill one well/ton of cooling, for me that would be 4 wells. Total system cost, just over $40K. Top of the line variable speed air to air system with propane backup was going to run $14K. As much as I like the idea of a geothermal system, I'm not sure I would ever make up that $26K difference.
But often it does. It can not when it costs $200/hr to dig a ditch.This is exactly the issue with geothermal.
Geothermal has some theoretical efficiency advantages, but isn't very much compared to modern air source heat pumps. On a ROI basis, the added cost of a geothermal installation can't come close to making up the lower upfront costs and generally high efficiency of air sourced heat pumps.
Locally, the ROI on geothermal is never.
That's not open loop. Open loop would only require 1 or 2 wells....depending on where you choose to discharge.I want to redo the heating/cooling system in my house. Researched geothermal, closed loop is not used around here due to all the trees. Open loop is what all the installers are familiar with. I was told they drill one well/ton of cooling, for me that would be 4 wells. Total system cost, just over $40K. Top of the line variable speed air to air system with propane backup was going to run $14K. As much as I like the idea of a geothermal system, I'm not sure I would ever make up that $26K difference.
Considering all the discharge was going into the creek behind my house... I would consider that open loop. They were instant that they needed to drill 1 well per ton of cooling. I told them that seemed excessive, their reply was "that is the way we do things". So.. they are not 'doing things'.That's not open loop. Open loop would only require 1 or 2 wells....depending on where you choose to discharge.
4 vertical wells is still closed loop. They just put the loop vertically in the wells instead of trenched horizontally in the ground.
Considering all the discharge was going into the creek behind my house...'.
Standing column concept sounds attractive, maybe pull from the bottom, return to the top. Don’t need a lot of flow, larger water volume and far better thermal conductivity to the earth than 1 ½” HDPE / bentonite clay. Down side is minerals / silt in the water damaging the equipment over time. Not sure I would want to share this well with domestic water, though.One of the good things about open loop geo is that it can utilize an existing water well. You should not need a well for every ton, but rather 1.5 GPM for every ton. If one well can make 6 GPM it will work for a 4 ton unit. If you don't have a good place to dump, you may need to drill an injection well. But many people use what is called a standing column design, which pumps and dumps back to the same well. If you have to drill wells for an open loop geo it can get as expensive as the closed loop designs. But using a well that was already drilled for house water doesn't add any cost to an open loop geo system.
I actually have 2 wells on the property. One supplies the house, the other for the irrigation system. We almost never use the irrigation system, but the HVAC tech didn't want to hear about using it. If I had a clue how to install a geothermal system I might try it myself, but I don't have the knowledge or tools. Also, I am a little concerned that the well water is fairly hard and full of minerals. Within 50 miles of me I only have 3 HVAC companies, only 2 of them do Geothermal and one of them installed the HVAC mess I have now and I wouldn't use them again. My options are limited for Geothermal and I am afraid even if I got a system installed, what would it be like to get service if needed. As much as I would like to go Geothermal, I just don't think it is in my future here. My property is also heavily wooded and I don't have an 80' x 120' area clear within 600' of the house.In that case, if your existing well can supply 6-8 gpm in addition to what you use now, you don’t need to drill any well, and geo makes a lot of sense.
You had a moron for a contractor...plain and simple.Considering all the discharge was going into the creek behind my house... I would consider that open loop. They were instant that they needed to drill 1 well per ton of cooling. I told them that seemed excessive, their reply was "that is the way we do things". So.. they are not 'doing things'.
