Mf65 trans and diff oil
/ Mf65 trans and diff oil #1
markw1969
mulino, or
John Deere 3032E
Need help on mf65 trans oil. I have a 1962 mf65 with multi power transmission. I see the manual calls for 80-90 wt mineral oil. Is the miles gear oil ok or is it not gl1? If that’s even important. The local MF dealer wants $110 for 2.5 gallons vs granger at a bit more than half price. If I’m on the wrong track please pount me to the right one at a decent cost???
/ Mf65 trans and diff oil #2
I am not absolutely sure but used to be that GL4 and lower were typically used in transmissions with synchromesh. GL5 contains high levels of sulfur-phosphorus which are not good for softer metals. Or perhaps if you could find manual transmission oil, it would likely be ok. Personally I would go with what the dealer recommends and be safe in knowing it has the correct fluid.
Perhaps someone else can chime in here that knows your machine better..
/ Mf65 trans and diff oil #3
Hi,
I noted the Multipower, but what are the other specs on the gearbox? Is it the 6 speed?
It’s a 4 speed. I see tractor supply has ford trans oil that is mineral sae 90 and gl1. I’m really hoping this will work. It’s fairly reasonable pricing
2012 MAGNUM TRAILER WATER TRAILER (A67714)
2012 MAGNUM...
Fecon 72in Mulcher Head Skid Steer Attachment (A66734)
Fecon 72in Mulcher...
2017 Chevrolet Impala Sedan (A66738)
2017 Chevrolet...
2015 John Deere 319E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
