MarblemountLane
Bronze Member
- Joined
- Dec 28, 2007
- Messages
- 52
- Location
- Skagit Valley, Washington
- Tractor
- Massey Ferguson 204 circa 1959
I’m thinking most of us with old tractors have similar questions. Maybe I should be posting over at BobIsTheOilGuy but I think this is a common issue.
I have a Massey Ferguson 204. I’ve heard they were made 1959-65 and also heard 1960-66. Ran my serial number at one site and it said 1959.
The manual says Type A ATF in torque converter. Closest thing today is Dexron, so that’s what I used.
Modern engine oils are much better, so I figured no harm in using 20-50 in that old loose Z134 engine. I went ahead and bought a spin-on filter conversion.
Looking at my hydraulics, thinking of changing return hose and filter, and all fluid while I’m at it, I see the manual says Type A ATF for the hydraulics, too. Should I go with Dexron again, or is there a modern alternative that is better and/or more cost effective? Also, will I have compatibility issues flushing out the system and making any change? (I have the big sliding kingpost backhoe, but have never seen it on the tractor. It will need TLC but I hope to see it in service.)
My trans/axle wants all mineral SAE90. Tractor Supply had some (interestingly, the label says Ford transmission fluid). I’m using this OK. BTW I had an issue with it being half water when I got the tractor, and even after a change I had water. Messy stuff to handle, but I drain a bucket out, place the stainless steel bucket on a hotplate set to take it slowly to just above 212 F then let it cool, drain more with water & return the water-free oil to the trans. Do we really need special all mineral 90 weight, or can we use modern 90W or even something like Redline MT90?
