Any precautions-electrical system-when welding on tractor?
/ Any precautions-electrical system-when welding on tractor? #1
wisconsitom
Bobcat ct2025 HST
Hey all, we're going to weld some hooks onto a 3-pt. skidding winch that lives on the rear end of my tractor. This amounts to a few tacks really. Question is, should one disconnect the battery or anything when welding on what amounts to a part of the tractor, given it's all continuous from an electrical standpoint.
Or am I overthinking this, like I usually do?
/ Any precautions-electrical system-when welding on tractor? #2
For the most part using a DC welder (the welding current itself, not what the welder is plugged into) and having the welder ground as close to the weld as possible there is little chance of an issue, If using an AC welder doing similar should be fine but if the tractor engine has a computer it really would be safer to disconnect the battery...
Thank you sir. This is a simple machine, a bobcat ct2025. No computer.
The welder is my son's Hobart tabletop mig, I know not the AC/DC, but can check that.
/ Any precautions-electrical system-when welding on tractor? #4
The welder current flows from the working tip to the ground clamp. No worries really. Make sure you clean the clamp contact area and keep it reasonably close to the work area.
Thanks guys.
/ Any precautions-electrical system-when welding on tractor? #6
I have a magnetized watch for sale. Keeps perfect time twice a day.
Welding can induce currents. Stray EMF starting and stopping arcs can be a bother for electronics. The safest bet is to disconnect the battery before welding but I don't always follow my own advice.
/ Any precautions-electrical system-when welding on tractor? #7
Okay sure. But I probably did that once in 30 years and never had a problem then or the other 999 times I didn't disconnect. Of course I could just have dumb luck :cool:
/ Any precautions-electrical system-when welding on tractor? #8
If you worry about EMF what good does disconnecting the battery do? You still have all the frame grounds (connected to your welder ground) and the current comes from the EMF not the battery. I agree that arcs could cause a problem by inducing higher voltage or current that the electronics can handle but that could still happen with the battery disconnected.
Not an expert and willing to learn.
/ Any precautions-electrical system-when welding on tractor? #9
Okay sure. But I probably did that once in 30 years and never had a problem the other 999 times. Of course I could just have dumb luck :cool:
90% of the time, I'm right every time.
/ Any precautions-electrical system-when welding on tractor? #10
I try not to weld on connected electrical systems. I usually try and pull both battery leads off.
There have been a few times when I didn't with no adverse effects.
My bigger concern is welding across bearing or joint surfaces I try and keep my ground on the same piece that I'm welding to or on.
Often if I can I'll use the ground clamp to hold the piece that I'm going to weld onto the unit.
/ Any precautions-electrical system-when welding on tractor? #11
My logic says why take a chance. Disconnect both battery terminals, turn on your lights to deplete any current in the system, and you shouldn't have any problems. Fuses, or otherwise.
/ Any precautions-electrical system-when welding on tractor? #12
I have welded on every tractor I've owned without disconnecting the battery. I'm not telling you what you should do.
I'm just stating my experience.
/ Any precautions-electrical system-when welding on tractor? #13
Shortest path (stinger and ground close togethe)r and remove the battery cables.
I reckon all things considered, we'll just disconnect the battery, simple matter that it is. FWIW, this particular job will consist of tacking the thin connector strap on u-bolts to top surface of Norse 250 skidding winch safety cage. I like the idea of using grounding clamp to hold this, or these-we might do more than one-in place while welding on.
/ Any precautions-electrical system-when welding on tractor? #15
LouNY has already mentioned ... beware of the welding current passing through bearings or pivots. You don't want a spot weld in any of them.
/ Any precautions-electrical system-when welding on tractor? #16
Don't want welding spatter to burn a hole in a hydraulic hose, either.
/ Any precautions-electrical system-when welding on tractor? #17
If your tractor has a computer then it would be a good idea to disconnect it. I don't think it would hurt to disconnect the battery too, but neither do I understand how it could help. Is it to prevent damage to the battery itself? If so, it's worth pointing out that the battery is the most robust electrical component on the machine; even more stout than the wires that connect to it. Or are we thinking that the battery completes a circuit, so removing it is like opening a disconnect and preventing current from flowing in any circuit?
There are only two ways I can conceive that welding could damage electronics:
1. By raising the electrical potential of one ground higher than that of another ground, causing current to flow through electrical circuits in ways that it isn't intended to flow. And I think that would happen whether or not the battery was connected. The best way to prevent that is to place your ground clamp as close as possible to the area being welded.
2. By inducing high frequency EMI into wiring harnesses. This also is possible with or without the battery connected. The best way to prevent this is to keep ground lead and welding lead as far as possible from any machine wiring, and if you must cross a wiring harness with a welding lead, do it at 90 degrees, never running alongside a harness.
/ Any precautions-electrical system-when welding on tractor? #18
Why not take the winch off, weld your hooks and remount the winch? For me, that's far easier than screwing around with the battery and worrying about what if's.
/ Any precautions-electrical system-when welding on tractor? #19
Mainly be sure you are grounded to and welding on the same piece of metal.
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2018 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2018 CATERPILLAR...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
