Ideas for fastening strobe light to tractor roof
/ Ideas for fastening strobe light to tractor roof #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
My Challenger has a typical plastic roof shell. Previous owner installed a home-brewed light bar bracket. Looks/works fine except one thing: It makes the tractor about 10’-2” high. I am storing it in a barn with a 10’ door opening for snowplowing season. Figures….
I removed the strobe light from the light bar and leave light bar in place the tractor is about 9’-10” high, so now it fits, but no strobe for snowplowing. If I stuck strobe directly to roof plastic, it would be about 9’11” high-it’ll just squeak through.
I’d like to fasten the strobe directly to the roof plastic to lower my overall height & retain use of strobe. The strobe, normally bolted, has 2 rubber mounting discs about 3” diameter. I presume they are shock absorbing and also leave an opening for the power wire.
I can’t use bolts or drill the roof.
Would large pieces of velcro stuck to the bottom of rubber discs and on top of roof plastic work? I don’t know if velcro adhesive sticks to rubber? It sticks to plastic very well. The power wire could act as a tether if it’s ripped off by a branch.
Or, what would be alternative suggestions would be better to stick directly to roof plastic? Gotta hold pretty good.
/ Ideas for fastening strobe light to tractor roof #2
I wouldn't trust the adhesive to stick to rubber in the cold.
I'm curious if a fishing magnet would stick to any kind of metal support on the underside of the roof? Or if you could glue some large fender washers to the roof top and then use a fishing magnet to hold the strobe to the washers?
I like that idea, but the roof structure on the inside of the cab has a ceiling. I’d have to pull the ceiling down.
/ Ideas for fastening strobe light to tractor roof #4
Or cab orange top light replace with LED bulbs and wire them up to flasher.
/ Ideas for fastening strobe light to tractor roof #5
Google Click Bond Studs, they are aerospace quality fasteners that attach to the surface and have studs (bolts) of various lengths that you could attach to. They also have nuts that secure to the surface.
/ Ideas for fastening strobe light to tractor roof #6
Is the black strobe bottom metal or plastic?
Plastic with rubber shock mounts.
I’m thinking about pulling the ceiling down, but what a PITA
A little more info: The home made light bar was welded to the 2 flat circular metal magnetic bases mounted to the roof plastic.
I found these: 6” diameter only 2” high with magnetic base.
Maybe I cut off the home made light bar from the 2 bases and just mount these to the flat metal magnetic bases?
/ Ideas for fastening strobe light to tractor roof #10
I wouldn't pull the ceiling down not really knowing if a magnet will actually hold the lights to the roof that way.
I probably should mention that even a small fishing magnet has such a strong grip that it could be a pain to remove the lights from the roof, especially being so far up in the air.
/ Ideas for fastening strobe light to tractor roof #11
On the top of the back of the cab (that's a mouthful)
where the challenger decal is just might be where they'd mount a license plate in Europe. If you're lucky there might be some type of threaded hole provided from the factory. If you're that lucky you could make a mount of some sort and keep it as low as possible.
If you got a pair of mini strobes, the mirror arms look like a good option also.
/ Ideas for fastening strobe light to tractor roof #12
/ Ideas for fastening strobe light to tractor roof #15
Contact cement will stick to rubber. Glue the Velcro to the rubber with contact cement and use the glue backing to stick the other side to the roof plastic.
/ Ideas for fastening strobe light to tractor roof #16
I wouldn't put any penetrations in my roof because ive seen that work out so well. I'd get on one of the steel corner posts, probably bolt holes already there.
/ Ideas for fastening strobe light to tractor roof #17
Thinking out loud again and taking stumblinhorse's suggestion a little further. Mount a hinge on the lower lip of the roof in way of the "Challenger" decal (holes would let water drain from inside roof); weld an "L" shaped bracket to the hinge so the strobe would sit atop the roof but could be swung down. A suitable ring welded near the angle of the "L" could allow movement of the bracket with a pole like a boat hook or an iron rake. This would work until you came back tired and forgot about the light, but you might be able to fabricate some leading curved piece of metal that would flip the bracket down when you drove under the door lintel, or perhaps some hanging alarm to alert the operator.
/ Ideas for fastening strobe light to tractor roof #18
I caulked a 4x4x.5 inch flat steel to the Gator roof with a product called Lexel that I bought at Ace Hardware. It says it will stick to almost anything, waterproof, mildew resistant and paintable. So I gave it a try.
I stuck my magnet base beacon light on the flat steel and plugged the power cord in. What was just a "temporary" setup has been there for two years now.
/ Ideas for fastening strobe light to tractor roof #20
That's a bad machine, mount that dude wherever you want.
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
Land Survey Kit (A60463)
Land Survey Kit...
500BBL WHEELED...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
