Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #121
Moved 8 loads from IL to TN with 14K gooseneck trailer behind my GMC 4500C
For what you wanting to haul and your needs a single cab four wheel dually may be preferable.
If possible a 7.3 or 12valve Cummins may be advisable. Pre the emission controls. It may be nesissary to spend money on the running gear and engine but would be much less than a newer truck would cost.
Moved 8 loads 550 mi. from IL to TN with 14K gooseneck trailer & 2003 GMC C4500 Duramax in 2007-08. Some loads (gvw) exceeded 40K, 2 loads with 20' china boxes packed full, 1 with Case 450 dozer/loader plus, longest was with '71 JD 4020 Diesel and Kuntz earthmover. No problems even coming over the mtns. on I-75. Thankful!
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #122
I'm planning/thinking long term on what I need to buy. I'm in the process of buying my late brothers farm that's 60 miles away from my place. The two main reasons I'm doing this is that I believe it will significantly increase in value over time, and while I'm waiting to sell it, I want to make it a hay farm so I'm not dependent on finding people to buy hay from every year.
I need something to haul my tractors there, and then to haul hay back here.
My backhoe weighs 14,000 pounds. I'll only need it there to clear mesquite. I might leave it there for awhile, so there is the option of hiring somebody to haul it there, then haul it back when I'm done. I might also rent something local and have it delivered, but I'm not excited about that option.
My 70hp cab tractor weighs 9,000 pounds
My 65hp open station tractor weighs 5,000 pounds
So far I don't have any haying equipment, but whatever I buy, it will be a small round baler that I have enough power to run.
The 26,000 pound weight limit is something I want to stay under so I don't have to get a commercial drivers license. I had a Class A when I lived in California and I don't want to do that again.
My original plan was to find an older 3500 Ram diesel with a flatbed trailer, but the truck and trailer GVWR is way too high. Now I'm wondering if I should look at a 3/4 ton truck? and should I consider gas instead of diesel? Towing would be pretty straight each way. 45 minutes on Interstate 20, and 15 minutes on two Country Roads that's all flat land driving. It's not something I'll do every day, and probably just once a month except when haying and hauling hay two or 3 times a year depending on how much rain we get.
Since you live in Texas, the Ag Exemption will have you covered for legitimate runs like you describe.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #123
I just try not to be overweight on any single axle or exceed my registered weight limit.
This was about 47,000lbs, but no axle is exceeded. I would guess the rear truck axle is close, next would be the front axle on the trailer.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #124
I just chased down and bought a “white rhino”. I am now restoring it from years of neglect. Still a lot cheaper than spending $150,000 on a new one.
Pre-emissions, high powered class 8 4x4 with an automatic. Rare as hen’s teeth.
That ^ Right There !!!! Needs it's own Resto-Thread on TBN !
(y)
Even if someone has enough money that a six-figure truck is a rounding-error...... the Elephant in the Shop remains...... Reliability !
Rgds, D.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #125
The less I spend the better, but it needs to be reliable. I'm nervous about a diesel truck with DEF. I'm also nervous about so many used diesels that have been Deleted. And I wonder if there is enough power with a gas engine? Finally, I'm hesitant to buy anything with single rear wheels. I'm sure they are capable, and I'm probably just worried about nothing, but I have it in my head that a dually is a must for towing heavy loads. Am I wrong? Am I dealing with enough weight to require dual rear wheels?
Since I'll be off pavement when on my farm and my brothers farm, I think that I need 4wheel drive. I don't need or really want 4 doors, or even the extra cab. I think that I'll save weight with a 2 door, single cab truck. I've been trying to find GVWR on different models of trucks, but they seem to be pretty generic in what I've found so far. Is there a lower GVWR on a single cab truck over a 4 door truck that can still haul a 14,000 pound backhoe?
Thank you
You can haul that sort of weight with singles but, dual rear wheels is a lot easier and safer.
A good gas engine will work if you don't expect to run 75MPH up the backside of a good hill.
Most importantly, living in East Texas like you, I will strongly suggest good truck AND trailer brakes are the most important thing due to idiots on the local roads doing astonishingly stupid things.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #126
Since my trailer is 7x22 I do 3 rows of 5 3x3x8 bales. And will do 3 rows of 6 bales if it I am in a hurry. 18 bales is my limit. That puts the trailer at max. That is 3 tall since i don’t have the width.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #127
(y)
Rgds, D.
This is what it looked like when I first got it.
I removed the stainless steel bed and the entire engine driven central hydraulics system. We are now restoring it the frame from years of neglect, getting it PA inspected (new brakes, lines, etc.).
The truck is very unique in that it has a 41,780 GVWR. About as heavy as you can build a single axle. The rear axle is 30,000lbs alone. Front axle is 14,780.
I just pounded out all the rust jacking a few days ago and began sand blasting. Its a mess.
I have a long way to go, but my plan is to install a 12 or 13’ steel dump box on it and make it part of my land clearing & ditching operations and pull excavating equipment. I will also use it to haul mushroom soil to some of my fields.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #128
You actually have to perform an air brake test. Its a physical demonstration. One has to monitor the air brake chamber(s) filling with air, then pump the brakes to bleed them down, etc.
If someone given a Class A CDL in a dually pickup with a gooseneck is now licensed to drive an air braked 18 wheeler with a 53’ trailer,,,,, we are gonna be in heap big trouble.
As a 16 year old farm kid, I drove a Cab-over semi with Tempte SuperGrain wagon. Putting a kid in an 80,000# truck to drive ~40 miles round trip is pretty @#%^! dumb IMHO.
Luckily, I didn't die or take anyone with me. Still astounded dad thought that was a reasonable thing to do. Ignorance is bliss when you are a teenager.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #129
I think that’s something to be proud of. Your dad must have thought you were an impressive young man. I remember my dad letting me drive at 14.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #130
Hay - so they had put a brand-new Cab on that truck, just before they sold it to you ?
JK..... but your pics well illustrate my recent post...... 5 year old cabs up here don't look that good !
Well Chased and Bought ! Why no love for the SS bed, or do you just want to sell it ?
All modern diesels have suffered, but even the International dealers up here don't want to touch a MaxxForce....
Rgds, D.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #131
I would buy a Big tex 14GP gooseneck. You either hire someone for a 1 time move of your 14k machine or haul it on this trailer. I have hauled 12k on a smaller version that they used to sell and it handle it fine. It is the lightest capable trailer made due to its truss design vs a heavy I beam. Big Tex Trailers 14GP Heavy Duty Pipe Top Gooseneck Lowboy Trailer
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #132
I wish trailers were advertised by how much weight you can put on them. Not the weight of trailer and load.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #133
A 14k machine on a 14k trailer is way overloaded. As @Fixastuff said 14k means GVWR not payload. Most of those weigh at least 4k. That is why I bought a 18k trailer so I could load my 14k machine on it.
I see it all the time. Dual 7k axle trailer going down the road way overloaded with a skid steer and more.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #134
I was going by memory, he got his CDL probably over 20 years ago. His brother in law owned a trucking company so he probably took a big rig for the air brakes. I was thinking the tanker endorsement was just a written test, he was hauling air plane deicer at the time. I know you have to really study for those tests too. I live about a mile from our township shed and the road superintendent wanted me to drive a dump truck for him. Sounded like fun but it sure looked like I need a CDL.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #135
You can get Haz Mat by written test
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #136
Another question since I just went thru this. I switched insurance companies and my previous one required coverage on the trailer, new one doesn’t.
So what do people have? Insurance on the trailers they own?
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #137
I've towed a Ford 4500 backhoe on a 40 ft deck over with a Ram 2500 Diesel. It was a terrifying experience all around.
The backhoe is rear heavy. Loading it required blocking to keep the trailer from lifting the truck of the ground. We had to back it on, extend the boom to get the weight distribution right.
The trailer was very top heavy and handled / stopped terrible.
For the distance you are going / cost involved I would have it professionally hauled. That is what I have done everytime I moved my 555E since.
When we cleared my brothers 30 acres of 10 yr old pine we rented a D5 dozer. It was faster, easier to operate, more cost and time effective.
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #138
Some manufacturers have "load, payload, or cargo" included on the decal
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #139
They don't want the liability. And there is no definitive answer either.
Your average 14k bumper pull trailer probably weighs 3000#....and a well balance load can probably have 2k tongue weight
In theory that allows an actual payload of ~13k
Now if the trailer mfg states that.....
And some jackwagon double stacks pallets of bricks as far forward as possible on the trailer....they are probably overloading both the truck, hitch, and front axle. And they don't want to assume the liability because they told you the payload is 13k.
Even so.... Some trailers DO list it. They give you a tire information sticker similar to trucks that says something like "max cargo and payload shal not exceed......" Which is usually just the sum of the axles minus the tare weight of the trailer. But technically you can legally haul more if you account for tongue weight
/ Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #140
Rgds, D.
I think they took care of the cab, but the frame was only given minimal attention.
Tell you this, avoid any kind of black “coating” for frames. I’d do paint or fluid film, but not much else. The coating they used actually peeled off in places and trapped corrosives.
The SS bed was only 10’ long and had the chain drive trough in the floor. I just want a 12-13’ “rock” dump. I found an AR450 12 or 13 (dealer has both) so I’m saving up all my millions I make off hay lol
Definitely avoid IH with Max Force. This one has an HT570 “old school”, so I should be ok.
Club Car Emergency Cart (A64557)
Club Car Emergency...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2020 CATERPILLAR 259D3 SKID STEER (A65056)
2020 CATERPILLAR...
Unused 2021 MK Martin Axis 5-6 Hydraulic Took Arm Tractor Attachment (A66734)
Unused 2021 MK...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
