Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #111
A 5th wheel restriction? Never heard of that
This is what I have. I’m surprised you didn’t get the same thing if you tested in a dump truck.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #112
My truck is 11,700 and my trailer is 18,000. 29,700 total rating…. Capacity 25,300.
Your combo is over 26K but the verifiable either by door sticker or other documents show the 25,300 so according to the IL CDL testing documents that would not meet the requirements for road testing for CDL but I guess could very by state.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #113
After reading all of the post I am glad I kept my class A license and endorsements. Plus yearly med card due to my S endorsement.
Its a pain and expense to get them now. Buddy of mine retired after I did and gave up his saying he would never need them again.
He calls me the other day asking if there was a way for him to legally drive a borrowed non farm triaxle. Told him to go get his license.
Seems like all the states have their own extra rules over the mandated fed ones. At times it seems not only confusing but contradictory.
You can always locate your local dot officer and ask them for guidance.
Another resource may be your states farm bureau insurance. Ours has the farm rules broke down in plain English and guidance for what can and cant be done.
My F 700 is below cdl and farm tagged but I hope to get a gooseneck trailer for it.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #114
I don’t see how you can do it safely without being over 26k combined. Just get the class A and outfit the truck (dual rear wheels) and trailer properly and be done with it.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #115
I had a coworker who took his CDL in a pickup with a trailer. This is in Illinois and he did it several years ago. He later on got other endorsements, such as air brakes and tanker, I think those with just written tests.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #116
So now legal to drive a tractor trailer across this country.....
Just mind blowing...
But it's good to hear someone actually did it in a truck...and didn't get laughed out of the building
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #117
You actually have to perform an air brake test. Its a physical demonstration. One has to monitor the air brake chamber(s) filling with air, then pump the brakes to bleed them down, etc.
If someone given a Class A CDL in a dually pickup with a gooseneck is now licensed to drive an air braked 18 wheeler with a 53’ trailer,,,,, we are gonna be in heap big trouble.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #118
Its a double edged sword. Yes you have the bi-annual med card exam and IF you are pulled over in a CDL vehicle for a violation, the fines are larger.
However, with most cops, I have seen a higher level of respect for “knowing my sh*t”, too. You are given a modicum of respect for your knowledge. And of course, you can drive money-making, commercial vehicles.
I was pulled over by a little gal with a pony tail, could’ve passed for my daughter. She knew nothing about the inter-workings of trucks. Dumb as a fence post on ‘em, but probably knew where all the best nail salons were. She let me go. Goes about the same with younger male cops. One pulled me over because “your tires look low on air”. He ended up letting me go after I assured him I was confident the tires would be fine.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #119
Having the top CDL opens up plenty of options.
For a one-and-done run with Eddie's backhoe, hiring somebody to float it is probably the most $ efficient. Then, he can get on with setting up a truck to haul his lighter stuff. Short distance use like Eddie described, if I was looking at modern p/u's, I'd start with big-block gasoline.
Having a CDL (I do), since I'm setting my own truck parameters (as opposed to a big-fleet O/O contract), I'd probably spend the time chasing down a pre-emission diesel capable of hauling (legally) my Max load trailer wise.
Plenty of Canadians chase down USA Medium duty+ trucks; first priority is southern US, non-coastal use ideally. Depending on the year (of the chase), geography, $ ratio, phase-of-the-moon etc....... you may save money, you may not. What Canucks can gain, is more choice than what is available in our domestic market, and hopefully little/no salt damage..... As stated, >I< would be chasing a pre-emission White Rhino. Any competent heavy truck mechanic should be able to fix an air-brake system quickly.
IF Eddie is interested in non-farm use (ie. construction contracting), then medium-duty trucks open up a world of possibilities. If a medium-duty truck can address his hauling needs, then a box on a straight truck also gives plenty of haul/secure site-storage options, or could be set up as a mobile workshop.
You can set up a modern pickup to haul relatively heavy, but it's not inexpensive to do, and depending where it's plated (non-farm esp.), can put you back into CDL-required anyway....
Rgds, D.
   / Truck & Trailer ideas to tow 14,000 and be under 26,000 pounds #120
I just chased down and bought a “white rhino”. I am now restoring it from years of neglect. Still a lot cheaper than spending $150,000 on a new one.
Pre-emissions, high powered class 8 4x4 with an automatic. Rare as hen’s teeth.
Ammco Brake Machine (A55758)
Ammco Brake...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
Honda EM3500SX Generator (A55851)
Honda EM3500SX...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
