Removing hydraulic hose
/ Removing hydraulic hose #1
Quantumkev
Member
Ford 4500 Industrial Loader/Backhoe
So this might be a silly question, but I have never done it before so looking for any help/suggestions.
I have a blown hose, and need to get it off. See attached picture of the valve block. The hoses are so close together, that I won’t be able to get a wrench on.
Is the procedure to remove all of the hoses from one end, until you get to the one you are trying to get to? Or is there a better method than that?
Bad hose is third from the right, so do I just remove the other two on the right, so I can get at it?
Any ideas/suggestions appreciated.
/ Removing hydraulic hose #4
Use a pin punch and hammer to drive the fitting on the bad hose CCW. Make a divot on the hex, then one good hit with 2# hammer and punch will break it free to then turn easily.
/ Removing hydraulic hose #5
I do a lot of those. We have a hose making machine just like at the hydraulic store. Yes, I would take lines off to get to the one I need to replace.
/ Removing hydraulic hose #6
They make some fancy specialty sockets like the ones pictured if like some of us you're always looking for an excuse to buy another tool...
/ Removing hydraulic hose #7
cut the bad hose off and slip a box wrench over it.
/ Removing hydraulic hose #8
All good suggestion about taking hose off by cutting it and using punches and wrenches and such, but how are you going to tighten it when replaced..... You are going to need room to swing wrench, bite the bullet and remove "other" hoses to get access to bad one....
I would also hit area with solvent and pressure washer, a fairly clean environment to work in will make it less drudgery...
/ Removing hydraulic hose #9
Exactly what @WranglerX said. If you cannot get a simple box wrench in there to take the fitting off, then you'll never get one on. You're probably not changing out hydraulic hoses often enough to worry about buying expensive wrenches. Simply clean the area well enough, mark the hoses to the block (so you know what hose goes where when your done), and take them off.
However, if you can get a simple open ended wrench on there and are able to turn it, even a little... it sucks, trust me, but just keep going, little by little. It will eventually come off.
If you think your going to be doing this sort of repair more often, then consider getting a better wrench set.
/ Removing hydraulic hose #10
Please post back how you ended up replacing the hose and how well the chosen method worked out.
/ Removing hydraulic hose #11
You may be able to fabricate a wrench to make the removal without removing other hoses. Determine the size of wrench needed and get a box end wrench that size. Then cut a piece out of the far end of the wrench to fit over the fitting. The end would end up looking the the end in the specialty sockets shown, but the handle would come straight out. Cut the lenght of handle off as necessary to fit.
/ Removing hydraulic hose #12
Those specialty wrenches say it all !
Anyone know the thread used on the ford 4500 industrial tractor? Would be nice to take a handful of pipe plugs/caps, so I can seal the system up while I get new hoses made.
Great idea!!! Thanks for the tip.
A lot cheaper than a bunch of pipe caps.
Any suggestion about the female valve ports?
/ Removing hydraulic hose #16
Put a small sponge or wad of cotton rag etc. in the end of the finger cots
/ Removing hydraulic hose #17
Hydraulic hose wrenches like this are readily available.Or make your own specialty wrenches.
gg
/ Removing hydraulic hose #18
They are a "Flare Nut Wrench". This one is a 12 point:
This is a 6 point Flare Nut Wrench:
/ Removing hydraulic hose #19
Only way is remove hoses till you get to the bad one . Magic wrenches will not work .BTDT Kevin .
/ Removing hydraulic hose #20
And it might be worthwhile to look closely at the 2 hoses you will need to remove to see if they might be worth replacing since you have to take them off in any case, it appears...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2019 John Deere R-4038 (A63688)
2019 John Deere...
Gradall no crank no start (A61568)
Gradall no crank...
UNUSED WOLVERINE MSG-11-44W STUMPLE GRAPPLE (A64281)
UNUSED WOLVERINE...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
