My Industrial Cabin Build
   / My Industrial Cabin Build #4,031
Suggest drilling a small 3/8 hole close to the pipe to see how far that down the foam shown around the pipe, then if its under 2" either keep drilling out the concrete or get a 3" core bit like this https://www.amazon.com/Drilax-Diamond-Concrete-Masonry-inches/dp/B07L2H1PLF
You would need to cut the drain pipe to do this, but they make deeper 3" coring bits 8" instead of 3" deep so you would not need to cut the pipe as low.
   / My Industrial Cabin Build #4,032
We are on a slab. Walk in showers. No doors or steps. Required accuracy when buryin the plumbing prior to concrete. 1/2" drop at the drain then slope the slab toward it. Large shower is 4x7. Small shower is 4x5. Best showers we've ever had.
We did this too. I love ours, however we recently stopped using it because the water sealer I put directly on our slab failed and started to peel up. What did you seal your slab with?
   / My Industrial Cabin Build #4,037
Richard, when you watch that FlowFX Video, do you think there is enough "give" to connect to his PVC that is 6 degrees off plumb?
Let me watch that and get back to ya.
   / My Industrial Cabin Build #4,038
Probly not.
   / My Industrial Cabin Build #4,039
Dang it, my memory is as short as,,,,. I'll hafta get back to you on our sealer. Ours has not peeled up. We are 4 years in. Last year I cleaned and resealed the floor. We have actually began to wear thru the stain in the main shower. That's my fault for waiting too long. But we've had no problems other than discoloring.
Gary (Gary49) and Dennis (Buckeyefarmer) both came over and helped me out today. Gary brought some big tools and a lifetime of experience and we drilled out the floor carefully and avoided the pex.
The shower floor, with tile will be about 2.75 inches above the bathroom floor. So an easy step over the shower curb and. Having someone there with experience was a game changer.
Later, buckey helped me assemble a three cabinet run in the kitchen. Tomorrow I expect to have all the cabinets installed. pretty good stuff.
I cant say thank you to you guys enough.
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
40" HANG ON LOADER FORKS (A52706)
40" HANG ON LOADER...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
