Novice wants a MIG, advise ?
/ Novice wants a MIG, advise ? #101
I am still researching a MIG. So far, I am sticking with the "name brands" that I know: Lincoln, Hobart (Miller) and Everlast. What I **think** I want is a 110/220 capable machine and
- can use large spools (8")
- capable using flux core in addition to (argon+co2) with wire
- do NOT need stick or TIG capability (already have a Miller stick)
- 10' leads would be nice
So far, considering a Hobart 140, Lincoln 140 (or maybe Lincoln Handy Mig k2185-1?) and Everlast 200ES. Checked a larger Miller / Lincolns locally, the next sizes up almost 2x prices. As mentioned, the Hobart, Lincoln and Miller are sold local, so any "options"/ parts... would be available.
Honestly, I am somewhat frozen by all the specs and features. I'd really like some opinions. This machine is mainly for Hobby use. Thin gauge tubing / thinnish rebar (wire, maybe up to 1/2"). So, trying to stick with a name brand, one that is easy to load spools, adjust and as trouble free as possible.
Perhaps, the ones I mentioned are all about equivalent? But I would appreciate advice from "experts" before buying and having regrets. :)
First Spike, I'd advise you to stay away from the off brands. Some may work, some may only work for a while. The same could be said of the Miller EconoTig ($3500 at time of purchase). I've had lots of trouble with mine. First the capacitor mounting screws oxidized so bad I had a terrible time getting them out. After that I thought I was home free - for about a month when the motherboard gave up and I had no amp control. Over $300 for another MB convinced me to roll it over into a corner and use a different one (my homemade one). It's been there now for 10 years collecting cob-webs and it can stay there until I die and my sons can decide what to do with it.
I'd recommend a Lincoln. My AC/DC tombstone has been my faithful companion since 1961 and, with a high-freq unit, it still is an adequate TIG for my needs. I 've had a Lincoln MIG since 1985 and I have no complaints.
/ Novice wants a MIG, advise ? #102
I wonder what a used Millermatic 200 in good condition sells for today compared to what they used to sell for new 15 years ago?
If you are really going to use the welder a lot for a long time, the investment you make today is relative to how much use you actually get out of the machine.
/ Novice wants a MIG, advise ? #103
So, I have a Millermatic 211. With it, I've welded sheet metal plate, rebar, angle, channel, I-beam, tubing you name it. I've made cranes and yard décor. It can run on 110 which is what I used to weld the I-beam into place when I removed a support wall. I usually run it on 220. It's a great machine and I've never really had any issues in the last 6 years with it, mainly the tip or nozzle. I use it for hobby like you and not professional use but I have made enough money off of it to pay for itself a couple times over. the nice part about it is that you can just select the wire size and the material thickness and it will choose the proper feed and amps for you, no conversion charts! It can run flux core and has a spool gun option but I find 11lb spools of .035 works best for me and is the cleanest option.
To see some of my work, see my Facebook page below.
Log into Facebook
/ Novice wants a MIG, advise ? #104
Look at the machines from all brands that can switch between 120 and 240 that can output 200 amps. get the brand you are most comfortable with, also you will find out a 15 foot gun will serve you better than 10 foot from experience.
/ Novice wants a MIG, advise ? #105
Hello Spike56. I'm originally from Abilene, but joined the USMC outta highschool and am now in ID. I am 70 as of today, but despite that I'm going to welding school and should graduate in APR. All that means is that I'm not a pro either, and have little experience. But I do recognize that the previous comments have been excellent.
My recommendations are that if you are gonna weld almost exclusively 3/8" or less, then get a 3/8" rated machine. On the rare occasion that you might weld 1/2", heat the material first w/propane or map gas, NOT oxyacetylene (200 degrees is good). If you are gonna weld 1/2" more frequently than very seldom getta 1/2" capable machine.
Currently, I'm wringing my hands trying to talk myself into spending the money to buy a Miller 255. If not that, then it'll be the Miller 211.
Altho retired, I like doing tractor work for people, and I live smack in the middle of an agrarian community (6 miles north of Middleton). Welding and tractors go together, right? When I get my certificate I'll then be able to do welding for people, too. Good luck, fellow Texan. : )
/ Novice wants a MIG, advise ? #106
I've been considering Forney. I heard that Home Depot sells them. Does anyone know anything about Forney? Isn't it an old brand, too?
I was considering a Harbor Freight MIG, but I read an article once that said they come with a very short lead.
/ Novice wants a MIG, advise ? #107
- is 110/220 capable
- able to use flux core
- able to use argon+co2 with solid wire
- 10' leads
Listing the essential characteristics/requirements is a good first step.
I've noticed that the ads often highlight differences - some I never thought of when 'looking.'
On one model, the trigger in the gun not only moves the wire, but energizes it. That is, when the user is 'off the trigger,' the wire in it is (electrically) cold. I assume this is a Safety feature (of Hobart's model(s)?), but may have other benefits I have yet to understand.
So my search includes documenting features and specifications found in MFG product literature to create a comprehensive list of features and benefits - some, even many, of which I may never have thought of - (but) the manufacturers have and deemed necessary and/or worthy of the expense of incorporating into their offerings.
Some, I suspect - like those little LEDs on portable drill drivers may be practically useless embellishments while others, like the ability to regulate torque while screwing is something every fella finds useful at one time or another.
As with any contemplated purchase, determining the world of available features offered by a class or subset of the product helps reduce the likelihood of the "I coulda had a V8 for teh same $$" buyer remorse sever, many, maybe all of us have experienced at one time or another.
I was gifted a Craftsman 12" tilt-table band saw years ago (moment to recall and appreciate that lovely and rather expansive gesture of a loving wife) only to discover that "NOONE" but Sears offered blades for the dammed thing and wound up selling to buy a 14" DELTA to discover how poorly made their newer bandsaws were in some important respects. I digress.
If you take those four 'brand name' machines and document the features and benefits each promotes in their literature such that you can easily see the differences and exceptions. Then, you will have a template for adding the unbranded selections you may come across to see if any have emulated the leaders by incorporating one or many of the features you find significantly beneficial.
You might also want to document the range of accessories available for the models under consideration as well as replacement parts and consumables and document these considerations in a column of their own.
Since so many of the products on "our stores" shelves are effectively imitations of the products we can't afford, and both are often made in the same foreign land if not in the same factory - than the one next door to it, we ought to compare pictures of the welders offered on Amazon or Ali Express. In my experience, it would appear that several of our branded offerings appear to share some of the 'DNA' of their 'dearer' competition - giving me that same nagging feeling about my son's legitimacy every time I see that &@%!* postman come up the drive.
Of course, as she says, "appearances can be deceiving," so I live with that.
Now, you can trust 'the wisdom of the crowd' of course - duly noting that this is a very small crowd - but only you will glean the benefits and suffer any loss the decision brings. So be sure and do the hard work and research up front as well as watch a few Project Farm and similar videos because the technology is as old as the Dickens (well, not the original Dickens maybe) and the improvements have long been widely adopted and (with notable exceptions?) manufactured in the same place by the lowest paid workers Big Money could find.
Do let us know which you chose and, after six months or two of those eight-inch spools of wire, of any regrets and why. We will appreciate honesty and commiserate accordingly.
/ Novice wants a MIG, advise ? #108
Hello, I have a Hobart 210, it has served me well, like a few have said it is better to go bigger most likely there will be a project that will require this. My next welder will be a Miller, I used them on the job and really liked the reliability.
/ Novice wants a MIG, advise ? #109
I have an old (like 50 years old) Lincoln tobmstone, a gas outfit, had a Harbour Freight 120 amp MIG, a Miller AC/DC stick welder gas powered, and now have a Hobart 190 with spool gun. I'm on a ranch so have a wide variety of welding chores. My dad was foreman of the welding department at a shipyard, my brother was a welder at a pulp mill and neither one of them would teach me to weld. I too learned the hard way. The secret of good welding is puddle control and lotssssss of practice. Get yourself the biggest machine you can afford. Make sure you get a gas version of MIG. I have 30 amp twist plugs installed all over the place so I can use my mig almost anywhere. I can weld up to 3/4 thick material. Of course it has to be in multiple passes but it works well. You will find that if you get a spool gun it will be invaluable as you can change the small reels in a minute or two. The big 8 inch reals take more time. I usually leave my 8 inch real in the machine then switch to the spool gun when I'm doing things like cast iron. There is a lot of this around the ranch.
Good luck with you purchase and enjoy the pleasure of being able to repair things yourself.
/ Novice wants a MIG, advise ? #110
Did you get a Senile Citizen Discount on the classes?
In NC the Community Colleges cut the price of classes for Seniors and I tried getting in a Welding Class after seeing the shop they had in Shelby, NC In the one closer to us, they were not scheduling a course - and did not offer a waiting list. I'm not looking for a certificate to weld for others. Rather the experience with the wire feed world. I've a Tombstone now and watched this thread to see what folks were saying about the options 'out there.'
One source is govdeals.com Schools are replacing serious wire feed machines - and they are commanding similarly serious money. But I assume a good used Miller 255 should be worth a bit while a decent discount from retail. Based upon the bidding, lots of folks appear to agree with this supposition,
Might be worth a look.
/ Novice wants a MIG, advise ? #111
/ Novice wants a MIG, advise ? #112
At this point for the home user, it's time to put the Harbor Freight Titanium and Vulcan models in the "name brand" category. My .02. Professionally I have used Lincoln, Miller, Hobart, and Snap-On units. After I retired, moved and set up my own home shop, I did some research and ended up buying a Vulcan Pro-Tig 200 and a Titanium MIG 170. I was able to get the Pro-Tig for $250 at a HF Sidewalk sale. Someone bought it, used it for a job, then returned it. It was marked at $500 and if it didn't sell it was $250 the nest day. I told the manager make it $250 now and I will also buy the MIG and some consumables. BAM. Worth checking your local store for returns. Very easy to set up and use. Lots of aftermarket support. The only gripes are with the standard guns and ground clamps. They are serviceable enough but you may want to replace them. New Vulcans have a great extended warranty available. In my experience it is easier dealing with HF than Home Depot or Lowes if there is an issue. The local welding supply place won't give any deals to non commercial users. A lot of the more affordable "name brand" units have lots of Chinese parts and crappy drive mechanisms. In the end YOU are the factor that determines the quality of your welds for the most part. I didn't worry too much about duty cycles for home use and I have yet to bump up against it repairing or fabricating around the property.
/ Novice wants a MIG, advise ? #114
I like Lincoln & Hobart but the vulcon 215 and titan 170 from hf are as good and cost less .l have ran them for 5 years professional with no problems,both run 110 or 220 with 10 lb spolls
/ Novice wants a MIG, advise ? #115
I have the newer Hobart 140, and it does a great job for what it is. I have larger welders, so I’m covered, but I retrospect I would have gotten the Hobart 210, as it can use 120 or 240. I have higher powered stick and TIG machines, but I find myself using the MIG more than I expected.
I never use flux core, as it’s comparatively messy with a lot more splatter.
/ Novice wants a MIG, advise ? #116
I have used my Lincoln SP170 MIG/Fluxcore machine for about 25 years. Welded about $250K worth of projects with it. If you want to see one of those, look up BattleBots on YouTube. My little company fabricated most of the arena floor weapons back in 2000, 2001. It’s a 230VAC hookup. Mostly used fluxxcore wire. I found the 120VAC type machines useful only on sheet metal and low duty cycle jobs.
/ Novice wants a MIG, advise ? #117
DrRighteous,
The wire you use makes a huge difference. I use flux core wire most of the time as it is convenient. I found that INE wire made in Italy gives me WAY better results. Self-shielded flux-cored wire for welding carbon and C - Mn steels | INE SpA
Agree 100%! As an amateur, INE flux core works notably better for me compared to anything else. Finding this simply reduced the number of variables I needed to get control over, as I was learning.
I'm using a couple of welders that don't have that video display to tell you what to do. Using Inetub flux core makes it look like I know what I'm doing. Recommended!
/ Novice wants a MIG, advise ? #118
Word is that HF solid wire is rebranded INE ... not sure what their fluxcore is.
/ Novice wants a MIG, advise ? #119
I have a MIG and TIG combo welder. TIG is so much fun I am partially aroused when using it. I would suggest a combo welder if possible. 240 volt too.
/ Novice wants a MIG, advise ? #120
Probably already mentioned but the 120 volt welder is very portable as opposed to a 240 volt machine. If you're welding thick stuff you probably need a good stick machine anyway.
2013 FREIGHTLINER Cascadia (A61307)
2013 FREIGHTLINER...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
8' DISC HARROW (A60430)
8' DISC HARROW...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
