Loader M59 loader control sticking when cold
/ M59 loader control sticking when cold #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Anyone figured out how to easily lube the cables from the handle to the FEL control valve? Sticky below 30 degrees. Technique and best product? Motorcycle cable lube and injection tool? 10 years old and 1400+hours.
/ M59 loader control sticking when cold #2
I vaguely remember rScotty? mentioning something...does using brake cleaner to purge first ring a bell?
I've been using Yamalube on my bikes
I don't ride in winter and avoid rain so I can't say for sure how good the yamalube is below freezing.
These guys say avoid WD40
/ M59 loader control sticking when cold #3
Might be worth putting new cables on it anyways. I did them on an LA series loader on an M series, wasn't too hard. I had broke a cable but did both. I kept the old "good" one as a spare and it was noticeably stiff compared to the new one.
Also, if you get the old cables off you can easily clean the ends up and soak them in PBlaster.
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2020 MACK GR64FT DAYCAB (A60736)
2020 MACK GR64FT...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
