YARRA VALLEY
- Joined
- Dec 27, 2022
- Messages
- 9
- Tractor
- KUBOTA MX5100
Thank you for your response 5030 Do you mean what the dealer is adding ...BH4988 Sub Frame Kit for L3200/3800? Do you believe the BH77 us a useful BH?Whatever you decide on, make sure the backhoe is a sub frame mount
I think that is a problem all across the asian tractor market. They build for smaller people.
I'm not sure why you say the L3800 won't accommodate a hydraulic thumb. These thumbs operate via a foot control valve on the hoe hydraulics for both the BH77 and BH92 models.Which is the cheapest Kubota a BH92 Backhoe Hydraulic Thumb could be used on as im thinking Id refer a hydraulic to a mechanical thumb, but it seems the L3800HD does not accommodate a hydraulic.
Thank you for your honest comment.The BH77 is almost too strong for the machine size. It will drag and pull the L3800 around with ease, so a stronger hoe on that machine really gains nothing, because it wont stay planted.
The L4701 is probably the cheapest machine that the BH92 goes on. But I dont think there is much cost difference between a MX and the L4701. ANd you get a bigger frame, more weight, and a stronger loader.
I appreciate your comments on backhoe strength and use. Im looking at a mini excavator as an option as the tractor prices seem low to start with then quickly move to $53,000 + level in Australian $$$ by the time the add bucket, bh, and other items. I m starting to think a mini excavator might have better value. Safety in the big question and id like to use a brush cutter for blackberry cuttingI use the heck out of my BH92. Get the mechanical thumb. It’s not anywhere near a mini X in capabilities but most of us aren’t digging to 10’. You’ll find all kinds of useful projects. My BH stays on from June-Sept. and it’s a beast! On the 92 you can relocate the seat back a little to gain some room, not sure on the 77.
thanks for your comment. Whats your view of a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]KUBOTA[/AFFILIATE] MINI excavator's usefulness and strength compared to BH92?The BH77 is almost too strong for the machine size. It will drag and pull the L3800 around with ease, so a stronger hoe on that machine really gains nothing, because it wont stay planted.
Thank you for your opinion as you made me realize the 4- in 1 bucket has its limitations true from my use on the MX5100 and a grapple would indeed be a better option.I don’t think I’d add a 4-1 bucket to that setup. 4-1s are expensive. Likely more so than a dedicated bucket plus a separate grapple. They’re also heavy and they aren’t very good at grappling. A Kubota tractor backhoe is the best in the industry IMO. That being said it’s still a tractor backhoe. It’s a long ways from being a mini excavator.
I had a small hoe on my B7100 and it certainly wasn't good for large jobs. However, I was able to get it into places a small mini ex wouldn't fit. This was back in 1979 when SCUT tractors & hoes weren't all that common. I did a lot of work for electricians & plumbers in tight spaces and homeowners who wanted minimal landscape damage.I have the 2501 tractor, my friend has the 2501 with a backhoe, it works fine but in that size tractor has it's limits. I have here on the farm a U-35 that runs circles around the small tractor with hoe attachment.
Agreed. One of my tractors, a 4x4 made in Japan under the name of Satoh, later Mitsubishi, has a Blackhawk backhoe with undercarriage frame, I bought this unit new in 1978 digging lots ditches as I owned an electrical contracting business then. Also used it all over the farm here for just about anything you might think of needing a tractor or hoe. These little Japanese tractors are very impressive for their size and weight, lots of cast iron in them and the Satoh engine has been bullet proof. Have retired it now and when getting the Mini but still runs great and ready to work!I had a small hoe on my B7100 and it certainly wasn't good for large jobs. However, I was able to get it into places a small mini ex wouldn't fit. This was back in 1979 when SCUT tractors & hoes weren't all that common. I did a lot of work for electricians & plumbers in tight spaces and homeowners who wanted minimal landscape damage.
Small hoes have their place.
