Mrs. Suggested that we might consider a Mini-Excavator in our future.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #1
KilroyJC
Elite Member
Appalachia
1962 Case 430, 1995 Craftsman Yard Tractor/mower, 1949 South Bend 9A Lathe, WoodMizer Lx55 sawmill, Kubota KX033-4 Mini-Excavator
The primary tasks on our woodlot/not-yet-hobby-farm would be:
-log transport/loading with sawmill
-stump removal
-drainage ditch maintenance
-road maintenance
-construction/overhead lifting
-brush pile burning
Now, this is not going to happen anything soon.
I will not be buying anything new unless Ed McMahon shows up on my doorstep with a big check.
I have never operated a tracked excavator - my whole heavy equipment experience is a Bobcat 610 skid steer.
ANY/ALL input /suggestions/comments etc gratefullynaccepted!
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #2
Following. I love to watch people spend money!!! :)
Of your list, log transport, road maintenance and overhead lifting are things I'd never consider using a mini ex for.
You might better benefit from a CUT or Utility tractor with FEL and backhoe. It would be a much better broad range tool.
My Plan B would be something like a Ford 555 or equivalent, mainly because my tractor does not have a bucket up front. But a mini-ex can go places a backhoe cannot. But a backhoe can go places further and faster than a mini-ex.
by log transport, I mean from a log rack to the mill. I would primarily move logs dragging behind my tractor. And when I finally build the shed for my mill, it would be much easier to use an arm to lift and maneuver a 20’ long beam than to do it with jacks and pulleys And ladders.
but this is the type discussion I want to have here! And maybe it will help someone else, too.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #5
I've had a 555 for a few years now. It's a 2wd model. It will go anywhere your hoe talents can take you. I would assume the same from a mini ex, depending on the size machine you are looking at. Moving a mini ex an 1/8 mile by tracking is a painful experience.
Again, depending on mini ex size, they are limited as to what they'll lift with the boom extended horizontally. Not being familiar with your mill setup, I don't know how far horizontally you want to lift the logs?
Hopefully this thread will draw the attention of excavator owners. An excavator is a very handy tool in the right circumstances.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #6
An excavator is a very specialized tool that does a couple of things really really good, but it's also horrible at just about everything else. Transporting stuff, or moving anything is one of those things it's horrible at.
On your list, an excavator is probably the best tool out there for stump removal. Digging is what it excels at. The more HP, the better it is. Just remember that not all stumps are the same, some trees have shallow roots that are easy to take out, others have deep tap roots that can be very difficult to take out.
Drainage ditch maintenance is the only other thing on your list that the excavator might do well. It might also be very time consuming and not the right tool at all.
For transporting logs, you want something on wheels with a grapple. Tracks are very slow.
Road maintenance can be one of the most frustrating things you will ever do. The blade on a mini excavator is for short distances, small piles of dirt. But mostly it's to stabilize the exactor while digging because it's so light and unstable. Trying to use it for dozer work will be very frustrating. I personally like to use the loader bucket for maintaining my roads. I can carry a load of dirt or gravel to where I need to fix my road, dump it, spread it and smooth it out with the front bucket faster then I can with anything else.
While an excavator with a thumb is capable of lifting things overhead, I believe that the front end loader on a tractor is much more practical and easier to use. You can remove the bucket, use pallet forks, or a grapple, or even attach a boom to the loader for lifting things a lot higher, like setting trusses if the tractor is big enough.
An excavator does do a good job at feeding a burn pile, but it's so slow that this is why so many excavators catch on fire. Once you get too close to the fire, a hose melts and hydraulic fluid sprays out. The fluid is very flammable and when this happens, there isn't any hope to save the excavator. It's good for picking up branches to build he pile higher, but a burn pile shouldn't be too high. Long and thin is best so you can control the fire. Once the fire is going, a tractor with a loader works treat at punching up the fire to keep it going. Those bigger logs don't burn very well, so they need to be moved around to keep the fire going. You want to push them, back up quickly, change position, and do it again and again. I work my way around the entire burn pile several times pushing everything on top of itself with my tractor until there isn't anything left.
In my opinion, a Loader Backhoe with a quick attach front bucket and the hydraulics to operate a grapple is the best machine to do everything on your list. It's not the best at digging up stumps, but if gets the job done. And once the stump is out, it's better then an excavator at filling up the hole by being able to haul dirt to the hole, fill it up, compact it and smooth it out. Where you spend you money on a backhoe is in HP, cab or open station, 4x4 and how new it is. A 20 year old Backhoe works just a good as a brand new one, it's just not as fancy and you have to wrench on it more often. But if the HP is the same, an older one will do what a new one will for a fraction of the cost. I paid $18,000 for my open station, 2wd 555E backhoe 20 years ago, and it's still running strong. I've taken out tens of thousands of trees with it, and moved thousands of yards of dirt with it. I plan on doing more this year and every year in the future. My neighbor hires guys with excavators to work his land, then somebody else with a dozer, dump trucks and loaders to clean up the mess. I do it all with my backhoe for a lot less money, but I spend a lot more time doing it myself on one machine then he does paying to have it done.
When my backhoe finally dies it's final death, I will buy another backhoe. I'll get 4x4 next time. More traction would allow me to get even more done, even faster!!!
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #7
Excellent post Eddie.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #8
A mini excavator is actually decent for moving logs. It drives slow is the main downside but it can carry logs sideways which is nice when your trail isn’t very wide. Sure a tractor could drag it but that gets dirt in the bark and scars the ground. You can also pull a trailer and load it with the mini x to help with the low travel speed. I assume he doesn’t literally mean lifting stuff over peoples head. Not very many machines are rated for that. But a mini x is actually good at lifting stuff. You’d need a pretty big tractor to match what my KX-040 can lift. My L3800 can’t come close. Road maintenance definitely isn’t a minis strong point. I guess if you got a Kubota 40 with a 6 way blade you could do it.
I am currently loading logs with a 3pt boom on a Class 1 hitch on a 1962 Case 430 With nylon sling straps.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #10
According to my Kubota dealer he said contractors are replacing their backhoes with a Skidsteer and a minix
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #11
Get that excavator once you have it you'll find tons of uses for it!
As to road maintenance, our main road is in pretty decent shape, and I can do most upkeep with my tractor and scrape blade. Road maintenance with the mini-ex would be for putting in a couple more culverts and reopening/re-creating several badly-overgrown tracks and paths through the property. I would also want to create a pond or two, and our lot is a cove so there is some slope in many parts.
AGAIN - THESE ARE THE TYPE OF CONVERSATION AND DEBATE I AM LOOKING FOR AND YOU ALL ARE GREAT!!!! THANK YOU!!!!!!!
A couple years ago on our local Craigslist there was a vintage Caterpillar tracked loader with and excavator bucket on the back. I think it had like a 3-yard split bucket on the loader end and weighed 20000+pounds and was wayyyyyu too much money for me, but something set up like that on like a Case 310-sized platform would probably fill the bill perfectly!
this is what I am dealing with now, I plan by summer to have a shed and the mill up off the ground on a deck.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #15
Fixa, you are so right on that. I find a lot I can use it for that saves on lifting things or moving things out of the way and create piles that the tractor can grab and transport. Wish I had gotten a bigger one and a 6 way blade. Also using it to grab logs and carry it sideways out of congested area. It is a tool that helps me be better at what I do at 80 years old
And excels at digging out stumps. The ability to index it around the work in progress is great. Using a big bucket with smooth edge is great for leveling. Wish I had a tilt bucket.
Post hole digger attachments can be very useful because of ease of placing it where you want
It is handy for firewood cutting in lifting up the log to a convenient position for chainsaw and then pick up the cut pieces and put it on trailer or stack it in a pile
And then there is digging and create piles that are easy to pick up with the tractor
Digging a pond with it I would not recommend though. Unless it is small
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #16
I’d always been a backhoe guy until I bought an excavator on a whim about 2 years ago. It’s the handiest thing I’ve ever had and I don’t have backhoes anymore.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #17
Mini is certainly better at somethings than others. I bought a tractor, skid, then mini. If I was starting over I would reverse that order. They are slow moving, but, I do as much road maintenance with the x as I do the skid and tractor. Two machines could do everything if you have a mower for the skid.
Skid for moving and grading.
Tractor for mowing.
X for all ground engagement.
You will have more fun running the x than either of the others (I do anyway).
Best,
ed
The pond would be small, and q Lot of it would be damming up a branch in a crease in the land, primarily to make a penstock for pressurized water feed for a potential micro hydroelectric setup Not to mention irrigation and general use. If I make it where I want it I can have about 140’ of head. There is another potential spot for a second penstock that can give me almost 180’ of head.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #19
I sold my backhoe recently. Never used it anymore. There is a little learning curve with the excavator. The backhoe had a different pattern for controls so had to adjust to the new controls but after a short while it was second nature.
It would be good idea to rent one to see if you like it before buying.
/ Mrs. Suggested that we might consider a Mini-Excavator in our future. #20
Most mini excavators have pattern changers. I run mine on backhoe since I learned on a backhoe.
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A60352)
2013 Chevrolet...
Volvo L45H (A61307)
Volvo L45H (A61307)
2011 Infiniti QX56 Multipurpose Vehicle (MPV), VIN # JN8AZ2NEXB9001685 (A61165)
2011 Infiniti QX56...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
