Looking for a mower that is great on hills
   / Looking for a mower that is great on hills #31
I’m betting that mower costs a fortune.
Mike
   / Looking for a mower that is great on hills #33
The original poster hasn't been seen since the day after his post. Maybe he's reading while not logged in. Anyhow, specialized slope mowers are expensive beasts.
   / Looking for a mower that is great on hills #34
I didn't realize it's the same thing as a DewEze. Apparently Harper bought them?
The PowerTrac PT1850 slope mower is "only" $53,000 but the mower deck puts it closer to $60K. However, it's WAY more versatile than the DewEze and can do a 45 degree slope.
   / Looking for a mower that is great on hills #35
   / Looking for a mower that is great on hills #36
   / Looking for a mower that is great on hills #37
   / Looking for a mower that is great on hills #40
That makes more sense. I see them used for well under $10K.
Finding the price was liking trying to find "Hens Teeth". Notice the date says 2014 so I am sure the price has increased.
Here it is boys and girls.
Harper ATM Mower Pricing FOB Harper, Kansas USA March 2014
ATM -72L
+ 30.2 HP @3000 RPM gross rating: Yanmar + Liquid Cooled Diesel Engine - 61.9 ft lb torque, Industrial Use Rating + 3 cylinder with Turf Radiator + 12 Volt, 45 Amp Electrical System + Direct Hydraulic Blade Drive - No Belts or Gear Boxes + Sundstrand Hydrostatic Transmission + Foot operated Speed Control - Self-centering to Neutral + Steering Wheel with Power Steering + Hydraulic Filter, 10 micron with Indicator + Hydraulic Oil Cooler + 0-11 MPH Ground Speed + Deck Caster Tire - 11" X 4.00 X 5" - Foam Filled + Drive Tire - 25" X 12.5 X 12" - All Terrain Tread + Stablilizer Tire - 16.5" X 6.5 X 8" - Foam Filled + Hydraulic Oil Pressure Gauge with shut down protection + Volt and Hour Meters + Water Temperature Gauge + Engine Oil Pressure and Temp Gauge + Fuel Level Gauge + Hand operated Parking Brake + Automatic Self Leveling to 34 degrees with Manual Override mounted on arm rest + Adjustable Suspension Seat with arm rests and seat belt + 13 Gallon (US) Fuel Capacity + 8 Gallon (US) Hydraulic Oil Reservoir + 72" Cutting Width + 24" Uncut Circle + 2" - 6" Adjustable Cutting Height + Overall Dimensions Length 107" Width 71" Height 92" + Two 36" decks, independently free floating, with rear discharge + Decks constructed of reinforced 10 gauge steel + Welded and formed steel frame + Hydraulic Center Deck Lift with switch on dash + Roll-Over Protection System (ROPS) with hazard lights Meets ANSI/OPEI B71.4 Standards + Includes wheel weights + Warranty: 1 year parts and labor Part Number Description Weight List Pricing (Approximate) 800212 Model ATM-72LC 2400 lbs / 1088 kg
$43,720.00 (US) ALL Terrain Mower Prices are Listed in US Dollars and are Subject to Change Without Notice
2008 Ford Ranger Pickup Truck (A55852)
2008 Ford Ranger...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
(INOP) LINDE H30D WAREHOUSE FORKLIFT (A52706)
(INOP) LINDE H30D...
2010 BIG TEX 16 T/A TRASH TRAILER (A55745)
2010 BIG TEX 16...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
