modifying the M comfort seat?
/ modifying the M comfort seat? #1
DaBear3428
Orange Grove TX
Mahindra 5145
I'm a big guy and my seat bottoms out as well as is just a little to far forward and low for my tastes, has anyone modified this seat to increase the weight holding and also moved it backward as well as up? I'm thinking of adding a rail made from 1.5 X 3 14ga tube to both sides moving the seat up and back 3 and 3". as to the weight rating i'm thinking i will look at it while i have it off to maybe add an air wedge to it.
any thoughts?
/ modifying the M comfort seat? #2
I'm 6' and raised mine 2 inches. Still could use more. BUT...the higher you go the quicker your knees hit the steering wheel. And you can't (or at least I can't) extend the steering wheel upward/outward even in the upright position.
2" is much better than nothing, but 3-4" would be better.
I did get an air suspension seat (finally). worth every penny.
yes i'm thinking that 3" would be about right the 5100 series has more room behind the steering wheel. how did you modify your seat? Photos?
what air seat did you get? I really like the new M comfort seat with the arm rests but do need more weight adjustability (or lose a lot of weight)
/ modifying the M comfort seat? #4
any thoughts?
This worked for me. Up 3”and back 2”.
/ modifying the M comfort seat? #5
Modifying the seat was easy. Took two 2" rails running front to back, drilled them in the same bolt pattern and inserted them under the seat.
When I got the suspension seat, it was already 2"+ taller than the old one, so I removed the old rails. The suspension seat you get will be determined by how much clearance you have between the lever controls on the sides of your seat. I have levers on both sides, so I had to find a seat that would fit in-between. Probably narrower than what you have available to you.
/ modifying the M comfort seat? #6
The OEM seat on my Kubota M6040 moves forward/backward. It can be adjusted to fit me fine. My problem - an ice cold/hard as a rock seat when it's truly cold outside.
I was given a foam "hot pad" for the seat. Works pretty well. Throw it down on the seat, sit on it for ten minutes or so. The seat is then pretty soft and a whole lot warmer.
that is what i need looks like 3X3 16 gage? i'm planning on keeping the stock seat i like it just need more weight capacity (or lose some).
has anyone tried to install an air wedge under the seat to keep it from bottoming out?
/ modifying the M comfort seat? #8
Here's what I did. To keep the seat from bottoming out I simply adjusted the knob at the front of the seat to pre-load the spring. I'm a six feet tall and weigh 190 lbs.
rScotty
/ modifying the M comfort seat? #10
I have the 3016; not sure if my comment will help but I put sections of schedule 40 PVC inside the seat springs.
Maybe 1" dia X 3" long; whatever fits inside of the springs.
The rocking side to side was really tough on my L4 & L5.
/ modifying the M comfort seat? #11
It sounds like my MX has the same seat. I used an aftermarket suspension unit. Which increased the height 1-1.5 inch and offered a true adjustable spring setting.
It was more work than I thought Because I tossed out the OEM seat mount and basically started from scratch. It was not that difficult but the front mount (2 bolts) was lower than the rear 2 bolts. Which made the mount not easy to figure.
But I like it, I got a seat that is further back, more adjustable, and higher. Oddly but not completely surprising the new seat position made reaching the controls and steering wheel more difficult. But that was another topic.
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
Unused 2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
Unused 2024 HLA...
2025 32in Bucket Mini Excavator Attachment (A66734)
2025 32in Bucket...
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
2023 Kubota L4802DT 4WD 48HP Utility Loader Tractor (A66734)
2023 Kubota...
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
