/ Case-ih 485 injection pump parts #1
jeff123456789
1985 Case-IH 485
Hi everyone I recently added to my project list a pump rebuild on a 1985 case-ih 485. Project started as someone else's good idea and I'm left trying to get it to back together and running again.
I either need a reasonably priced good used injection pump or a parts pump.
Does anyone here know where I can get one?
It's got the Case D179 engine
And below is a link to the exact pump this tractor has on it.
Case IH D-179 - 3-CYLINDER DIESEL ENGINE (NORTH AMERICA)(01/71 - 12/88) Parts (messicks.com)
/ Case-ih 485 injection pump parts #2
hey there I 'm about 100% sure that that is a 4 cylinder engine , might want to check again however I could be wrong
/ Case-ih 485 injection pump parts #3
Pretty sure the parts link title is correct, not to mention it is a 3 cylinder
I think you might be going by the old system of model indicating # of cylinders, hp. This is a good read on that:
/ Case-ih 485 injection pump parts #4
How about this:
/ Case-ih 485 injection pump parts #5
I suggest u buy that core pump..at the very least you’ll see how everything goes..
Those VA pumps aren’t anything to fool with.. u either know how to do one OR U DON’T..
There’s shims and springs all over that pump..& if u get 1 wrong.. it’s game over..
U know where there’s a pump.. now search for a rebuild manual..
/ Case-ih 485 injection pump parts #6
It's 3 cylinder 100%. IH didn't really stick to HP/ cylinder in the model numbers for those world wide tractors.
I am 200% sure it's a 3cyl engine. Thank you for your input though
How about this:
Thank you very much for your reply. So this isn't the right pump but it's extremely close, best guess is it's an older model. However this post did give me an idea for a new search criteria which did find the right pump. So thank you very much you may have just saved this tractor from the shredder
