Generator wiring
   / Generator wiring #91
First. Employ a licenced reputable repair person who is familiar with Generators.
YOU MUST HAVE THE INTERLOCK SWITCH SO YOU DON'T POWER OUTSIDE LINES! YOU COULD KILL A LINEMAN.
THIS IS NOT FOR THE DIY PERSON.
   / Generator wiring #92
I hope that the OP's question has been answered. However, for my two cents....
When I had my home wired for my 10KW PTO generator, I had a licensed electrician do the work, When I queried him about those 'mechanical' interlocks, his reply, "They only work if and when the panel cover is installed !" If the cover is off, all bets are off.
He gave me two options. A set up where certain circuits to a separate panel are powered by the generator and a setup where the whole house was connected using a double throw switch between the power company and the Generator. For the prices that he quoted, I went with the 200Amp double throw connection. When the connection is in the 'UP" position, I am connected to my UTILITY Company and full power. When the connection is in the "DOWN" position, I am running off the limited output of the 10KW PTO Generator. Either way, all household circuits are covered. I just have to decide what is the most important and not overload my generator. As a precaution, when I am running the PTO generator, I shut off the breakers for my two biggest energy hogs...the Stove and Clothes dryer. If I do not, the circuit breaker on the generator will shut it down. I have been running this way for nearly 18 years and have had absolutely no problems.
The really nice feature with my setup is, if I ever want to upgrade the generator that I do have, when I connect a larger generator, my setup is all wired to take advantage of any increase in power.
Photo 5621a showing:
#1 - Power from the UTILITY to the double throw Transfer Switch.
#2 - Power out from the double throw Transfer Switch into the house
#3 - Power from the PTO Generator into the double throw Transfer Switch (white is #6 AWG ground for the PTO generator with heavy duty battery clamps on each end)
#4 - Double throw Transfer Switch box
Photo 5622a: showing double throw switch for either ON LINE (Utility power) or ON AUX (PTO generator)
   / Generator wiring #93
cant fault
his logic there is absolutely correct.....
those are great switches. but the standard interlock IS UL Listed for use. But your correct, they ONLY work when dead front cover is installed. But honestly, why would cover be off?
   / Generator wiring #94
Nonsense. ive seen many homeowner installed interlocks done over the years. not brain surgery. If someone is competent enough to understand the dangers in working around a panel, its an easy job. the interlocks i purchase come with full instructions.
now, if your talking about someone thats a clutz and not sure how a breaker works, then yes, leave it to the professionals.
   / Generator wiring #95
Fuddyduddy obviously has no concern for the people that supply his grid power . Lineman have injured & killed by people just like him . What you have is illegal . Just plain Illegal . Just
because you drive around with a beer between your legs & haven't got caught or hurt someone is the same logic you have about your generator . Why don't you have your power company
come out & inspect your setup ? See what they have to say about it . Or you could give us your address & we can call your power co for you .
animal
   / Generator wiring #96
I forgot to mention that I have had peoples power shut off for having setups like good ole Fuddy has .
animal
   / Generator wiring #98
If anyone is wondering if there is really a danger from 'backfeeding' into the grid, here is a great video, that I found several years ago, done by Dominion Energy. They have a portable unit, which they use traveling throughout their territory, to educate public safety departments (police, fire, rescue, etc) about downed power lines. At or about 20 minutes into the video, they demonstrate that the whole demonstration is carried out buy using a portable generator to power the whole demonstration unit. That is, a portable home generator with 120 volts back fed into a step down transformer steps up to over 7000 volts in the power lines. Feel free to share video with anyone who has and uses any home generator, be it portable, PTO, or on site backup generator.
   / Generator wiring #99
Things that were code many years ago are not often code approved today and in most cases are not required to be.
When inspecting older buildings one must reference the code that was applicable at the time the plans were submitted.
   / Generator wiring #100
I agree.
It starts with learning how to change a lightbulb safely. Then learn how to reset a GFCI. Then replace a broken light switch or outlet. Or maybe a bathroom fan.
Every homeowner should know how to disconnect the power in their house for safety reasons. Just like the should know how to turn off the gas or water.
These are tasks that can be learned through books, videos, hands-on experience with a competent teacher.
People should not fear electricity, they should respect it, and learn how to use it, troubleshoot it, and repair it.
I learned basic electronics/electrical around 8-10 years old. Pretty simple stuff.
It's a great skill to learn, or just to have the knowledge of what's going on in the box and behind the walls.
By all means, if you're not comfortable or knowledgeable about something, consult a professional. But 110/220 home wiring is not rocket science. It's very logical and beautifully simple. Most people can understand it with a little reading and patience.
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2003 Big Tex 10PI...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
John Deere 1025R (A53317)
John Deere 1025R...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
