Manual Top Link Options
/ Manual Top Link Options #1
AaronD81
PA
Kioti CK30
I'm looking for a better top link but don't have rear remotes. I currently have a standard one with a lock nut that needs threaded separately, which is double the work. I've found some with a handle that doubles as a lock, which seems like a good idea. Several variations on the design, but basic premise is the same. Interestingly, they all seem to be advertised as brand specific, most commonly JD, but others as well. Anyone have one? Any negatives?
/ Manual Top Link Options #2
The new Holland ones like on my brothers tn60 I like the best, which you mentioned. The handles serves both purposes, to adjust the link and serve as a lock
/ Manual Top Link Options #4
Trying to find a link where you can buy one that was a auction link done sold
I found it on the CNH parts website, but looks like Cat 2 and dimensions aren't listed. My tractor is Cat 1. It's also about $400 and some of the generic ones are $50 so I will probably try a cheaper one first.
/ Manual Top Link Options #6
Yeah look here but doesn't seem to list as whether it's a cat1 or 2 too bad if not available in a cat1, nice link..
/ Manual Top Link Options #7
My dad made a telescoping top link out of scrap so he could adjust the pitch of his 3pt forks on the fly. I'll take a pic tomorrow and post it.
/ Manual Top Link Options #8
This product was the subject of several threads several years ago...have not heard much about it lately but it does/can serve a purpose...it is NOT the same as a typical hydraulic top link...It requires no additional hydraulics it is self contained...
Now I see that it is no longer available from SC...
Thanks.
Interesting concept, I can't find it on Hydraulink's website either so probably discontinued.
/ Manual Top Link Options #11
He showed us how to lengthen it (By gravity) while hooked to the box blade but how do you shorten it ?
A lot of adjustments are made with the implement on the ground or a hair above the ground so you can set parallel etc which is easy with a screw turn one way or the other with that you only have gravity which is one way. It might be a real pain to set things up I don't know ???
gg
/ Manual Top Link Options #12
Agrisupply sells mechanical top links for both blue and green machines. I saw a . Pretty good collection of both Cat 1 & Cat 2 in Petersburg yesterday.
/ Manual Top Link Options #14
I used to see top links that had a hand crank handle on the side. Real easy to adjust. At one time they were popular aftermarket on older JDs for category I/II, so they may still be available somewhere.
/ Manual Top Link Options #15
I have two manual types that I no longer use. The twist type with the lock nut and the type with the hand crank handle on the side - like rScotty refers to. I went to a FitRite nine years ago. The M6040 already had the necessary valving.
The WR Long valving goes with my grapple.
/ Manual Top Link Options #16
I mostly mow with either a flail or rotary cutter. The flail requires quite a long top link and I got tired of manually adjusting it when switching mowers. My solution was get a top link for each and leave them on each mower. $50 or so at Tractor Supply or ASC.
/ Manual Top Link Options #17
$400 for an OEM top link sounds like a bit much. I got my entire hydraulic top link and hoses from FitRite for $360.
/ Manual Top Link Options #18
I asked my Kubota dealer about buying an extra long one. $280 IIRC. He suggested Tractor Supply. Also the stock Kubota ones are pretty wimpy.
That's my backup plan, I'll try one of the ones wit ha handle first.
/ Manual Top Link Options #20
So i have a bunch of thoughts on this!
As far as how you easily shorten a manual link, you pick up your implement and then set the rear of it down on something above ground level. Random rocks, tree stump, curb, etc and i would guess many implements have room onboard for a brick or 4x4 piece of wood etc to make this happen anywhere.
As far as top link design ideas:
1. 'Telescoping' top link. The pieces below are actually ride height 'mockup' tools intended to go in place of coilover shocks on a car to 'mock up' different ride heights for testing. They are about the same size as a cat0 top link, and built lighter than a 'normal' cat0 top link at that. But i do have one in place as the top link on my little Case 444 and will see how it holds up. But i think this idea for a larger top link would be good for large, fast adjustments. It is still threaded with jam nuts for adjustment in the usual way.
2. 12v 'Electrohydraulic actuator' as top link. A hydraulic cylinder with an onboard pump and reservoir. These are hard to find and expensive, but SUPER convenient as a power top link IF you can find something suitable. I have one installed as the power top link on my little Kubota B6100. This pic shows the first installation with the motor on the top outboard end and only one spherical joint at the tractor end. I've since welded another spherical joint to the base end and flipped it so the base end is attached to tractor. If these were more widely available in more sizes they'd be the go-to for people with no remotes, but the one im using would be far too weak for anything on the larger end of Cat1, let alone Cat2. I doubt it could tilt up the end of my bush hog, for example (haven't tried) but it doesn't really matter because i can always set the back of the implement on something as i said above (even the pile of dirt in the pic would work) and let gravity assist the cylinder that way.
3. A screw jack such as an adjustable side link 'leveling box', but as a top link. Or, basically a trailer tongue jack with spherical rod ends as a top link. :p
4. Ratcheting chain/load binder modified into top link. You can get a pretty big one of these for <$50, and you've already got your normal top link, right? Well, cut the middle out of this and weld it into the middle of your top link, now you have a reversible ratcheting handle on your top link. They make folding handles as well. I bought a small one to do this for a cat0 top link but i ended up converting it to a 3pt stabilizer/tensioner on my b6100 instead. Could also work as an adjustable side link in the same cut/weld fashion. So there's 3 uses right there..
5. 'Hydraulink'. Now this would be extra fiddly but there is no magic i can tell to recreating the 'hydraulink' out of a hydraulic cylinder. The only reason you can't just hook both ports of a hydraulic cylinder together with a needle valve in the middle is because they typically have different displacements on each side of the piston due to the presence of the cylinder rod on only one side. Well, there are two ways to get around this. One is leave some air in the cylinder. The cylinder will still be harder to move one way than the other, but like i said up top when you've got a heavy implement, gravity, and leverage involved it will still work by just compressing the air to allow fluid into that side. The fiddly bit is figuring out how MUCH air to make it work 'right'.
But I don't think that's what actual HydrauLink pictured above does, although they include some air/gas for cushioning. The other way to make it easy to hook both ends of a cylinder together through a needle valve, is just to use a 'through rod' cylinder with rod on both ends, which makes both sides have the same displacement. In that case you don't need to leave any air in there and it will just work.
So if you notice the hydraulink is actually a very short ~6-8" cylinder with an extension welded on one end. I suspect internally it is a through-rod cylinder with one end possibly cut/shortened to not interfere with the threaded rod end screwed into that end of it. It may also include some intentional 'gas pockets' for cushioning.
Which, by the way, if you leave air in a cylinder it has to be on both sides of the piston or it will only cushion in one direction. If you hook both ends together, how do you keep the air on one side or the other, or both? Well, suspension shock absorbers which are another form of hydraulic cylinder trap their 'gas' either in separate chambers (outer housing of a twin tube shock, gas piston at base end of a monotube shock, or even an external reservoir) or in 'gas bags' or gas bags in separate chambers, but one possible way of doing it is simply to trap air in closed cell foam. Some shock absorbers do this: video
You could make such closed cell foam take the shape of a 'bumper' aka bumpstop. One 'donut' shaped bumper of closed cell foam on each side of the cylinder would trap air and cushion the cylinder movement in each direction while not allowing the gas to travel from one side of the piston to the other through the valve. Some shocks/struts do include a bumper like this internally for their extension travel aka 'topping out' (vs bottoming out).
I don't even know why the cushioning is important but Hydraulink says it reduces operator fatigue, so heck if you want it just put it in there i guess! You could also plumb in actual hydraulic accumulators but that would be a lot more expense than some air pockets/gas bags/foam.
2021 Ford F-150XL (A64911)
2021 Ford F-150XL...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2019 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2019 HINO 268 4X2...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
INDUSTRIAL GOLD 133 GALLON COMPRESSOR (A67714)
INDUSTRIAL GOLD...
