Cowboy boot care
/ Cowboy boot care #1
sandman2234
Super Member
Jacksonville, Florida
JD2555 and a few Allis Chalmers and now one Kubota
I was wondering what y'all used to keep your cowboy boots from falling over? I was hanging mine but that is causing friction with my Bride who needs more closet space.
Anyone got anything that works good for keeping them from falling over while sitting?
David from jax
/ Cowboy boot care #4
David from jax
Try standing in them instead of sitting so much? :)
/ Cowboy boot care #5
Try kicking them off in the corner. :p They can't fall over if they are layin about.
Actually your boots must have a very soft upper ?
/ Cowboy boot care #6
stuff a pool noodle in them
perhaps this is a question for the Texans ? per capita they probably have the most cowboy boots ... I only have 2 pairs (one nice pair, one well used yard pair)
/ Cowboy boot care #7
I know that a 'good' equestrian shop/saddlery has spring-loaded, long-boot inserts. They're like a shoe-tree but for the shaft of the boot.
Googling "long-boot inserts" brings up some examples, perhaps "cowboy boot inserts" would do the same in your area?
/ Cowboy boot care #8
David from jax
What brand of boots are these that fall over?
Pic?
/ Cowboy boot care
Well, fall over might to the wrong words, but I would like them not to wrinkle at the lower end of the shaft. I quit buying Acme boots back in the late 70's when a shoe salesman gave me (in writing) a one year guarantee of a pair of Tony Lama's. I was going through a set of soles in 6 months, and by the time the second sole wore out, the uppers weren't worth putting soles on. I still have that pair of bull hide Tony Lama boots, and they are still wearable (but not to Church)
Natoma and Lucchese are the others.
/ Cowboy boot care
I failed to mention that it is the shaft of the boot that I want to support, so that it doesn't fall over, or buckle the boot just above my ankle. Some of y'all understood what I meant, but wanted to clarify my original post.
/ Cowboy boot care #12
My opinion: That just looks like normal broken in boots. That wrinkle is from wearing them, not them sitting in the closet. As your ankle moves that portion of the boot flexes. Also, sitting with feet kind of back with weight on your toes adds to it. Your pants aught to cover that area unless sitting.
I've got Tony Lama fancy boots, Twisted X, Red Wing, and Ariat. They all do it.
/ Cowboy boot care #13
I failed to mention that it is the shaft of the boot that I want to support, so that it doesn't fall over, or buckle the boot just above my ankle. Some of y'all understood what I meant, but wanted to clarify my original post.View attachment 771385
That's just normal. Actually not quite as wrinkled as some Lucchese and Redwing boots I have.
/ Cowboy boot care #14
Cowboys wear longer pants. So they don't look like they are ready to wade into some high water
Get some cowboy length pants and nobody will ever see it. Google cowboy stacked jeans
/ Cowboy boot care #15
I think those are called Capris
I could never get a pair of cowboy boots that my fat foot ever felt comfortable in.
/ Cowboy boot care
Assuming you mentioned this due to my jeans being up where the shaft of the boots are visible. I was holding my jeans up to where the boots could be seen for the picture. My jeans typically cover down to the heel or lower on the rear of the boot.
David from jax
/ Cowboy boot care #17
David from jax
My Bad, I never could resist a chance to poke fun. At least it wasn't me that went to capris
/ Cowboy boot care
Those are pretty fancy boots. I'd not want them to wrinkle either but i don't normally wear cowboy boots anymore.
Thanks!
. These are on the lower end of the high cost boot market! While I like a nice pair of boots, I am too cheap to pay thousands of dollars for them!
/ Cowboy boot care #20
Thanks!
My friend, that is just normal wear because of one's ankle . . . That's when I consider them broke in and comfortable. ;)
Takeuchi TB225 (A62177)
Takeuchi TB225...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
296385 (A57192)
296385 (A57192)
Margaritaville Decorative Metal Sign (A61569)
Margaritaville...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
2016 Peterbilt 337 S/A Flammable Liquid Transport Truck (A60352)
2016 Peterbilt 337...
