To do and not to do with Kubota DEF system.
   / To do and not to do with Kubota DEF system. #21
Just yesterday I was aerating a 45 acre piece of land I farm for a wealthy customer. They have 2 full time groundskeepers and a decent amount of property maintenance equipment. One piece they have is a 2021 Kubota L6060 with cab & loader they use for light property maintenance.
One of the groundskeepers said he was stuck in regen mode for 20 minutes with it while attempting some basic loader work.
I would like to farm in newer equipment, but I can’t afford any. I purposely steer clear of anything with DEF or DPF, except my main truck. I bought it with an extended warranty because I knew the system would fail, and it did. This summer the DEF tank gauge broke. The truck still ran, but with an annoying check engine light on, for about a month until the parts arrived.
Buying the DEF isn’t the problem, its the added layer of complexity and electronics that IS the problem. It’s prone to failure and at the worst possible time.
When I bought my 2014 F250 6.7L diesel truck in 2018 (used with 125K miles) the DEF heater module went out.
I could pay $800 to fix it or $1800 to get rid of the entire DPF system.
Wasn't a hard decision. After 4 years my truck is running great and no wasteful DEF plastic bottles going to the landfill.
   / To do and not to do with Kubota DEF system. #22
   / To do and not to do with Kubota DEF system. #23
just do a search on "DPF emulators" and enjoy. :geek:
The DEF icon flashes for a while and then becomes solid toward then end of the regeneration cycle. What does this mean?
   / To do and not to do with Kubota DEF system. #25
What is your level? My DEF icon comes on depending on level, 1/2 full on my M5-111 and between 1/4 and 1/2 on my M7-111. When I had a real problem with my M7 DEF, it also began spitting error codes, explained in detail on the large M7 display. If mine had just flashing, then solid DEF light, has always been low DEF. Remember Kubota wants you to keep the DEF level very high to prevent accumulation of ammonia vapor that can damage the sensor electronics in the DEF head.
The level is full.
Does anyone have this complete sticker?
   / To do and not to do with Kubota DEF system. #28
The only problem the neighbor has with his tier4 equipment is when he hires new help. The new help stops working and pushes buttons when going into regen. He said if they just keep working there is no problem.
That was me the first time that mine went into a regen cycle. It would have been worthwhile to read the manual first...
   / To do and not to do with Kubota DEF system. #29
Don... If you look in your Kubota owners manual or in the WSM if you have it, Kubota will call out every sticker placed on the unit and the location. If not, your local dealer can help you out.
I cannot hear any beeps, they must be at a frequency my hearing aids do not pick up with the tractor running.
The manual does not say what the difference between the flashing and the non flashing regeneration icon is.
I had hoped someone had the same sticker on top of their dash so I could find the missing part, it is not in the online owners manual.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
202473 (A54757)
202473 (A54757)
Cowboy Wooden Statue (A55853)
Cowboy Wooden...
