Tip of the day.
/ Tip of the day. #112
Carboy > here in the US that is a teen age boy more interested in cars than girls. :D
/ Tip of the day. #113
No spills is good. Stupid Kubota has the fill neck in the hood like a lawn mower but worse because the hood is about 5ft off the ground. I got a big transfer pump from Northern Equipment. Pumps a 5gal can in the blink of an eye... looking to set up a 55gal drum for fuel now, but I may wait until prices calm the F down. :oops::rolleyes::cautious:
I used to have one of those that I used to refuel my Flightstar ultralight. The tank was mounted behind the seat only a foot below the wing. Refilling the tank with a 5 gallon can was a PIA, the little pump made it a lot easier. Only thing was, half the time the batteries were dead because a couple of hangar mates were using it too.
/ Tip of the day.
Your funnels. Cover them up. I hang mine on the wall and throw an old shop rag over the top. Before that I would grab a funnel and spend a few minutes wiping the dust and dirt out of it. The film of oil just attracts dust and makes it stick.
/ Tip of the day. #115
(y)
I keep mine either in a plastic bag with a few paper towels to absorb any leftover drops of oil, or in a small tool box. I keep all my "Jerrycan" fuel nozzles a toolbox to keep them clean as well, also lined with clean paper towels.
All the best,
Peter
/ Tip of the day. #116
(y)
All the best,
Peter
I think that is a good idea.
Mine are kept in a new 5 gallon bucket with a lid.
I got that idea last xmas. It's a great place to hide xmas presents.
/ Tip of the day. #117
We have an early snow storm going on right now. So far, it has dumped about 6in of snow and the power went out.
Here is the tip: Keep your generator in good working condition, free of other things, battery charged, and by the door (if its portable).
When you need it, it shouldn't be difficult to get it up and running. You typically never need it when the sun it out on a nice warm day. You typically need it when its dark, cold, and wet.
Its not a shelf for other crap. The only thing I keep on mine is the cord that runs from the generator to the house.
Mine is portable, so I keep it in the garage, next to the door, nearest the plug. Nothing is in front of the generator that will get it the way of removing it from its place, wheeling it over the 10 feet, and getting it running.
Keep it serviced. Do regular maintenance on it. When you're done running it, don't just turn it off, turn off the fuel and let the carb run out of gas. Then switch off the ignition. Top up the fuel as soon as possible.
If yours has an electric start, keep the battery charged. If its pull start only, make sure the cord is in good condition.
Having power when the power goes out is a godsend. Especially during a freak snow storm, with small children in the house.
/ Tip of the day. #118
If you have problems removing some Phillips head screws, i.e. the screwdriver doesn't fit them well, they are most likely JIS (Japanese Industry Standard) screws, most imported items use them. Get a couple of JIS screwdrivers, #1 and #2, and they will fit much better.
Sometimes they might be Posidrive screws, but those a not very common.
/ Tip of the day. #119
All of my funnels are stored in a sealed tote and cleaned after each use.
No contaminants.
/ Tip of the day. #120
It is beyond my comprehension that in the year 2022, something as seemingly simple as a gas can is so difficult. Between the Gov't can compliance standards, and "let's make these as cheaply as possible" boggles my pea brain. Many cans sold a box store now have only a top handle. I hate that design and have to order online just to get a side handle. Sure, the single handles are usable but. Also, the self-venting spouts! Then, there is the "I cannot see, or it takes just the right light angle to see the level when filling". I had a can long ago with a clear window up the side. Can't find one now that has this and (2) handles.
I sort-of solved the self-venting. But to do so I had to by plugs (Tractor Supply), drill the can and install. Even so still a pain.
Guess, I expect TOO much these days and complain too much. ;)
You’re not complaining too much. Similar complaint about engineering and using on another thread. Politicians make unrealistic regs. Engineers make a product to meet regs, but don’t use or have to use to experience the downsides of their design. Also, because the product is engineered, that cost has to be recovered, adding to more expense or a cheaper made product to make the difference.
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
CASE TR270 SKID STEER (A62129)
CASE TR270 SKID...
(INOP) JOHN DEERE E0570 MOTORGRADER (A59823)
(INOP) JOHN DEERE...
