Tip of the day.
/ Tip of the day. #101
I put the vents on my cans also. Then I bought a pump to transfer fuel, slower but no spills.
I use the same pump which uses two D size batteries. I have to elevate the can off the ground for the pump to reach the fill port on the hood.
/ Tip of the day. #102
I bought a set of those fill spouts and I think they are junk. The plastic broke right above the threaded cap at the base of the container within the first couple of uses.
/ Tip of the day. #103
/ Tip of the day. #104
Do you bring in the back of your truck to the fuel station to fill it? Then unload it at home....
Yes, load and unload with pallet forks. But I’ve been thinking about getting a small trailer to haul the UTV. I could strap the fuel tank on the front of the trailer and just leave it there.
/ Tip of the day. #107
I write the oil drain plug size on the fill cap. Crawl under with the correct size wrench every time.
I put the oil quantity and drain lug size under the hood, written with a permanent marker.
/ Tip of the day. #108
If your project table is too short just stuff the legs in a longer piece of pipe. I used 12" long pieces of 3/4 PVC pipe to gain 6" of table height here.
/ Tip of the day. #109
Growing up we had a family friend that ran a gas station / repair shop...the man had made a "tree" that would hold a a couple dozen quart sized oil cans (before plastic bottles)...on angled plates connected to a 6" dia. pipe that was necked down and attached to the top of a carboy with a tap at the bottom...He did quite a few oil changes a week...and would use the oil from the carboy whenever he could...
So what is a "carboy"?
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
Giyi Gy-BS72B QA BoxBroom Sweeper (A60463)
Giyi Gy-BS72B QA...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
Giyi GY-SF60 (A60463)
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
