Do you hate your rotary cutter gearbox shield?
   / Do you hate your rotary cutter gearbox shield?
Keep it simple design and rigid...(y)...does it rattle while in operation?
That's right, sir!
It's designed so you have press the top/center of the shield down in order to insert the keeper pin, so it stays nice and tight. #NoRattle
Travis
Finally! I've been looking for something that would fit my Frontier mower similar to this. Working on the slip clutch or greasing takes way too long with the existing plastic shield. As soon as I get a chance to measure my gearbox I will be ordering one.
Sounds good, sir.
Yes, this will greatly simplify the process!
Travis
   / Do you hate your rotary cutter gearbox shield? #14
My entire pto shield is stored under a bench...shhh. I did look at the bolt spacing on my KK cutter and it is the 2-3/8 spacing.
   / Do you hate your rotary cutter gearbox shield? #15
Everything old is new again...
My Ford 909 rotary has an octagonal guard that mounts with that same system. Very nice for servicing the U-Joint/Slip Clutch.
Nice to be able to retrofit that style to modern mowers.
   / Do you hate your rotary cutter gearbox shield? #17
I will also be ordering one, as soon as I can measure my gearbox.
Unfortunately, I've put it away for the season, so may have to dig some stuff out to get to it.
Worth the $ to get rid of the aggravation.
I spotted some fresh gearbox hoods hangin around this morning!
Travis
   / Do you hate your rotary cutter gearbox shield? #19
Maybe I won't need to measure mine.
Anybody know the measurement for a
Frontier RC2060 rotary cutter?
The only relevant info I have on the subject is second hand.
Yesterday, someone ordered one with 2 7/8" spacing and noted that it's for his RC2060.
Travis
2015 FORD F-550 CAB ONLY (A55745)
2015 FORD F-550...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2014 John Deere 1770NT PLanter (A53485)
2014 John Deere...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
XCMG CV83PD (A53317)
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
