TC33 Starter Problem
   / TC33 Starter Problem
Tooth profile on the new one looks quite a bit different than the old one. Have you tried bolting back in the old starter and seeing if that works?
Those cuts in the teeth on new one were in the the old starter teeth too, they’ve just worn down quite a bit
   / TC33 Starter Problem #22
"I even hooked up the battery directly to the starter and jumped it nothing works it’s as if somehow being mounted on the tractor is robbing power from the tractor."
Most times that is a problem with grounding or power cable. Take a jumper cable and go from the negative battery post to a good ground on the engine and positive to the post on the starter solenoid, does it improve the action of the starter?
   / TC33 Starter Problem #23
The wear pattern on the flywheel also shows that the bendix only engages about half the tooth.
   / TC33 Starter Problem #24
One thought that I have is are your cables from the battery in good shape. I have read that they can corrode from within and you cant see it. A test could help confirm this is to use good jumper cables to supply power to your starter, if that makes it spin faster then you know there is an issue somewhere in between.
Edit: Didn't see Ruffdos's reply above, but sounds like he was thinking the same issue might be possible.
Both cables were replaced last year. I used a jumper cable to connect bat - to the stater mounting bolt, which was up against the mounting body. I used a new bat cable from + to the solenoid mount and jumped the solenoid contact both from the solenoid battery cable mount and directly from the battery.
I have confirmed the bendix is NOT extending when montes on the tractor. I put a piece of tape on the ring gear and the bendix never touches it.
Somehow the starter is losing power only when physically connected to the tractor. I just had them both checked by a shop and they’re both good.
   / TC33 Starter Problem #26
do a voltage drop test.
   / TC33 Starter Problem #28
Do I just hook up the multi tithe battery and watch for the lowest voltage?
you might want to google it, it takes a couple minutes to wrap your head around it. you put the meter on the same power wire ( both sides of plus) and look for a voltage difference, its to determine if the wiring or path is causing a low voltage issue.
Ok barely any voltage drop on the + and had .8 on the - side. I loosened and retightened the - and got a little better reading but not much. Now I keep blowing fuses like nobody’s biz. So apparently the plate that the starter bolts to must not be providing the ground it needs. I’m going to get new cables and half tempted to run a ground strap from the starter bolt to the wire harness ground right next to it. I’ll update tomorrow. Thanks so much for the help.
Well, I’m officially out of ideas. I’ve had both starters tested and they’re both good. I changed out the battery cables with new ones. I was thinking maybe somehow I screwed up the wiring when I replaced the relays but here’s the most mind boggling thing: I pulled the starter, connected the + to the battery and the - with a jumper cable to the battery the bendix advances and the starter spins up normally. Then I put a piece of tape over the end of the starter loose enough to allow it to spin but if the bendix advances it will rip the tape. Then installed the starter on the tractor and only connected the + to the battery. I jumped the solenoid and again the stater just spins, pulled the starter and the tape was still intact. So, for some reason ONLY when the starter is installed on the tractor the bendix won’t advance. I thought maybe I had a tiny misalignment issue so I colored the ring gear and starter gear with a sharpie, no shiny metal. I also installed a jumper between the wire harnesses ground on the block and one of the starter bolts. The starter bolts to a plate that attaches to the back of the motor. I never removed that while changing the clutch so the previous ground circuit is intact with the exception of me disconnecting the battery. The battery is charged and I’ve used another just in case. Same results.
   / TC33 Starter Problem #31
Well it seems like there's only a couple things it can be at this point. Since the starter is new and your positive battery cable is new and you ruled out the possibility that your battery is putting out good voltage but no amperage: either the ground circuit to the battery negative is inadequate or the starter solenoid and motor are not actuating together because they're disconnected electrically or inappropriately shorting. I think the inadequate ground scenario is more likely. You said you connected a wire from the plate that the starter is mounted to to a wiring harness ground on the block. What about the block to negative terminal connection along with the chassis to negative terminal connection?
Excessive resistance in your ground circuit causes a voltage drop per ohm's law. It doesn't take much power to free spin the starter so it is conceivable that inadequate grounds could spin the starter without actuating the solenoid.
The other thing I would try is not jumping the terminals to try to start it and use the ignition switch instead. There's some variation on starter wiring setups and there also can be some variation on interpretation of what jumping terminals means to folks. This can eliminate additional variables
After I changed out the + wire I figured it was a ground issue. At first, I forgot to disconnect the ground from the battery and connected a jumper cable from the battery to the starter mounting bolt, with same results, however, I started blowing the 30amp main fuse. I disconnected the the battery ground cable and left the jumper cable connected with the same results including blowing the fuse. I replaced the - cable with a new one removed the jumper with the same results. When I engage the starter for (guessing 10 seconds or so) it will eventually blow the 30amp. With the jumper cable attached I get .6-1v drop, which to my understanding is pretty significant.
The ground from the battery is bolted to the front frame below the engine. The engine is bolted to the frame and the panel the starter bolts to is bolted to the engine. I never removed or messed with anything in this path. The only electrical work I did was change out the old relays/relay harnesses. When changed them out I triple checked each wire but I plan to check them again today. One relay is the safety start which I know is working, the other is the start circuit relay and I believe the last is the lighting circuit. Incidentally, the lights on the rear work but the headlights have no power. I was planning to troubleshoot that issue once I had the tractor put together. Obviously the start circuit is working but seems something is sucking the juice from the starter that I’m missing. I get barely .1 voltage drop when the lights are turned on.
   / TC33 Starter Problem #33
So you have a short in the system or you wouldn't be blowing fuses. Also visualizing that you have a wire going from the battery to the frame and doing a voltage drop test does not guarantee that you have a good ground as that can change at high amperage. You should remove that wire, scrub the contact points with a wire brush, and look carefully at where the wire is crimped to the ring terminal. You can also diagnose whether ground is an issue by running a wire from the starter mounting bolt directly to the negative battery terminal -if that fixes the problem you know it's a ground issue. Do you have a wiring diagram you can post?
   / TC33 Starter Problem #35
Wow, you are blowing the main 30 amp fuse, definitely something is grounding in that circuit.
Does the fuse blow when you turn your key to the first position for the glow plugs? If not then its probably not the glow plug relay, I'd then look at the PTO safety start relay or the Safety start relay.
  • TC Series Deluxe Electrical Schematic.pdf
With regard to the battery cables. Last year I replaced both because the tractor would only activate the solenoid. I thought it was a dead battery but I changed the cables first which ended up being the issue. The tractor has custom battery cables ($150) that plug into the harness the previous owner had replaced the OEM cable and hacked into the harness, he just replaced the factory fittings. The cables I replaced with are standard Orielly auto cables with the large holes and the bolt having to make contact with the center of the lug hole. At first I thought this was an issue so I bought some solder lugs and soldered them on the cables. That didn’t cure my problem so I replaced them with crimp on. Didn’t solve the issue so I soldered the crimp on still no change.
I did run a jumper cable like you mentioned from bat - to the starter mounting bolt. That’s when I started blowing fuses, which really doesn’t make any sense to me. At first I forgot to disconnect the battery ground so it was grounded with the jumper cable and with the battery ground. When I realized this I unhooked the battery ground.
No the fuse only blew when I had the jumper cable connected from the - batt to the starter mounting bolt AND I would run the starter for several seconds (10 sec +/-). I was running the starter for a longer time to check the voltage. As the voltage would drop (up to 1v) that’s when the fuse would go. Still I don’t understand how grounding the battery to the starter mount would cause a short.
   / TC33 Starter Problem #38
There's something going on in your wiring harness that's causing the problem. I would bypass the harness all together by running a single heavy wire from your battery positive to the starter and then applying power to the starter trigger. The starter should turn the engine appropriately at that point, then you can start working through your wiring harness and figure out where you are shorting out. You may want to consider unwrapping a good portion of the harness and looking for shorts and cracks etc
   / TC33 Starter Problem #39
Voltage drop tests only work during high current such as the starter actually turning. based on the amount of work done, and the fuses blowing. I would disconnect literally everything in the start circuit and run direct wires to a battery, and work your way back
I’ve done that already. I didn’t use a switch but I connected the bat + to the starter like it should be and the - from battery to the starter mounting bolt. I used a separate wire clipped to the + battery terminal and touched the other end to the starter solenoid where the switch would connect. The starter still turns slow and bendix doesn’t advance. I even put a piece of tape over the starter gear to verify it was or wasn’t advancing. Then I removed the starter and set it on the tractor tire still hooked up the same way and it functions normally. So no matter if its in the tractors wiring circuit or not, the bendix will not advance if it’s bolted to the tractor. I’ve even loosened one of the bolts to make sure I wasn’t binding it somehow, same result. That’s why I’m so confused. No matter how it’s wired, if it’s physically attached to the tractor it won’t work properly. Off the tractor they both work fine
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
2025 CATERPILLAR 255 SKID STEER (A60429)
2025 CATERPILLAR...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
