Converting old thermostart to electric
/ Converting old thermostart to electric #12
FWIW: Here is a Thermostart diagnosis, disassembly, and replacement. (On a slightly larger machine...)
All the best, Peter
/ Converting old thermostart to electric #13
All the best, Peter
FWIW the Thermostart portion of the video starts at the 4 minute point.
Slide-on vs screw electric connector is the only difference between versions and most will take either. They are cheap to replace. I see several under $15 on Ebay.
/ Converting old thermostart to electric #14
About $9 on Amazon if ordering the Ford 1000 Series tractor types. It's the same product. We pay a tad bit more for the Yanmar name, even in the aftermarket circles. I've already replaced mine last year with the Ford identical version.
/ Converting old thermostart to electric #15
Great! Amazon is the best source then.
Before posting I searched Amazon on 'Thermostart' and nothing at all was found. So I went to Ebay.
It was/is also used on the Perkins diesels in MF, and many other tractors and industrial engines. The device is a Perkins patent.
What does Ford call it?
Photo after I bought a new one at the local ThermoKing (reefer on semitrailer) dealer.
dscn5123thermostart-perkinsbox-jpg.68476
/ Converting old thermostart to electric #16
Ford calls it a Thermo-start air-intake heater or manifold heater.
I bought mine thru AI products (aka John Deere owned aftermarket co.) here:
It's listed on Amazon for $15 thru others now.
/ Converting old thermostart to electric #18
The hard parts to find are the tubing lines and little reservoirs.
/ Converting old thermostart to electric #19
Thermostart works fine if it works properly. My old big tractor was a beast to start. So I got two freeze plug heaters, a lower radiator hose heater, covered the hood with a blanket. Plug it up and it was hot in 30 minutes. I like cranking a warm engine, easier on the engine. Most wear happens on cold starts. I had thermostart too, but it was easy when warm, busted right off.
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
2023 FORD F-650 SUPER DUTY CAB & CHASSIS TRUCK (A59823)
2023 FORD F-650...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
Here are some similar links:
