Yanmar 336d powershift lever slop
/ Yanmar 336d powershift lever slop #1
tewks
Yanmar 336D
I inherited a yanmar 336d that I've been working on. The powershift lever on the dash has the holes worn oblong where it connects to the shaft that goes down to the linkage.
What is the recommended way to fix this? If there are previous threads on this, I can't seem to find them.
Thanks in advance...
/ Yanmar 336d powershift lever slop #2
Is the dash linkage same as this one on the smaller YM186D?
Seems to me that's a project to take to a welding shop to replace the missing material then drill a new, snug hole. Then good as new.
Or you might be able to weld a thick washer on each side to provide snug holes. I'm cheap, that's what I would do, and expect maybe a thousand hours use before the washers needed to be replaced.
20200906_121205-1-powershiftshifter-jpg.668830
/ Yanmar 336d powershift lever slop #3
I have new shift levers in stock, they are not very much,if you want to start with a brand new one, send me a P.M. for the price.
/ Yanmar 336d powershift lever slop #4
Please tell me, what does the spring actually do except from just sitting there?
I don't ever see mine under any tension.
/ Yanmar 336d powershift lever slop #6
The spring pulls the handle down into the neutral position when you go there.
If you lift the handle up and let go it should pull the shift handle all the way down.
If not, replace the spring.
/ Yanmar 336d powershift lever slop #9
Sorry California, that part is No Longer Available from Yanmar.
Hoye lists it but they don't have any.
It is part no. 194170-27340.
If someone took an existing cover, measured it all up to 3D model into FreeCAD or Solidworks, the part can be made for a few dollars on a home 3D printer.
/ Yanmar 336d powershift lever slop #10
Are these covers all the same on all the powershift shifters small through larger tractors ? Almost think there'd be a small market for them.
/ Yanmar 336d powershift lever slop #11
Interesting and maybe worth checking on. I couldn't find it in my parts but my search came up " Allstate AG Parts. Apparently it's not online you have to call them. Here's the add with the Ph. #
/ Yanmar 336d powershift lever slop #12
PartsASAP - isn't that the Hoye affiliate?
/ Yanmar 336d powershift lever slop #13
I think you are right California, I think they have numerous sites.
/ Yanmar 336d powershift lever slop #14
Duplicating the cover might be a fun winter project. I have a 3D printer and could model and print it if I had a drawing or sample part to work from. I don't have this type of shifter gate on my Yanmar 2210BD and this is the only picture I could find of the cover so I don't have any idea on the overall size to see if it will fit in my print envelope. From the picture it appears to be a softer type plastic.
Is anyone on the forum with an intact cover near Black Diamond WA?
