My Homemade Skid Steer Machines
/ My Homemade Skid Steer Machines #1
oceanside ca
homemade
Main Question: Could the 2 cu in. motor difference between the two machines be the issue?
Hello all, this forum helped me out in the past (thank you!) and I again need a little help. I've built from scratch two skid steer machines with various interchangeable attachments, not sure what to call them but they dig, drill, lift and can move about 500 lbs of materials at once. I recently did some major upgrades to my first machine, the green one (Its been hacked up and redesigned a few times). New engine, pump, cylinders, chain drive, wheels, arms, valve body, flow control valve. They both are low pressure systems (2500 psi max). Try not to laugh at them too much, they work well and cost only a couple thousand to make.
My issue now is I cannot crawl up a steep 50 degree incline as I am with my other silver machine. The system pressure will not rise above 2000psi when attempting to crawl up said incline. The motor wont stall out just bog down and sit at 2000psi. The hydraulic fluid heats up pretty quick in this situation.
The machines now are now identical in powertrain terms other than the capable silver one has two 17 cu in. drive Gerotor motors and the green one has two 19 cu in Gerotor drive motors. Could the 2 cu in. difference between the two machines be the issue? The silver machine has tons of power and torque. It almost seems like fluid is getting bypassed yet I've maxed out all pressure relief valves and even bypassed the flow control valve. I understand the GPM of this system is incredibly low to what the motors call for, but I'm fine with 5mph top speed, torque is what I need.
Other general info:
16 hp gas engine
Tried both a .45 cu in. and .74 cu in gear pump, no difference
Green machine is about 300 lbs heavier then the silver machine
Green machine has much smaller fluid tank, 2 gal vs 8 gal on silver machine
These are direct drive hydraulic motor to driveshaft setups. No gear reduction. A chain links front and rear wheels together.
Silver machine has two 1/2 hoses feeding valve body, Green machine just has one 1/2 hose.
Fixed displacement pump, open center system.
/ My Homemade Skid Steer Machines #2
Post the brand and spec's for your motors.
You need to have an idea of the torque requirements of your drive system. A quick and dirty way would be to remove the motor, rig up a way to connect a simple torque wrench to the drive and see how many foot pounds is required to rotate the wheels.
Without that number the rest of what you are trying to do is a waste of time and effort.
Some motors are described as high torque low speed which strike me as describing your application but in the one case I looked at the motor is turning 1,000 rpm which seems far too fast for your direct drive system.
There are others on the forum with far more hydraulic knowledge than I have. I am just looking at basic engineering principles in providing my comments.
Great projects and I admire your ingenuity and creativity
Dave M7040
Thanks Dave. Here at the only specs I have, the current pump is putting out roughly 10 GPM-and that feeds the two 19cu in motors.
What's strange is that the other machine which works great is running roughly 6 GPM feeding two 17cu in. motors. Something isnt right...
/ My Homemade Skid Steer Machines #4
Does the silver machine also have the flow control valve after the pump? Could it be that the relief valve on the flow control valve is limiting your pressure for the travel circuit?
By the way, nice machines. I'm all for homemade stuff. Might not look pretty, but just the joy making and using it, it's great in my opinion.
Thank you, yes both machines have the flow control. I thought that might have been the issue and bypassed it completely and made no difference.
/ My Homemade Skid Steer Machines #6
What component gets hot the quickest? That would indicate your leak point or pressure loss limiting the system to 2000 PSI. 500 PSI is 20% of your available pressure to produce torque.
/ My Homemade Skid Steer Machines #7
We need the spec's for the other motor also.
You also need to do the torque wrench test I suggested
Dave
/ My Homemade Skid Steer Machines #8
As a point of reference here are the theoretical torque produced by the motors at 100 % efficient
17 CIR at 2,000 PSI = 451 ft-lbs
17 CIR at 2,500 PSI = 563 ft-lbs
19 CIR at 2,000 PSI = 504 ft-lbs
19 CIR at 2,500 PSI = 629 ft-lbs
CIR = cubic inch rev
Another variable is tire diameter. Larger diameter will reduce torque capabilities but provide higher travel speed.
/ My Homemade Skid Steer Machines #9
Great projects!
Out of what has been said so far, the comment about finding where the heat is being generated is the quickest ticket to what's going on.
I would like to see better pics of the valve sets on the machines, but my guess right now is that there is a leak between valve sections in one of the valve sets that just isn't becoming an external leak.
Left side fine metering spools, 1st aux, 2nd left side motor, 3rd right side motor- through power beyond fitting to lift,tilt, rear blade, aux. I wonder if power beyond fitting is leaking.
No problem hitting high psi and stalling engine with cylinder dead head.
Left side fine metering spools, 1st aux, 2nd left side motor, 3rd right side motor- through power beyond fitting to lift,tilt, rear blade, aux. I wonder if power beyond fitting is leaking to tank?
/ My Homemade Skid Steer Machines #12
Thanks for the follow up pics. Well, if pressure is feeding from left to right as viewed in that pic from operator station (i.e. first to drive motors, then to loader valves) then the power beyond fitting couldn't be leaking because deadheading a downstream loader valve would cause the upstream power beyond leak to 'bypass' a bunch of fluid back to tank rather than making enough pressure to stall the engine.
However, if i'm misunderstanding and pressure flows from right to left, then a leaking power beyond fitting absolutely could cause this. You should be able to redirect the tank port flow through a clear hose or just hold it slightly above the reservoir fill hole and observe tank flow when trying to operate the drive motors against a load. Maybe just chain the machine to a tree or something and see if tank flow goes up drastically when you load up the drive motors.
I keep feeling like i'm misunderstanding something about it but.. i'm fairly confident that any valves downstream of a power beyond fitting leaking to tank would not be able to make full pressure, while valves upstream of it would be unaffected by the leak. If this leak exists. But it does seem relevant, even likely.
/ My Homemade Skid Steer Machines #13
ok just curious but
are we really talking degrees here
like should I be merely really impressed by your skills or should I change religions and worship your skills?
Wow I was waaay off on my degrees, more like 30. I'm adding another oil tank after noticing foamyness. Will keep ya'll posted, thanks for all the input
/ My Homemade Skid Steer Machines #17
Well, if you're thinking the pump is sucking air and looking to prevent that, the best shape for a hydraulic reservoir is tall and narrow. If you think about filling a straw up with liquid and hooking your pump to the bottom, how far do you have to tilt the straw to 'uncover' the pump inlet? 89.9 degrees from vertical!? This is one reason why loader towers make good fluid reservoirs. Tall and skinny. (y)
/ My Homemade Skid Steer Machines #18
If you have foaming, you probably have an air leak somewhere. An air leak will absolutely degrade performance, as well as running the risk of cavitation damage to your pumps. I would double check all of your suction lines as a start.
How do you have your oil reservoir plumbed? Is the outlet to the pump at the bottom and the return below the oil level on the top? What is the total volume of oil in the system?
Do you have any oil coolers? Have you checked your oil temperature after some work? How is the oil color?
Finally while motor size is important, so is the pump/engine choice, and the setting on your pressure relief (trust but verify on the latter!).
Really creative jobs!
I have a slope rated tractor that does 30-35 degrees cross slope and a bit more up down, but traction rather than motor power or pressure relief tends to be the limiting factor, at least on my soils. (T18 Class)
All the best,
Peter
All the best,
Peter
The tank is quite small, maybe 3 gal, see attached photo. I used all 1/2" lines, and way oversized cylinders for the loads required so I feel like overall capacity is decent if you take all that volume into account? The return is on bottom and the suction is about 2" up from that. With cylinders fully extended the fluid level was very low, i think it was simply sucking in a little air when trying to crawl up hill. The Temps are fine and I have always just used trans fluid. I just welded up this extra tank which I will add to the rig. I will tee from both tanks for pump inlet/ returns and have some kind of balance line. Stay tuned, thank you
/ My Homemade Skid Steer Machines #20
Anything that you can do to keep air out of the suction line will greatly extend the lifetime of your system. If you can, try to have at least five or six inches of coverage on your outlet.
As a rough temperature check, after you run your machine for awhile, can you put your hand on the tank and keep it there?
All the best, Peter
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
17601CFL (A59228)
17601CFL (A59228)
NISSAN FORKLIFT (INOPERABLE) (A60736)
NISSAN FORKLIFT...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
