Ford 5400? Year?
/ Ford 5400? Year? #1
urbantech
Ingersoll 4020
Hi all.
I bought an industrial loader/backhoe from a local meat packer last week that was advertised and sold as a 1980s Ford 755 for $4500. It didn't take me long to figure out with a 3 cylinder diesel it's not a 755. It took me days to understand where people were saying the ID numbers are, but I found them yesterday, and I'm attaching a photo. Having a hard time deciphering just what the numbers mean. If it's a 4500, what year was it made? The model number seems to indicate it's a gas model, though it has the diesel engine in it.
The tractor ran pretty good when I tested it in their field, although it backfired constantly when opened up, there's hardly a neutral position on the power reverse shifter, so hard to get in and out of neutral and shift gears, and there's some leakage in a couple hydraulic cylinders. I drove it home about 14 miles, and right off the RPMs were going up and down quite a ways running about 2/3 throttle. The temperature was getting toward the top of the meter, around 200, so I shut it down a couple times to cool down, although I see now the temp meter shows 160 when it's cold, so a new meter is in order. I got about 3 miles from home and stopped for a minute, but when I restarted at idle throttle in gear to avoid gear grinding it wouldn't move. I observed liquid bubbling up from the boot of the shift lever. I had to leave it set til the next morning and it moved fine then. After getting it home and playing a little, it seems to be slipping terribly in reverse, can't get it to move at all in reverse without increasing RPMs significantly. I took off the trans fluid cap and the fluid is milky and was at the bottom of the gear. I put universal hyd/trans fluid in to cover the gear. I don't see a level window or dipstick. There's a lot of play in the forward/reverse lever, which I haven't looked at yet.
The hydraulic fluid in the front reservoir was low, too, and I brought it up to level. That seems to be clear, but the loader stutters from 2/3 up to the top. I'm changing oil and putting anti-stiction additive in to clean it out.
What do you think? It's obviously an older tractor than I thought I was buying. Should I go return it to them? Looking at available loaders and backhoes it seems I may not get a comparable running unit of any kind at this price. I don't need any more power than this will supply. It's actually above the range I was looking for.
/ Ford 5400? Year? #2
6C17
March 17,1966
/ Ford 5400? Year?
Thanks. So I'm right in it being a 5400?
/ Ford 5400? Year? #4
"45021F" will be a 4500. IIRC, the backhoe is a 752, but don't hold me to it.
/ Ford 5400? Year? #5
Looking at the pics I agree looks to be a 1966-1967 4500 The hood louvers were dropped in the 1968 models.
But I think the backhoe is a model 755
The crowd cylinder and lift cylinder pin spacing on the boom is wider on the 755. The 752 is the side shift model with rotary swing.
The 750 ,753 and 755 are center mount
750 and 753 were used on the 3500 model.
Not certain, but the 4500 may have been available with any of them depending on how it was ordered.
750 was a 10 foot, 753 called a 13 foot, and the 755 was the 15 foot version.
I recently bought a working but rough 1977 Ford 550 TLB with the 755 and from what I can gather the 4500 is the predecessor.
Congrats on the new TLB
/ Ford 5400? Year?
Thanks!
Ah, so the description from the seller was the backhoe model, not the tractor, and the 755 tractor was made from 79 to 84. He was sure it was an 80s model tractor, but he's just an employee and was probably tasked with getting rid of it. He had to ask the general manager if he could take $4500 for it. I'll have to look at the engine numbers to see if it was swapped from a gas model and is newer than the tractor, because if I'm not mistaken, that fourth number, 2, means it's a gas tractor.
You can see from my photo names that I thought it was a 535, by looking at photos on the tractor sites and picking out the placement of the Ford logo on the front and the shape of everything. Now I can spend fifty bucks on a service manual and know I have the right one.
Does anybody have an idea what numbers on the engine identify when it was manufactured? This makes me leery about getting the right parts for that, too, since some of the same displacement engines had different diameter cylinders and such.The tag on the fuel pump is unreadable, even with the paint dissolved off.
/ Ford 5400? Year? #7
I paid a bit more at $8000 but the main thing I was looking out for was a non leaking torque converter seal and that the trans had to have good pushing power.
Mine has lots of broken parts that have been re welded and other leaks and electrical problems.
Check out a couple vids on working on the power reverser transmission
If the deal isn't a Done deal yet. -Not trying to scare you off. but if you can not get the trans to work reliably in reverse- It could be the seals or friction discs a problem that requires splitting the tractor and that requires front engine cover removal as well as front axle and engine to get to the torque converter, pump and clutch packs. Reverser valve body can be accessed from under the fuel tank without engine removal if it is like the 550-555.
I have had bad luck with transmissions in everything from cars to trucks to skid steers. so hopefully this one keeps working, but even if it does I have plenty of other things to fix up on the 550.
That said Still happy with my purchase, and have already done a Lot of work with the 550. These mid sized backhoes have some weight and hydraulic power that will sure move some dirt.
/ Ford 5400? Year? #8
Thanks!
The giveaway for it being a 4500 is the "hard nose" square radiator shell. The other models had a sheet metal nose like an ag tractor.
The engine can be identified by this chart I made up by matching the S/N located at the bottom, RH center of the block OR RH front bottom boss of the engine. The S/N is what identified the original engine (it could have been rebuilt and bored out to the larger size) and the date code will be located in the same area that identifies the original build date. It should have a 333 engine in it. The 333H didn't come out until the 80's. My chart is only for diesel engines
/ Ford 5400? Year?
Thanks for the chart. I'll look at the engine when it's light and stops raining.
/ Ford 5400? Year? #10
Thanks!
How is it Going on the 4500? I ended up doing the same in ordering a full Paper original service manual.
The seller blue toothed a digital version to my phone and it evaporated somehow... Really like these old Ford tractors.
/ Ford 5400? Year?
I haven't had time to do anything. Finally done working a little earlier today. Planning to put new oil in with cleaner and look at the hydraulic fluid again. I'm wondering about draining and heating it to evaporate the water. Seems like the water would come out pretty quick if it was heated in the open air.
/ Ford 5400? Year?
Draining the hydraulic oil tonight. Wanted to get this done last week, but work is in demand. The stuff is the color and nearly the consistency of a butterscotch milkshake. I have 35 gallons of fluid to change it all. I was thinking of trying to heat it and get the water out, but I'm not sure I want to try as wet as it is. I'm looking at a Dryzoil water absorber to wire in the transmission tank, to absorb what water will be left from the oil that won't drain, like in the torque converter. Just hoping the torque converter hasn't been ruined by the obviously extensive use of the tractor without any regard for maintenance.
/ Ford 5400? Year?
/ Ford 5400? Year?
I bought a pdf service manual that combines several models and turns out is just scans of the paper manuals. I'm sure it's in violation of copyright and being sold repeatedly. No searching, just have to scroll to the information, just like reading a book.
/ Ford 5400? Year? #15
You drained the loader/backhoe sump of 35 gallons. Milky/caramel colored I understand. Did you find the same oil consistency in the transmission? It is a separate system from the loader/backhoe system.
/ Ford 5400? Year? #16
Late to the thread, it seems most questions are answered.
This is a good site for deciphering those model codes FORD CODES and SERIAL NUMBERS
And yes, it indicates a gasser. So one can only assume it had an engine swap somewhere along the way.
Yes its a 755 backhoe attachment, and thats the 740 loader attachment too. So if you need to look up parts on newhollands website. The hydraulics are indeed separate from the transmission, and the loader/backhoe frame is actually tube steel and is the oil reservoir.
Not sure on the trans or how different it is than a 5500. I had a 5500 with the TC trans and the suction line for the torque converter charge was on the bottom of the trans. A 90° steel fitting. Any condensation would settle to the bottom then freeze in the winter. Had to crawl under there with a propane torch several times in the winter when I needed it.
When you stopped on the road and saw steam at the shift boot.....that was probably just getting it up to operating temp and cooking the water out if the oil. Dad had a 4500, but his was not the TC trans so I have no idea about that.
IF you think this 4500 is already a little bigger than you wanted, be thankful it wasnt actually a 755. Otherwise you'd have a 18000 pound monster instead of the 10,000-11,000# machine you now have. My 5500 was a predecessor to the 755.
Here is a side by side shot of a 4500 and a 5500
/ Ford 5400? Year? #17
View attachment 766423View attachment 766424View attachment 766425View attachment 766426
For sure LD1, there is a big, big difference between the 4500 and the older 5500, 6500, 7500. The latter have a Clark transmission, which was continued on with the 750, 755... TLBs.
The 4500 has a Ford transmission with a Borg Warner shuttle assembly in the front end of it. Much simpler and smaller overall. Same basic housing as the ag tractor versions.
As far as the backhoe goes, as various replies have said, it definitely looks like a 755 backhoe attachment. But to make sure, look at the control tower facing the operator seat. If it is still intact, as SD455DAN pointed out, there is a "true model" of 19-388, 19-389 or 19-390. 19-390 is the 755 or 15' hoe. The loader has the same 19-... #, but as LD1 pointed out, it is a 740 loader as the 4500 only used this loader.
/ Ford 5400? Year? #18
Thanks for clarifying.
Dads 4500 had the 6-speed manual. 3R, 1R with a high low. I wasnt even aware they put a TC trans in a 4500. I thought that didnt start til the 500 series like the 545, 550, 555, etc.
I have also seen some 4500's with the smaller 735 loader. But those were most common on the 3400 tractors.
I am in agreement with Dan that it IS the 755 hoe. The 10 and 13' versions did have much closer pin spacing at the end of the boom cylinder and base of the dipper cylinder. Can spot the smaller hoe's a mile away.
The 740 loader was a beast in comparison to the 730 or 735 loaders. Almost too much for the tractor IMO.
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
ATS Mini Excavator ATS - ME18 (A66285)
ATS Mini Excavator...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2022 EZ-GO ELITE...
