Yanmar Tractors
/ Yanmar Tractors #41
A JD/Yanmar dealership would be an interesting marriage since they share the same engines in the compact tractor segment. Of course, Yanmar’s iHMT is a much more advanced transmission than anything that JD offers so folks might gravitate towards the Yanmar’s due to the lower price and better transmission in the YT series.
What's the iHMT do for you? Probably my favorite feature of my 2420 is the power shift transmission on it.
/ Yanmar Tractors #42
In layman’s terms it puts power to the ground like a power shift and has infinitely variable speed like an HST. You can also toggle between speed/rpm settings with buttons on the loader control stick, and has cruise control.
/ Yanmar Tractors #43
I also thought I read somewhere that you can remove the transmission without splitting the tractor.
/ Yanmar Tractors #44
Dealer is in Denton Texas. Lawn Land. The JD sign came down this week. Not sure if they are modifying for JD and Yanmar or replacing JD. This dealer is not carrying the heavy duty field tractors so much as the 75 and under HP tractors. It is a good store and purchased many items, sthil from them in the past.
I know about Lawn Land. That dealer has left me scratching my head more than a time or two. I'm not surprised that they are losing the JD brand, I'm surprised they were able to hold onto it as long as they did.
/ Yanmar Tractors #45
I would like to understand how it compares to Kubota's HST+
/ Yanmar Tractors #46
Not positive they are losing it yet. it is still early. they have both on the ground right now. We will see how it evolves and signs get replaced.
/ Yanmar Tractors #47
I’ll take a stab at it.
The Kubota HST+ has an additional transfer case in front of the HST which allows the operator to toggle between low and high range, within the primary range (L, M, H), using a lever on the dash as the tractor encounters different loads.
The Yanmar iHMT is similar in principle, but toggles electronically between pre-set speed/rpm settings using two buttons on the loader joy stick (mode A & B) as the tractor encounters different loads. The Yanmar uses a clutchless shuttle shift lever on the dash with a “gas pedal” on the floor (similar to driving an automatic vehicle) while the Kubota uses a sIngle HST pedal.
The iHMT puts more power to the ground and to the PTO than the HST, and once in gear you can inch around like with an HST.
/ Yanmar Tractors #48
The HST+ doesn't have another transfer case. It achieves the two speed change by adjusting the swash plate angle on the hydraulic motor, while the rocker pedal still control the swash plate angles on the hydraulic pump. Other brands use a fixed displacement hydraulic motor, hence why they don't have the two speed available. This concept has been around a long time ago on heavy equipment. Kubota simply applied it on a tractor.
The iHMT that Yanmar uses, is basically a scale down version of the Vario transmission that Fendt created. This transmission retains the mechanical power transfer instead of relying on a fluid power transfer like on a common HST, hence it has a lot less losses. It still has an hydrostatic drive but it doesn't actually drive the tractor directly.
/ Yanmar Tractors #49
I finally spent some time to really understand how the IHMT/I-HMT transmission on the YT3 series(YT359/YT347) Yanmar tractors works and now I understand more clearly where the benefits come from and even why it makes hydrostatic noise at a stand-still. Hopefully I can shed some light on this for others as well. There is a good video on YouTube that shows the internal workings/cut-away of the transmission, with a factory rep explaining. I had to watch it a few times before it sunk in. Here, I'll borrow a picture from this video and another on the basic hydrostatic transmission workings to illustrate. See links for them at the end. Apparently this transmission is used in some military vehicles. Due to its efficiency in the working range, I'm predicting it could become the transmission of choice in the higher end hydrostatic tractor market. It's a pretty ingenious design.
I admit I had some reservations about going with it, really due to the newness, but I went with it due to the Yanmar name and quality and it was explained to me that the transmission can be much more easily pulled and serviced if required, through the bolted plate in the rear housing. Also, I wanted the speed control of a hydrostatic transmission, but didn't like the fact that they substantially heat up when pulling heavy loads. I've previously experienced this when pulling a harrow or plow for a couple of acres, albeit with a smaller unit. With the YT359, I have not noticed the transmission heat up really, but it is not an apples-to-apples comparison. I'll leave that to someone who has two comparable size units to try. Based on my understanding of the transmission though, the IHMT should remain cooler. No issues so far, but I'm only at 230 hours. Much of that has been reasonably heavy loader work.
Let's start with a bit about a standard hydrostatic transmission. Take a look at this diagram taken from Mekanizmalar's video on YouTube. This shows a single wheel load and an electric motor, but it illustrates the concept well. You might want to open this and the second picture in separate windows to refer to while reading.
This transmission uses an axial piston pump, to the left side with the red handle on its swash plate and an axial piston motor to the right with a fixed plate, powering the wheel to the far right. The connection between the two is purely hydraulic. Instead of an electric motor shown to the far left, the power source would be the compact tractor's diesel engine. This would power the axial piston pump, which sends pressurized fluid along the red line to the axial piston motor, powering the load.
With the swash plate tilted as shown and when the diesel engine turns the pump, each of the pistons rotates around the central shaft, compressing and elongating (due to the swash-plate angle), drawing in fluid from the return side (blue) and pumping it out on the high-pressure side (red). The more the swash-plate is tilted using the red ball handle, the faster the pump moves fluid and the faster the wheel turns. The swash-plate gives infinite speed adjustability. If the swash-plate is tilted perfectly vertically, no compression or elongation happens and no pumping occurs. Also, the tractor can't move, as the hydraulic motor is hydrostatically locked. If the swash plate is tilted in the opposite direction, the pump pumps backwards and drives the wheel in reverse.
The highest efficiency of a standard hydrostatic drive is when it is pumping very little fluid, as low hydraulic flow-rates produce low friction energy loss. This corresponds to the tractor moving, but at a virtual stand-still. The faster you go, the more the transmission pumps. Pumping fluid generates heat, wasted heat, which only makes things worse because you have to get rid of that heat. It also lessens the life of the fluid. Ideally, you want to pump as little as possible.
Now suppose we could get the zero-pumping state of the transmission to correspond with some non-zero speed? If we set this speed at the typical working speed of the tractor for each gear, then when working at this speed we have optimal efficiency (no pumping). This appears to be what Yanmar aimed for with the IHMT. Also, when working slightly away from this optimal speed, we still would minimize the amount of pumping, because only the amount of pumping needed to create the speed offset would be required.
With the workings of a normal HST transmission in mind, it will be easier to explain how the IHMT works. Here is a screenshot from the IHMT YouTube video; Daniel is the guy's name. This is the actual unit used in the YT359/YT347.
We can first make correspondences to similar pieces of the normal hydrostatic transmission. The hydraulic motor output of the transmission, connected to the wheels would be where Daniel's left hand is (our right, yellow arrow). There's a lighter blue flange hidden by his hand you can see elsewhere in the video that looks like it bolts to a gear. That gear would be connected to the wheels through the three-speed range gearbox. The white arrow shows the fixed plate of the motor side. This is a complement to the light blue pump side variable swash plate that is shown by the red arrow to the left. The silver round body he is pointing to is connected directly to the diesel motor output. It actually houses the pistons for both the pump side (light blue arrow) and the motor side (light green arrow). The pump and one side of the motor always spin together at the same rate as the diesel motor.
Now suppose you set the swash plate to vertical. No fluid would be pumped, so the motor and pump would be hydrostatically locked together, just like in the case with the standard hydrostatic transmission at zero speed. However, here the tractor is moving, as the output is spinning exactly at the motor's speed. With no pumping, the efficiency should be essentially the same as a gear tractor. Changing the swash plate angle from vertical in either direction will start the pump pumping to either add or subtract from the ideal "no-pumping" speed. I assume that Yanmar designed the system so that this no-pumping speed is in the middle of the speed range for that gear, but I'm not sure if there is a good reason to bias that toward the slow or fast side of the range. Yanmar, if you are reading, you might want to consider a dash light indicating hydrostatic lock or some kind of efficiency metric that could be aimed for while working. It would allow us to maximize fuel efficiency.
... it was explained to me that the transmission can be much more easily pulled and serviced if required, through the bolted plate in the rear housing
/ Yanmar Tractors #50
This is where I get lost understanding the concept of this.
Well said, it seems like this design would be superior to straight hydrostat but if so why is Yanmar is the only manufacturer using it?
If there is anyone who has a YT347 or YT359 I would like to know what your experience has been with this transmission.
/ Yanmar Tractors #51
This is where I get lost understanding it the concept of this.
Search about Vario transmissions and you'll get some nice animations and explanations of it working, mostly from Fendt. Haven't found any good explanations from Yanmar yet.
As far as why it's not used more on smaller tractors is mainly because this transmission is crazy expensive, super complex and again, crazy expensive to repair as well. Compare the cost of an Yanmar with the iMHT to one with either a shuttle transmission or the HST.
However, I suspect in the future we might see more of these style of transmission on smaller tractors.
/ Yanmar Tractors #52
That's what I suspected. The verdict is also out as to how reliable this design will be in the long run.
/ Yanmar Tractors #53
The 250,000th Fendt Vario transmission unit rolled off the production line at the company’s German factory on Sunday, November 27.
Now every tractor that is manufactured at the factory in Marktoberdorf, in the south of Germany, is fitted with the Vario transmission.
Fendt first began using the Vario transmission 20 years ago, when the manufacturer first began production of the Fendt 926 Vario in 1996.
The stepless Vario transmission remains the only transmission solution for Fendt, according to CEO of AGCO/Fendt Peter-Josef Paffen.
At the time we consciously opted for this innovative technology and started implementing it almost right away in every range and power level.
“We now offer the solution for every power band, from 50 to 500 horsepower. Whatever the operation, the customer can always carry out their work at the right speed,” he said.
/ Yanmar Tractors #54
The Fendt Vario ones are fairly reliable. One thing that does kill those transmissions quite fast is when the operator uses the transmission to slow down the tractor, instead of the brakes. That's very hard on the transmission, specially pulling loaded tanker trailers when all that load tries to shift forward.
/ Yanmar Tractors #55
So you're saying that type of transmission is no good for engine braking.
/ Yanmar Tractors #56
It is good for engine braking, just have to be used properly. The way that transmission works, you can actually force the tractor. Compared to just slowing down by engine braking like on a shuttle transmission or a manual on a car or truck.
Using the transmission entirely as a brake, is what hurts it over time.
/ Yanmar Tractors #57
I think that it would be a mistake to over generalize. What ptsg appears to be saying is that the variable ratio type transmission he is familiar with - the Vario used by Fendt - requires special care when used for engine braking.
That may or may not have anything to do with Yanmar's design for a variable ratio transmission. Yanmar is known for high quality and for coming up with innovations that work. It's a huge company with a lot of in-house resources.
rScotty
/ Yanmar Tractors #58
I think that it would be a mistake to over generalize. What ptsg appears to be saying is that the transmission he is familiar with - the Vario used by Fendt - requires special care when used for engine braking.
That may or may not have anything to do with Yanmar's design for a variable ratio transmission. Yanmar is known for high quality and for coming up with innovations that work well. It's a huge company with a lot of in-house resources.
rScotty
What I said applies to any Vario transmission and mainly applies when pulling heavily loaded trailers. That's a lot of mass for that HST inside the transmission to handle. Just engine braking is perfectly fine as long as you're not forcing the transmission to stop the entire load, which you can do with one of those transmissions.
I suspect this won't be a problem at all on Yanmar tractors in the US, since pulling loads with smaller tractors doesn't really happen all that much.
Yanmar's transmission is nothing innovative and it's been used for a long time on Fendt tractors as shown in post #54. Yanmar simply scaled it down to fit their small tractors. On Yanmar Europe website, they even call it Vario transmission to make it clearer.
/ Yanmar Tractors #59
Yes, the variable ratio transmission has been around a long time. in simpler form, it was used on on old single speed motor scooters from the 1950s.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
CATERPILLAR 48" QUICK ATTACH PALLET FORKS (A65056)
CATERPILLAR 48"...
2006 Wells Cargo CV63627 T/A 36ft. Enclosed Command Center Trailer (A66736)
2006 Wells Cargo...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer (A66734)
2023 JCB 3TS8T...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A69167)
2020 FREIGHTLINER...
