MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,043
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Don't know about his situation, but here, code says the main disconnect has to be a short distance from the meter. Can't remember the exact distance, but I recall it being about 10' or less. That disconnect is the MAIN panel, and everything after it has to be wired as a sub-panel. So what many people call their MAIN panel, is not really their MAIN panel at all.How will you connect your indicator into live wires ahead of your main disconnect which gets shut off when the generator runs? And how will you disconnect it or fuse it if it needs to turn off?
If that's the case, it would be very easy to shut off the main disconnect at or near the meter, then wire in an indicator on the hot side in the panel that has the generator stuff in it. Or run a small wire up to a plate in a kitchen wall, or by the back door, etc, and put the indicator there for easy viewing.
