Water pump TC40
/ Water pump TC40 #1
Strummer
Strummer1%
Welp I replaced my water pump
A few days ago . Shredded about an hour . Seemed fine . Went to move some dirt for my neighbor. Started smelling antifreeze. Open the hood had water spraying everywhere. Let it cool down last night. Tore it apart today . The aftermarket water pump o got from the dealer had a paper gasket the pretty much disintegrated on me. Just got gone putting it back together this evening. Have to run to town to pick up some more distilled water to top it off . It’s a very simple job . Took all of about 15 minutes maybe 20 . I couldn’t fund the torque specks for the water pump. . Either could my local dealer .
/ Water pump TC40
Well I thought I had my water pump fixed . Turns out my new water pump wasn’t any good . Where the 2 pieces water pump bolts together had a bad gasket . Couldn’t tell until after I tore it apart for the second time . Called my dealer and they got me a oem water pump instead of an aftermarket. While putting the oem pump on I twisted a bolt off into the block . I was on my last set or torque sequence. Man I got lucky and had about 1/16 of an inch sticking out and was able to remove the broken bolt . Got it all back up and running yesterday. Shredded a few hours today and all was good .
/ Water pump TC40 #3
This is the 3rd time the pump has been removed and a bolt broke? I would loose the torque specs and hand tighten things. Clearly the spec isnt working or the bolts where not clean.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
generator trailer (A61569)
generator trailer...
(2) 460/85R38 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R38...
