Bucket wont curl
/ Bucket wont curl #1
3gunr
wentzville mo
mahindra 2538 mahindra 2810 cub cadet 7260 massey 255
My neighbor was using my 2810 mahindra and was pushing stumps with the bucket curled down and now it will not curl up or down , the loader will raise and lower fine and the 3 pt works, The curl cylinders dont look bent , is their anything i can try,
/ Bucket wont curl #2
Check the quick disconnects. Disconnect all and connect back again, even if it looks fully connected.
It's quite common for brush to hit the collar enough to disconnect even though it may look fully seated.
/ Bucket wont curl #5
Yeah, if he was pushing stuff around with the bucket fully dumped this could have come back a lot worse.
So when you do try to curl the bucket.. does the engine bog a little like you're maxing out the hydraulics, or does it just show no change to anything, not even engine sound?
/ Bucket wont curl #6
If the cylinders aren’t bent you dodged a bullet. Tractor loaders aren’t meant for pushing stumps and definitely not with the bucket rolled down.
/ Bucket wont curl #7
Not much risk of bending cylinders by pushing with it dumped. That's a concern back dragging.
/ Bucket wont curl
We have been friends for 50 yrs or i would have been really ticked off, i am going hunting in the morning so wont be able to do anything till sunday, The engine does bog a little And the bucket acts like it is trying to move, and the hydraulics sound like there is movement in the lines , It almost acts like it is stuck, I will try undoing the couplers on sunday.
/ Bucket wont curl #9
Before you do it, release all the pressure with the engine off and just move the joystick in all directions.
/ Bucket wont curl #10
You can still pull piston rod bolts off, bust the gland out of the cylinder and stretch the pin holes. And any operator treating the loader like that probably didn’t limit it to one direction.
/ Bucket wont curl #11
I can see a situation where the cylinder rod gets bent.. if the thing stopping the bucket dump travel from banging the glands out of the cylinders, is the cylinder rod resting against a pad down near the bucket end of the loader arms. Forcing it to go further could bend the very end of the cylinder rod just past where it touches that pad. And if so it would put the cylinder pin at such a close radius from the loader arm pin that pulling on it might just bind the thing up rather than rotate the bucket. It would be sort of like trying to pedal a bicycle when one of the pedals is straight up. You end up side loading the shaft without it rotating. Sort of like 'over-centering' it. If that's the case picking up the front of the tractor with the bucket, and then slowly reversing while trying to curl, might get it moving again. But if the cylinder rods are bent you don't want to power them into and through the glands or you'll probably screw them up or get them stuck worse!
/ Bucket wont curl #13
I guess I'm familiar with Kubota loaders that have a mechanical stop, and don't rely on the cylinder. Not sure how Mahindra is.
Agree it's still bad practice to push with bucket full dump....but it "shouldn't" have effected the cylinders
/ Bucket wont curl #14
Good point. Use at "full dump" is a questionable term - the questions being "really" and "why". I say this because although it might be desirable to, edge down and visible, carefully push something along the ground it would be most effective with the blade edge leading some to give the item a bit of lift. It would be unusual but a lot less sensitive to harm to have the blade trailing as it would be if the bucket were rolled all the way to a mechanical stop at full dump. -- But if you were grading dirt or gravel and pushing against that mechanical stop it might work quite safely and well since there would be no tendency for the blade to bite in, and like you say no effect on the cylinders. ... My Mahindra does have a mechanical stop. I may explore that mode "gently" with a small SSQA bucket. MUST NOT back up!
Hopefully the OP will check back in and does not have damage.
/ Bucket wont curl
Sorry for not getting back sooner but i went hunting on friday, But as usual your info was correct on the quick connect being popped out, The cable tie holding the lines together was keeping me from pushing it back in until i slid it down and got some slack, Working fine now ,thanks for the help.
/ Bucket wont curl #16
Thanks for reporting back. That’s pretty drama free though. You sure you don’t want to say something more dramatic like you replaced the entire FEL.
/ Bucket wont curl
A whole new tractor would be even better but he is a tightwad so that’s a no go
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
2022 EZ-GO ELITE...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
