Remote control forklift mast ?
/ Remote control forklift mast ? #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Any ideas appreciated. I want to remotely raise and lower the forklift mast when I am on the work platform. But I also want the levers to operate like they do now from the drivers seat... :unsure:
/ Remote control forklift mast ? #2
I've used a long stick in the past. Two ropes would also work and make it more flexible.
Although, if you want something more "civilized", you could use some sort of actuator and a remote control like those used with winches.
/ Remote control forklift mast ? #3
Being a primitive by nature I've considered sticks and ropes. That is still not out of the question.
/ Remote control forklift mast ? #6
Forgive my lack of hydraulic design comprehension, would this device go inline for the 'lift' function and be an aux control via remote?
I am not a designer either, but it seems that you could run a cable to a couple of pushbuttons in the basket to operate hydraulic solenoids to the mast cylinder. Probably best asked in the Hydraulics forum.
/ Remote control forklift mast ? #7
I presume that you would require fine movement control from the remote same as manually feathering the levers. To do that function electrically requires using proportional valve(s). If no fine movement is required then standard on- off solenoids would suffice.
Definitely - Fine control is needed/ I certainly do not want any big up or down movements with me in the cage
/ Remote control forklift mast ? #9
Talk to your forklift supplier. You don't provide enough info on what you are using currently.
Google portable electric forklift. Some come with electric remotes and man baskets doing exactly what you are looking for.
I'm using a CAT P25 with off pavement capability that we use for business and ranch work.
/ Remote control forklift mast ? #11
My need for "remote" control of my FEL is, thankfully, seldom. I've used 16 foot chunks of quarter round molding - tied together. It worked for the one time I used it.
I was lucky but I didn't press it. Now if I want to do something crazy in my raised FEL - call my son and make arrangements for him to control the tractor.
Exactly - Scared I'll drop the stick or get the rope tangled in the chains and send myself through the roof :oops:
I just want to change some light bulbs without climbing the ladder
/ Remote control forklift mast ? #14
I bought a small actuator and a remote control to play with.
The actuator moves 2 inches with 13.5 pounds pressure.
If this proves to be safe I see many potential uses.
/ Remote control forklift mast ? #16
Sounds like a simple solution.
/ Remote control forklift mast ? #17
An issue I see with the actuator is that you can't quickly "let go" and stop vertical movement of the mast in either up or down motion. You would instead have to anticipate a stopping point of movement and then move the actuator in the opposite direction to center the valve and achieve the stopping point. Might be a bit tricky and dangerous!
That is what I was thinking - obviously there will be many unmanned flights before the monkey is sent up :giggle:
I figure this will be done at idle and speeds should be slow with just a minimum of lever action. And my finger would be on the ready button.
/ Remote control forklift mast ? #19
We sent people to the moon with lowest bid parts so based on that we can maybe send a monkey to the ceiling :)
Hopefully just shy of the ceiling without going through it. Most of were I need to go is 8-10 ft.
CHANDLER 14' LITTER SPREADER (A64277)
CHANDLER 14'...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
Metal Hog Feeder (A65640)
Metal Hog Feeder...
213101 (A64276)
213101 (A64276)
1999 FONTAINE FLT-7-35HBTW LOWBOY (A62613)
1999 FONTAINE...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
