Add Rear 3-point control to Subcompact?
/ Add Rear 3-point control to Subcompact? #1
BryceSteiner
Antwerp, Ohio
RK25 T25
I just figured out how to add a rear 3-point lift control to the back of my RK25/TYM T25. I think this may work for most tractors:
if you like it, please comment and subscribe! Thanks for watching!
/ Add Rear 3-point control to Subcompact? #2
IF you use a regular QUICK HITCH.... You don't need this..... This "extra" seems to just be another awkward point in the PAT's system....
/ Add Rear 3-point control to Subcompact? #3
I appreciate the usefulness of your mod but, at the same time, see the safety issue of being in harms way when operating the 3PH from the rear. I realize that some farm tractors have buttons on the rear to operate the 3PH and have often wondered about the liability issues attached.
I'm not the safety police but just wanted to mention this. Nice simple mod.
/ Add Rear 3-point control to Subcompact? #4
I also added rear 3 pt control on my tractor and I have to say, it's absolutely awesome and super handy to have.
As far as safety goes, just like everything else related with tractors or equipment, whoever is using it, just need to have their brain in the right place and use a little bit of common sense.
/ Add Rear 3-point control to Subcompact? #5
That’s on my to do list.
The bigger the tractor the more useful it is.
/ Add Rear 3-point control to Subcompact? #6
its pretty straightforward. You dont stand between the implement and the rear tire, you stand to the side. There is no safety issue if you don't do anything stupid. If you watch the vid Bryce is standing outside of the tire so no danger.
Bryce did a great job on the control.
/ Add Rear 3-point control to Subcompact? #7
I'm trying to understand why standing relative to the tire would make any difference. I was thinking more of standing position and keeping hands away from the 3PH while using the remove position control lever would be critical.
/ Add Rear 3-point control to Subcompact? #8
The difference is if tractor pops into gear or left in gear or even out of gear and rolls backwards, it can not run over you if you are standing out side of the tires track....
Also my owners manual for my tractor it states clearly on almost every page to "turn key to off and remove key and put in pocket when leaving operators station to hook up implement"... Guess it help you from being run over by your own tractor....
And with a full QH you never have to leave operators station to do implement hook up so it also goes some ways to prevent being run over you your own tractor....
(note to site operator: "please bring back delete button")...
/ Add Rear 3-point control to Subcompact? #9
Don't you have to get off the tractor to latch the QH connections?
/ Add Rear 3-point control to Subcompact? #10
I did the same type mod to my M5640 because there was no way I could see operating the control beside the seat from the ground. Like a lot of things on a tractor you do have to think about what you are doing.
gg
/ Add Rear 3-point control to Subcompact? #11
Pop the latches back to closes position once you have disconnected from removed implement, you can then just come up under pins and the spring load feature will allow the locks to push in when they contact the pins of implement you are connecting to.... The spring load of latches is sort of a "auto latch" feature...
/ Add Rear 3-point control to Subcompact? #12
And my wife called me lazy for driving the golf cart between the house and barn...
LOL the SCUT 3PH control lever is like six inches away from the 3PH
/ Add Rear 3-point control to Subcompact? #13
Can't you stand next to the rear tire and reach over the fender to the existing 3PT control? Maybe I'm mistaken, but your tires look smaller than mine, and it's easy on my tractor -- and I'm a bit shorter than average.
My attachments vary quite a bit on the width. "standard" quick hitch is not the answer to everything. I actually use it to have better control when digging post holes.
2023 Kubota KX057-5 Compact Excavator (A63118)
2023 Kubota...
(4) ROW FIELD CULTIVATOR W/ROLLING FENDERS (A62130)
(4) ROW FIELD...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
