Add Rear 3-point control to Subcompact?
   / Add Rear 3-point control to Subcompact? #11
Don't you have to get off the tractor to latch the QH connections?
Pop the latches back to closes position once you have disconnected from removed implement, you can then just come up under pins and the spring load feature will allow the locks to push in when they contact the pins of implement you are connecting to.... The spring load of latches is sort of a "auto latch" feature...
   / Add Rear 3-point control to Subcompact? #12
And my wife called me lazy for driving the golf cart between the house and barn...
LOL the SCUT 3PH control lever is like six inches away from the 3PH
   / Add Rear 3-point control to Subcompact? #13
Can't you stand next to the rear tire and reach over the fender to the existing 3PT control? Maybe I'm mistaken, but your tires look smaller than mine, and it's easy on my tractor -- and I'm a bit shorter than average.
IF you use a regular QUICK HITCH.... You don't need this..... This "extra" seems to just be another awkward point in the PAT's system....
My attachments vary quite a bit on the width. "standard" quick hitch is not the answer to everything. I actually use it to have better control when digging post holes.
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
2020 Kubota SVL75-2 Compact Track Loader (A55314)
2020 Kubota...
2018 MERTZ FRAC CHASSIS W/ENGINE &TRANS (A55745)
2018 MERTZ FRAC...
