Front-End Loader Best SSQA trailer mover attachment?
   / Best SSQA trailer mover attachment? #2
Weld a 2in reciever right on the cross bar between the latch boxes.
A $7 part with some welding needed.
   / Best SSQA trailer mover attachment? #3
I just welded a hitch receiver tube on the center of my bucket. Then made a lowering bracket out of a piece of channel with a ball on it. Also have a fixed hook and an extended arm with a chain if I have to get up inside something to chain up and pull out.
   / Best SSQA trailer mover attachment? #4
I have been using the CL Fab SSQA quick hitch for last 3-4 years to move trailers, including partially loaded at approx 6-7K Lbs, around the work space. Also has storage for different sized balls.
   / Best SSQA trailer mover attachment? #5
My SSQA pallet forks frame came with a 2" hitch receiver mounted to it.
   / Best SSQA trailer mover attachment? #6
I used square U bolts and put a receiver hitch on the brush fork frame:
The view from the seat:
Moving the trailer:
   / Best SSQA trailer mover attachment? #8
One I built, you can see what you are doing very well. The only thing I am going to change is put a small dozer blade on the bottom.
   / Best SSQA trailer mover attachment? #10
Simply welding a 2" receiver on the top edge of the bucket is making more and more cents to me...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2018 FORD F-550 CAN AND CHASSIS (A55745)
2018 FORD F-550...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
2020 John Deere 450M Round Baler (A53485)
2020 John Deere...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
