Front-End Loader Best SSQA trailer mover attachment?
   / Best SSQA trailer mover attachment? #2
Weld a 2in reciever right on the cross bar between the latch boxes.
A $7 part with some welding needed.
   / Best SSQA trailer mover attachment? #3
I just welded a hitch receiver tube on the center of my bucket. Then made a lowering bracket out of a piece of channel with a ball on it. Also have a fixed hook and an extended arm with a chain if I have to get up inside something to chain up and pull out.
   / Best SSQA trailer mover attachment? #4
I have been using the CL Fab SSQA quick hitch for last 3-4 years to move trailers, including partially loaded at approx 6-7K Lbs, around the work space. Also has storage for different sized balls.
   / Best SSQA trailer mover attachment? #5
My SSQA pallet forks frame came with a 2" hitch receiver mounted to it.
   / Best SSQA trailer mover attachment? #6
I used square U bolts and put a receiver hitch on the brush fork frame:
The view from the seat:
Moving the trailer:
   / Best SSQA trailer mover attachment? #8
One I built, you can see what you are doing very well. The only thing I am going to change is put a small dozer blade on the bottom.
   / Best SSQA trailer mover attachment? #10
Simply welding a 2" receiver on the top edge of the bucket is making more and more cents to me...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
XCMG CV83PD (A53317)
