Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice
/ Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #1
pokemahoney
Yanmar 1610
I just noticed my Yanmar 1610 Tractor overheating. I figured I had a leaking hose or something, but when I checked the coolant reservoir there was oil in it and it's getting into the radiator as well. I checked the oil dipstick, and there isn't water in the oil pan. I figure I must have blew a head Gasket, but the tractor runs fine except it bogs down when I use the FEL to curl up on a load. This old engine is getting tired. I've changed Head Gaskets on my cars. They were all gas engines. Is there anything I need to know , or should check when changing the Head Gasket on this engine? Thank you.
/ Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #2
It's pretty straightforward, I rebuilt a 3TNA72UJ Yanmar a few years ago, and it was pretty simple. Do you have a manual for it? My manual might cover that engine too, I'd have to look at it.
Thank you! I have a service manual. Haven't dug into it yet. I noticed Hoyes have the Head gasket for around $42.00
You rebuilt the whole engine? Where did you get your parts? I helped my father rebuild a 66 mustang a long time ago. Sounds like a good project!
I deadheaded the hydraulic pump on this tractor and it sheared the bolt with the keyway off. Got a couple of backhoe hoses crossed up. Hasn't run right since I fixed that problem. Might be time for a rebuild, but for now, just a head gasket.
/ Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #4
You should have a parts list make life easier for
you when you can see how every thing goes together
willy
willy
Thank you Willy! I found a thread on Hoyes of somebody who has done this complete with parts list.
/ Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #6
It's just like any other engine. But with a Yanmar I'd check for a crack in the head. So look for a bad place in the head gasket and if no bad place, look for a crack.
/ Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #7
Yes, I rebuilt it, new rings, bearings, gaskets and valve job. Got the parts from JD, the engine was a warranty job out of a JD compact tractor with only ~50 hours on it, and it's identical to the engine in my JD430.
I used it to build a 10KW genset, and it works and runs great.
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
Snap-On Southern Thunder Edition 24-drawer tool box (A63118)
Snap-On Southern...
2021 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2021 Peterbilt 348...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
