Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice
   / Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #1
pokemahoney
Yanmar 1610
I just noticed my Yanmar 1610 Tractor overheating. I figured I had a leaking hose or something, but when I checked the coolant reservoir there was oil in it and it's getting into the radiator as well. I checked the oil dipstick, and there isn't water in the oil pan. I figure I must have blew a head Gasket, but the tractor runs fine except it bogs down when I use the FEL to curl up on a load. This old engine is getting tired. I've changed Head Gaskets on my cars. They were all gas engines. Is there anything I need to know , or should check when changing the Head Gasket on this engine? Thank you.
   / Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #2
It's pretty straightforward, I rebuilt a 3TNA72UJ Yanmar a few years ago, and it was pretty simple. Do you have a manual for it? My manual might cover that engine too, I'd have to look at it.
Thank you! I have a service manual. Haven't dug into it yet. I noticed Hoyes have the Head gasket for around $42.00
You rebuilt the whole engine? Where did you get your parts? I helped my father rebuild a 66 mustang a long time ago. Sounds like a good project!
I deadheaded the hydraulic pump on this tractor and it sheared the bolt with the keyway off. Got a couple of backhoe hoses crossed up. Hasn't run right since I fixed that problem. Might be time for a rebuild, but for now, just a head gasket.
   / Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #4
You should have a parts list make life easier for
you when you can see how every thing goes together
willy
willy
Thank you Willy! I found a thread on Hoyes of somebody who has done this complete with parts list.
   / Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #6
It's just like any other engine. But with a Yanmar I'd check for a crack in the head. So look for a bad place in the head gasket and if no bad place, look for a crack.
   / Need to change the Head Gasket on my Yanmar 1610 Tractor-Engine 3T75U-Need advice #7
Yes, I rebuilt it, new rings, bearings, gaskets and valve job. Got the parts from JD, the engine was a warranty job out of a JD compact tractor with only ~50 hours on it, and it's identical to the engine in my JD430.
I used it to build a 10KW genset, and it works and runs great.
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2003 INTERNATIONAL 7600 6X4 DUMP TRUCK (A51247)
2003 INTERNATIONAL...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2022 BOBCAT T76 PLATINUM R SERIES SKID STEER (A51246)
2022 BOBCAT T76...
UNUSED CHERY INDUSTRIAL 11' CATTLE SQUEEZE CHUTE (A51248)
UNUSED CHERY...
